USRP-E3xx Series
Comparative features list - E310
  • Hardware Capabilities: Integrated RF frontend (70 MHz - 6 GHz)
    • Configurable clock rate
    • Internal GPIO connector with UHD API control
    • 2 USB 2.0 Host ports
    • Internal GPS
    • Soundcard mono input / stereo output
    • USB UART
    • Internal IMU
    • Zynq-7020 FPGA
  • FPGA Capabilities:
    • 2 RX DDC chains in FPGA
    • 2 TX DUC chain in FPGA
    • Timed commands in FPGA
    • Timed sampling in FPGA
    • 16-bit fixed point sample mode (sc16)
Getting started
This will run you through the first steps relevant to get your USRP E310 up and running.
First boot
There are two different methods to connect to the device
  • using the onboard Serial to USB connector
  • using the gigabit Ethernet connector and a ssh client on your host computer
For the first boot, booting with the serial cable connected to the device is recommended, as it allows to review and modify the Network configuration and allows to enter the bootloader in case of issues during the boot.
Serial connection
To use the serial connection together with a Linux or OSX machine (most other UNIX variants come with a version of screen, too) a terminal emulator such as screen can be used:
$ sudo screen /dev/ttyUSB0 115200
The exact device node /dev/ttyUSB0 depends on your operating system's driver and other USB devices that might be already connected. It can be usually found by perusing the output of dmesg or journalctl, after connecting the USRP E310 device to your host computer.
An example of a dmesg output for the serial to usb converter:
924.102764] usb 1-1: FTDI USB Serial Device converter now attached to ttyUSB0
On Microsoft Windows the serial connection can be established using a tool such as Putty by selecting a baudrate of 115200 and the corresponding serial port for the serial to usb converter.
In both cases you should see boot messages fly by and finally end up with a login prompt similar to the following:
ettus-e300 login:
Note: The username is 'root' and the default password is empty.
You should be presented with a shell similar to the following
root@ettus-e300:~#
SSH connection
The USRP E310 device relies on the DHCP protocol to automatically obtain an IP address. In case your network setup does not include a DHCP server, refer to the section Serial connection or configure a DHCP server to hand out IP addresses on your network.
$ ssh root@192.168.10.42
where the IP address depends on your local network setup.
On Microsoft Windows again the connection can be established using a tool such as Putty, by selecting a username of root without password.
root@ettus-e300:~#
Using the SDK
In order to facilitate software development for the integrated ARM Cortex-A9 processor, a Yocto Project based SDK is provided in the download section of our website. This SDK contains a cross-compiler, a cross-linker as well as a cross-debugger and can be used to develop your user space applications for the Ettus USRP-E310 devices.
Installation
The following section will guide you through the installation of the provided SDK on a Linux development machine.
Obtaining the correct SDK
It is necessary for the SDK version and the image version to match, to ensure the versions of the software installed on the device and the version of the software the SDK will build against match.
If you are not sure which image is installed on your device, upgrading to the latest stable version is recommended. See the appropriate section for details on upgrading.
Obtaining the right toolchain
To install the toolchain you downloaded type:
$ ./oecore-x86_64-armv7ahf-vfp-neon-toolchain-nodistro.0.sh
This will prompt you for an installation path. Please ensure you have sufficient disk space, as each of the SDKs may require several gigabytes of disk space (depends on the image flavor selected).
Usage
$ . <yoursdkinstallpath>/environment-setup-armv7ahf-vfp-neon-oe-linux-gnueabi
This will modify the PATH, CC, CXX etc, environment variables and allow you to compile software for your USRP E310 device. To verify all went well you can try:
$ $CC -dumpmachine
Building UHD
The E310 comes with UHD already installed on the SD card. You will only need to build UHD and install it if there is a critical bug fix in a later UHD or you have custom UHD modifications.
  2. Setup your environment as described in Usage
     $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr -DENABLE_E300=ON -DENABLE_GPSD=ON ..
     $ make
For instructions on building UHD on a PC to interact with your E-Series device, follow these instructions: Building UHD
Building GNU Radio
GNU Radio is already installed on the SD card. You only need to build GNU Radio for the E3XX if you are doing custom GNU Radio development work.
