#include <uhd/utils/msg_task.hpp>
◆ msg_payload_t
◆ msg_type_t
◆ task_fcn_type
◆ ~msg_task()
          | virtual uhd::msg_task::~msg_task  |
          void  |
pure virtual   |
◆ buff_to_vector()
          | static UHD_INLINE std::vector<boost::uint8_t> uhd::msg_task::buff_to_vector  |
          boost::uint8_t *  |
          p,  |
          size_t  |
          n  |
inlinestatic   |
◆ get_msg_from_dump_queue()
          | virtual msg_payload_t uhd::msg_task::get_msg_from_dump_queue  |
          boost::uint32_t  |
          sid | ) |
pure virtual   |
◆ make()
- The blocking call is interruptible.
- The task polls the interrupt condition.
- Parameters
    | task_fcn | the task callback function  |
- Returns
 - a new task object
