#include <uhd/stream.hpp>
virtual ~rx_streamer (void)
virtual void issue_stream_cmd (const stream_cmd_t &stream_cmd)=0
◆ buffs_type
◆ ~rx_streamer()
virtual uhd::rx_streamer::~rx_streamer ( void  )
virtual
◆ get_max_num_samps()
◆ get_num_channels()
◆ issue_stream_cmd()
virtual void uhd::rx_streamer::issue_stream_cmd ( const stream_cmd_t stream_cmd)
◆ recv()
rx_metadata_t metadata,
const double  timeout = 0.1,
Receive handles fragmentation as follows: If the buffer has insufficient space to hold all samples that were received in a single packet over-the-wire, then the buffer will be completely filled and the implementation will hold a pointer into the remaining portion of the packet. Subsequent calls will load from the remainder of the packet, and will flag the metadata to show that this is a fragment. The next call to receive, after the remainder becomes exhausted, will perform an over-the-wire receive as usual. See the rx metadata fragment flags and offset fields for details.