  1. Obtain the gnuradio source code via git.
  2. Setup the environment as described in Usage
$ mkdir build-arm
-DENABLE_GR_DTV=OFF -DENABLE_DOXYGEN=OFF ../
Rebuilding the file system
The file system images are built using OpenEmbedded Core. The repo tool is used to manage the versions of the various layers that supply recipes for building the image. For more documentation see http://www.yoctoproject.org. These notes will show you how to rebuild the files used to create the SD card included with the E310. These instructions assume you have a working knowledge of Linux.
Once you have rebuilt the factory image, you can create your own custom recipes to build file system images for specific application.
  1. Install repo.
    $ curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > repo
    $ chmod a+x repo
    $ sudo mv repo /usr/local/bin
  2. Configure the repo manifest that controls the build.
    $ mkdir e300-oe-build
    $ cd e300-oe-build
    $ repo init -u git://github.com/EttusResearch/e300-manifest.git -b Release-4
  3. Initialize the environment. This will take a little while.
    $ repo sync
    $ TEMPLATECONF=`pwd`/meta-ettus/conf source ./oe-core/oe-init-build-env ./build ./bitbake
    At this point you should review the file in conf/local.conf and make sure path names make sense for your machine.
  4. Build an image. This will take a few hours, especially the first run since it will download all the required sources. (These are saved locally for future builds)
    $ export MACHINE="ettus-e3xx-sg1"
    $ bitbake gnuradio-dev-image
When this completes, the files needed to create the SD card are in tmp-glibc/deploy/images/ettus-e300. Building the file that is written directly to the SD card is covered later in this document.
  1. Build the toolchain.
    $ bitbake -c populate_sdk gnuradio-dev-image
    The sdk is in tmp-glibc/deploy/sdk Note that you can set the MACHINE variable in `local.conf so that you no longer need to set it from the command line.
  2. Building the complete set of E3XX image files and sdk.
There is a script in the meta-ettus BSP layer that builds SD card images for all E3XX series devices and the sdk.
From the build directory run:
$ sh ../meta-ettus/scripts/build-all.sh
When the script finishes, the SD card image files are in ./images and the sdk is in tmp-glibc/deploy/sdk/ .
  1. Using the environment When you log back in, you will need to setup the OpenEmbedded environment again by:
    $ cd e300-oe-build/oe-core
    $ . oe-core/oe-init-build-env ./build ./bitbake
Upgrading / Writing image to sd card
In order to upgrade or reinitialize a sd card for the first time, you can use the 'dd' tool. Make sure that you are using the right block device for your sd card as failing to do so can wipe your hard drive.
Replace <yourimage>.direct with your image file name and <yoursdcard> with your blockdevice e.g. /dev/mmcblk0 or /dev/sdb.
$ sudo dd if=<yourimage>.direct of=/dev/<yoursdcard> bs=1M
Notes: The commands will wipe the entire sd card and reinitialize it. Newer images need a 8GB sd card.
Specifying a Non-standard FPGA Image
Using UHD to load FPGA images
UHD software will automatically select the USRP E310 images from the installed images package. The image selection can be overridden with the fpga device address parameter.
Example device address string representations to specify non-standard image:
$ uhd_usrp_probe --args='fpga=usrp_e310_fpga.bit'
Using JTAG to load FPGA images
The USRP-E Series device features an on-board JTAG connector (see Debugging custom FPGA designs with Xilinx Chipscope) that can be accessed on the PCB of the device. The iMPACT tool in the Xilinx Programming Tools (ISE, iMPACT) package can be used to load an image over the JTAG interface.
If you have iMPACT installed, you can use the impact_jtag_programmer.sh tool to install images. Make sure your e3x0 is powered on and connected to your computer using the internal JTAG connector. Then run the tool:
Change the USRP's IP address
  • to use multiple USRP-E Series devices with the same host computer
  • to set a known IP address into USRP (in case you forgot)
For examples refer to the Network configuration section.
