uhd::task Class Reference
#include <uhd/utils/tasks.hpp>
typedef boost::shared_ptr< task > sptr
◆ task_fcn_type
◆ make()
static sptr uhd::task::make ( const task_fcn_type &  task_fcn)
a new task object
