uhd::timed_wb_iface Class Referenceabstract
#include <uhd/types/wb_iface.hpp>
Inheritance diagram for uhd::timed_wb_iface:
uhd::wb_iface
typedef boost::shared_ptr< timed_wb_iface > sptr
- Public Types inherited from uhd::wb_iface
typedef boost::shared_ptr< wb_iface > sptr
typedef boost::uint32_t wb_addr_type
virtual time_spec_t get_time (void)=0
virtual void set_time (const time_spec_t &t)=0
- Public Member Functions inherited from uhd::wb_iface
virtual ~wb_iface (void)
virtual void poke64 (const wb_addr_type addr, const boost::uint64_t data)
virtual boost::uint64_t peek64 (const wb_addr_type addr)
virtual void poke32 (const wb_addr_type addr, const boost::uint32_t data)
virtual boost::uint32_t peek32 (const wb_addr_type addr)
virtual void poke16 (const wb_addr_type addr, const boost::uint16_t data)
virtual boost::uint16_t peek16 (const wb_addr_type addr)
typedef boost::shared_ptr<timed_wb_iface> uhd::timed_wb_iface::sptr
◆ get_time()
virtual time_spec_t uhd::timed_wb_iface::get_time ( void  )
Get the command time.
the command time
◆ set_time()
virtual void uhd::timed_wb_iface::set_time ( const time_spec_t &  t)
Set the command time.
tthe command time