Hardware Notes
Front Panel
USRP E310 Front panel
  • RF A Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend side A
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend side A
  • RF B Group
    • TX/RX LED: Indicates that data is streaming on the TX/RX channel on frontend B
    • RX2 LED: Indicates that data is streaming on the RX2 channel on frontend B
  • PWR: Power switch with integrated status LED, for status description see below.
  • SYNC: Input port for external PPS signal
  • AUDIO: Audio input / output
The status LED in the power switch indicates the power and charge status. It's behavior is firmware version dependent.
  • Version 1 (original E310)
    • Off: Indicates device is off and not charging
    • Solid Red: Indicates device is charging
    • Solid Green: Indicates device is on
    • Fast Blinking Red: Indicates an error code
      • 1 - Low voltage error
      • 2 - Regulator low voltage error
      • 3 - FPGA power error
      • 4 - DRAM power error
      • 5 - 1.8V rail power error
      • 6 - 3.3V rail power error
      • 7 - Daughterboard / TX power error
      • 9 - Temperature error
  • Version 2 (E312 and upgraded E310)
    • Slow Blinking Green: Indicates device is off and charging
    • Fast Blinking Green: Indicates device is on and charging
    • Solid Green: Indicates device is on (and not charging, if E312)
    • Solid Orange: Indicates device is on and discharging
    • Fast Blinking Orange: Indicates device is on, discharging, and charge is below 10% charge
      • 8 - Charger error
      • 9 - Charger temperature error
      • 10 - Battery low error
      • 11 - Fuel Gauge temperature error
      • 12 - Global (case) temperature error
Rear Panel
USRP E310 Rear Panel
  • PWR: Locking connector (Kycon KLDHCX-0202-A-LT) for the USRP-E Series power supply
  • 1G ETH: RJ45 port for Ethernet interfaces
  • USB: USB 2.0 Port
  • SERIAL: Micro USB connection for serial uart console
Clock and Time Synchronization
PPS - Pulse Per Second
Internal GPS
Your USRP-E Series device comes with an internal GPS. In order to get a lock on a satellite an external GPS antenna is required. The PPS from the internal GPS can be used to discipline the internal reference clock. This feature is automatically enabled with the time source is set to "gpsdo". Again, keep in mind that the E310 does not have an actual GPS-disciplined oscillator (GPSDO) on the board, the value "gpsdo" was named such for better compatibility with code written for other devices.
The device provides a 3.3V supply voltage to an external antenna connected to the GPS port of your device. Note that this supply voltage is turned off in order to safe power upon destruction of the software object.
Inertial Measurement Unit (IMU)
Your USRP-E Series device has an onboard IMU that provides 9 axis (Gyro, Accelerometer and compass) functionality.
The USRP-E Series images ship with several example applications based on RTIMULib that allow the user to explore the basic functionality of the IMU as well as to calibrate it.
To test the accelerometer, run:
$ RTIMULibDrive
This will print the current accelerometer values on the console.
To launch the IMU calibration procedure, run:
$ RTIMULibCal
and follow the onscreen instructions. Please note that magnetometer calibration is important to obtain sensible results if the IMU is to be used in sensor fusion applications.
Using X11 forwarding over SSH (see Frequently Asked Questions) a complete sensor fusion application can be run over SSH from a host computer by typing:
$ RTIMULibDemo
This should open a graphical window on the host computer that displays the various outputs of the IMU, as well as quaternion measurements based on different sensor fusion algorithms.
RTIMULibDemo
For more advanced IMU based applications please refer to the RTIMULib repository as well as the datasheets.
Internal GPIO
Connector
E3xx GPIO Connector
Pin Mapping
  • Pin 1: +3.3V
  • Pin 2: Reserved
  • Pin 3: Data[5]
  • Pin 4: Reserved
  • Pin 5: Data[4]
  • Pin 6: Data[0]
  • Pin 7: Data[3]
  • Pin 8: Data[1]
  • Pin 9: 0V
  • Pin 10: Data[2]
Audio connectors (if populated)
The E3x0 2.5 mm Audio Jack TRRS pins are assigned as follows: Tip=Mic, Ring1=Right, Ring2=Left, Sleeve=GND.
