uhd::filter_info_base Class Reference
Inheritance diagram for uhd::filter_info_base:
uhd::analog_filter_base uhd::digital_filter_base< tap_t > uhd::analog_filter_lp uhd::digital_filter_fir< tap_t >
enum  filter_type { ANALOG_LOW_PASS, ANALOG_BAND_PASS, DIGITAL_I16, DIGITAL_FIR_I16 }
typedef boost::shared_ptr< filter_info_basesptr
 filter_info_base (filter_type type, bool bypass, size_t position_index)
virtual bool is_bypassed ()
filter_type get_type ()
virtual ~filter_info_base ()
virtual std::string to_pp_string ()
Protected Attributes
filter_type _type
bool _bypass
size_t _position_index
typedef boost::shared_ptr<filter_info_base> uhd::filter_info_base::sptr
◆ filter_type
Enumerator
ANALOG_LOW_PASS
ANALOG_BAND_PASS
DIGITAL_I16
DIGITAL_FIR_I16
◆ filter_info_base()
uhd::filter_info_base::filter_info_base ( filter_type  type,
bool  bypass,
◆ ~filter_info_base()
virtual uhd::filter_info_base::~filter_info_base ( )
◆ get_type()
filter_type uhd::filter_info_base::get_type ( )
◆ is_bypassed()
virtual bool uhd::filter_info_base::is_bypassed ( )
◆ to_pp_string()
virtual std::string uhd::filter_info_base::to_pp_string ( )
virtual
◆ _bypass
bool uhd::filter_info_base::_bypass
◆ _position_index
size_t uhd::filter_info_base::_position_index
◆ _type
filter_type uhd::filter_info_base::_type
