All defined R&D test procedures are listed here. These tests are meant as a tool for Ettus R&D to enable faster and more reliable development. Note these tests are no replacement for manufacturing or production tests, and should not be treated as such. Instead, they are meant to catch common failure modes during development. As a result, test definitions are fairly light-weight.
tbd
| Test Code | Device | Peripherals | Manual Test Procedure | Automatic Test Procedure |
| GPS-X310-TCXO-v1 | USRP X310 | Jackson Labs TCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
| GPS-X310-OCXO-v1 | USRP X310 | Jackson Labs OCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
| GPS-X300-TCXO-v1 | USRP X300 | Jackson Labs TCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
| GPS-X300-OCXO-v1 | USRP X300 | Jackson Labs OCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
| GPS-B200-TCXO-v1 | USRP B200 | Jackson Labs TCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
| GPS-B210-TCXO-v1 | USRP B210 | Jackson Labs TCXO | GPSDO: Manual Test Procedure | GPSDO: Automatic Test Procedure |
For cursory testing, not all tests within a device family are required (e.g., only testing the OCXO on any X-Series, and testing the TCXO on any B-Series is sufficient).
The following tests are recommended for a minimum test (N stands for the latest version of this test):
All of these tests require a device that is GPSDO capable (e.g., X3x0, B2x0, N2x0). For those devices that have a separate GPS component (such as the Jackson Labs GPSDOs), this component is also required (called the "peripheral" in the following).
uhd_usrp_probe on the device and verify that the lack of GPSDO is correctly reported. No warning or error must be printed.uhd_usrp_probe and verify that the GPSDO is correctly reported. Power down the device before connecting the peripheral. The GPSDO must be reported found, and no error or warning must be printed.query_gpsdo_sensors. To pass, it must report the GPSDO as found, lock to the external reference, but then report not being locked to GPS. The tool will report a valid GPS time, and a string such as "GPS and UHD Device time are aligned" in case of success.query_gpsdo_sensors within 20 minutes of connecting the antenna. The tool query_gpsdo_sensors will print a string such as "GPS Locked" in case of success.All of these tests must pass for a 'pass' validation.
tbd
Tests can be added any time to define procedures for pass/fail validation. Any test must include the following:
GPS-X310-OCXO-v1 is a GPS-related test, requires an X310 and an OCXO to run, and is version 1 of this test.Basic understanding of the operation of USRPs by the test operator should be assumed when authoring test procedures. The descriptions should be as short as possible to fully describe, unambiguously, how to reach a pass/fail conclusion.
Test procedures may be updated at any time. If this happens, a new test code must be generated, with the version number increased. Old test codes are considered deprecated (if there exists a version 2 of a test, version 1 should not be run any more).