Audio Jack
The Left/Right audio outputs are compatible with typical low-impedance headphones (16 to 32 Ohms). The Microphone pin provides approximately 2 mA bias at 2.2 V when not suspended. A variety of pin configurations can be found on commonly available headsets, so an adapter may be required.
Connector
E3xx JTAG Connector
Pin Mapping
  • Pin 1: TDO
  • Pin 2: 3.3V
  • Pin 3: TCK
  • Pin 4: TDI
  • Pin 5: 0V
  • Pin 6: TMS
Battery notes
Connector
Battery pack connector
The pins are as follows:
  • Pin 1 (Red): VBat
  • Pin 2 (Black): GND
  • Pin 3 (White): Battery Thermistor
Driver
/sys/class/power_supply/BAT/
and for the charger:
/sys/class/power_supply/AC/
root@ettus-e3xx: cat /sys/class/power_supply/BAT/status
SUBSYSTEM=="power_supply", ATTR{online}=="1", ATTR{temp}=="730", RUN+="/sbin/shutdown -h now"
Another example will cause a safe shutdown once the battery level reaches 5 percent
SUBSYSTEM=="power_supply", ATTR{online}=="1", ATTR{status}=="Discharging", ATTR{capacity}=="5", RUN+="/sbin/shutdown -h now"
Calibration Procedure
  1. Completely discharge battery (e.g. by booting up without SD card, so OS doesn't autoshutdown)
  2. Unplug the battery pack and external power
  3. Reconnect the battery pack
  4. Reconnect AC power and charge until charge completed.
  1. Completely charge battery
  2. Type:
    $ echo 3200000 > /sys/class/power_supply/BAT/charge_now
  3. Unplug AC power
  4. Replug AC power and wait until charge completes
Daughterboard notes
E310 MIMO XCVR board
Frontend tuning
Frontend gain
Frontend LO lock status
// assumes 'usrp' is a valid uhd::usrp::multi_usrp::sptr instance
// get status for rx frontend
usrp->get_rx_sensor("lo-locked");
// get status for tx frontend
usrp->get_tx_sensor("lo-locked");
Frontend Filter and Antenna Switches
Source code related to controlling the filter band and antenna switches resides in e300_impl.c. Specifically, refer to methods e300_impl::_update_bandsel, e300_impl::_update_atrs, e300_impl::_update_gpio, and e300_impl::_update_enables. Generally, these methods set the switches depending on the state of transmit and receive streams.
Frontend Side A Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX2_V1,V2 VCRX2_V1,V2 RX2_BANDSEL[2:0] RX2B_BANDSEL[1:0] RX2C_BANDSEL[1:0]
TRX-A < 450 01 10 101 XX 01
TRX-A 450 – 700 01 10 011 XX 11
TRX-A 700 – 1200 01 10 001 XX 10
TRX-A 1200 – 1800 01 10 000 01 XX
TRX-A 1800 – 2350 01 10 010 11 XX
TRX-A 2350 – 2600 01 10 100 10 XX
TRX-A 2600 – 6000 01 01 XXX XX XX
RX2-A 70 – 450 TT 01 101 XX 01
RX2-A 450 – 700 TT 01 011 XX 11
RX2-A 700 – 1200 TT 01 001 XX 10
RX2-A 1200 – 1800 TT 01 000 01 XX
RX2-A 1800 – 2350 TT 01 010 11 XX
RX2-A 2350 – 2600 TT 01 100 10 XX
RX2-A >= 2600 TT 10 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX2_V1,V2 TX_ENABLE2A,2B TX_BANDSEL[2:0]
TRX-A < 117.7 10 01 111
TRX-A 117.7 – 178.2 10 01 110
TRX-A 178.2 – 284.3 10 01 101
TRX-A 284.3 – 453.7 10 01 100
TRX-A 453.7 – 723.8 10 01 011
TRX-A 723.8 – 1154.9 10 01 010
TRX-A 1154.9 – 1842.6 10 01 001
TRX-A 1842.6 – 2940.0 10 01 000
TRX-A >= 2940.0 11 10 XXX
Frontend Side B Filter and Antenna Switches
Receive
RX Port RX Filter (MHz) VCTXRX1_V1,V2 VCRX1_V1,V2 RX1_BANDSEL[2:0] RX1B_BANDSEL[1:0] RX1C_BANDSEL[1:0]
