#include <uhd/rfnoc/graph.hpp>
◆ sptr
◆ connect() [1/2]
| virtual void uhd::rfnoc::graph::connect |
const block_id_t & |
src_block, |
size_t |
src_block_port, |
dst_block, |
size_t |
dst_block_port, |
const size_t |
pkt_size = 0 |
Connect a RFNOC block with block ID src_block to another with block ID dst_block.
This will:
- Check if this connection is valid (IO signatures, see if types match)
- Configure the flow control for the blocks
- Configure SID for the upstream block
- Register the upstream block in the downstream block
◆ connect() [2/2]
src_block, |
dst_block |
Shorthand for connect().
Using default ports for both source and destination.
◆ get_name()
| virtual std::string uhd::rfnoc::graph::get_name |
const |