TRX-B < 450 10 01 100 XX 10
TRX-B 450 – 700 10 01 010 XX 11
TRX-B 700 – 1200 10 01 000 XX 01
TRX-B 1200 – 1800 10 01 001 10 XX
TRX-B 1800 – 2350 10 01 011 11 XX
TRX-B 2350 – 2600 10 01 101 01 XX
TRX-B 2600 – 6000 10 10 XXX XX XX
RX2-B 70 – 450 TT 01 100 XX 10
RX2-B 450 – 700 TT 01 010 XX 11
RX2-B 700 – 1200 TT 01 000 XX 01
RX2-B 1200 – 1800 TT 01 001 10 XX
RX2-B 1800 – 2350 TT 01 011 11 XX
RX2-B 2350 – 2600 TT 01 101 01 XX
RX2-B >= 2600 TT 10 XXX XX XX
Transmit
TX Port TX Filter (MHz) VCTXRX1_V1,V2 TX_ENABLE1A,1B TX1_BANDSEL[2:0]
TRX-B < 117.7 00 01 111
TRX-B 117.7 – 178.2 00 01 110
TRX-B 178.2 – 284.3 00 01 101
TRX-B 284.3 – 453.7 00 01 100
TRX-B 453.7 – 723.8 00 01 011
TRX-B 723.8 – 1154.9 00 01 010
TRX-B 1154.9 – 1842.6 00 01 001
TRX-B 1842.6 – 2940.0 00 01 000
TRX-B >= 2940.0 11 10 XXX
Your USRP E3XX Series device can be configured by editing the /etc/network/interfaces.
The device defaults to DHCP, meaning it will query the local network's DHCP server for an address.
DHCP
The default configuration should look similar to, instructing your device to query local DHCP servers for an IP address, gateway, etc.
auto eth0
iface eth0 inet dhcp
In order to change the hostname used to obtain an IP address via DHCP change
/etc/hostname
and edit:
auto eth0
hostname your-hostname
Note: In rare occasions it might be necessary to increase the timeout value for the dhcp client running on the device in order for autoconfiguration to succeed.
In order to increase the timeout to e.g. 40 seconds edit:
auto eth0
udhcpc_opts -t 40
Static IP
To configure a static IP address edit
to look like
auto eth0
iface eth0 inet static
address your-ip
netmask your-netmask
gateway your-gateway
Miscellaneous
Multiple RX channels
There are two complete DDC and DUC DSP chains in the FPGA. In the single channel case, only one chain is ever used. To receive / transmit from both channels, the user must set the RX or TX subdevice specification.
In the following example, a E310 MIMO XCVR is installed. Channel 0 is sourced from subdevice A, and channel 1 is sourced from subdevice B
usrp->set_rx_subdev_spec("A:A A:B");
Available Sensors
The following sensors are available for the USRP-E Series motherboards; they can be queried through the API.
  • fe_locked - rx / tx frontend PLL locked
  • temp - processor temperature value
  • gps_time and gps_locked sensors are added when the GPS is found
Network Mode
Your USRP-E series device can be used in network mode for narrow band signal observation, evaluation and debugging purposes. See the instructions below for how to use network mode.
Please note that when compared with normal operation as a standalone device the usable bandwidth is limited and therefore Network Mode is not the recommended mode of operation.
Building UHD
To work with your E-Series device in network mode, you will need to build UHD on your PC with extra CMake flags. Assuming you are in the host/build directory, see below:
    $ cmake -DENABLE_E300=ON -DE300_FORCE_NETWORK=ON ..
    $ make
Once UHD is installed on your device, it will be able to interact with an E-Series device with network mode active (see below).
Activating Network Mode on the Device
In order to use the device in network mode it is necessary to start the usrp_e3x0_network_mode executable on the device. In order to start the executable please log into your device either via SSH or serial console(see First boot) and type
$ usrp_e3x0_network_mode
Your device should now be discoverable by your host computer via the usual UHD tools. If you are having trouble communicating with your device see the Communication Problems section.
Addressing the Device
Single device configuration
In a single-device configuration, the USRP device must have a unique IPv4 address on the host computer. The USRP can be identified through its IPv4 address or resolvable hostname. See the application notes on Device Identification. Use this addressing scheme with the uhd::usrp::multi_usrp interface (not a typo!).
Example device address string representation for a USRP-E Series device with IPv4 address 192.168.10.2:
addr=192.168.10.2
Multiple device configuration
Booting from a NFS root
Booting your device from a NFS root might be desirable for remote deployment, management or similar applications.
Requirements:
  • NFS server (for configuration see your Linux distribution's documentation)
  • dtc (devicetree compiler)
  • Filesystem image
Extracting the filesystems
The first step to make a root filesystem available via NFS is to extract the root file system. This can be done as follows:
$ sfdisk -l -uS <your-image>.direct
Which should produce output similar to:
Disk release3-image.direct: 7 GiB, 7516197888 bytes, 14680074 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x8bc3587b
Device                 Boot Start      End  Sectors Size Id Type
release3-image.direct1 *        8    36871    36864  18M  c W95 FAT32 (LBA)
release3-image.direct2      36872 14680071 14643200   7G 83 Linux
From this one can see the second partition (root filesystem) starts at sector 36872, and has a length of 14680071. We can use the dd tool to extract the root filesystem into a handy file.
$ dd if=<yourimage>.direct of=<yourimage_rootfs>.direct offset=36872 count=14643200
The same procedure can be done for the boot partition.
$ dd if=<yourimage>.direct of=<yourimage_boot>.direct offset=8 count=36864
Both of these files are mountable on your NFS server, e.g. by:
$ mount <yourimage_rootfs>.direct /srv/nfs/root-e3xx
$ mount <yourimage_rootfs>.direct /srv/nfs/root-e3xx/media/FAT
Copy the uImage, uEnv.txt, u-boot.img, boot.bin from the extracted boot partition to the boot partition of your device's card.
Use the devicetree compiler to modify e300-devicetree.dtb file as follows:
$ dtc -I dtb -O dts e300-devicetree.dtb -o e300-devicetree.dts
Using your editor of choice modify the chosen property in e300-devicetree.dts from:
console=ttyPS0,115200 root=/dev/mmc0blkp2 rw rootwait earlyprintk
to:
console=ttyPS0,115200 root=/dev/nfs rw nfsroot=<yourserverip>:<yourpath>,vers=3 rootwait ip=dhcp earlyprintk
Use the devicetree compiler to compile the modified devicetree as follows:
$ dtc e300-devicetree.dts -o e300-devicetree.dtb
Copy the modified e300-devicetree.dtb to your device's card.
For more information on server configuration please refer to your Linux distribution's NFS Server manual, for more information about NFS root see the Linux Kernel NFS Root documentation
Firewall issues
Ping the device
ping 192.168.10.2
Observe Ethernet port LEDs
  • Communication
    1. How do I enable X forwarding so I can run X apps on the E3x0?
      In the file /etc/ssh/sshd_config, uncomment the line #X11Forwarding no and change "no" to "yes".
  • Firmware
    1. With Firmware 2.0 the device no longer turns on when AC power is plugged.
      This setting can be adjusted via /sys/devices/axi_pmu.3/autoboot.
      Using $ echo 1 > /sys/devices/axi_pmu.3/autoboot autoboot is turned on.
      Using $ echo 0 > /sys/devices/axi_pmu.3/autoboot autoboot is turned off.
      Note that the path above is subject to change depending on device tree changes.
Applications
GSM Base Station
OpenBTS allows the USRP E310 to serve as a GSM base station capable of providing voice and messaging services to standard GSM handsets. General information on the OpenBTS project can be found at the official webpage.
http://www.openbts.org
Special instructions to install OpenBTS on the E310 can be found on the OpenBTS wiki.
http://openbts.org/w/index.php/E3x0
