serial.hpp
18 #ifndef INCLUDED_UHD_TYPES_SERIAL_HPP
19 #define INCLUDED_UHD_TYPES_SERIAL_HPP
22 #include <boost/shared_ptr.hpp>
23 #include <stdint.h>
24 #include <vector>
25
26 namespace uhd{
27
31  typedef std::vector<uint8_t> byte_vector_t;
32
46  public:
47  typedef boost::shared_ptr<i2c_iface> sptr;
48
49  virtual ~i2c_iface(void);
50
52  i2c_iface::sptr eeprom16(void);
53
59  virtual void write_i2c(
60  uint16_t addr,
61  const byte_vector_t &buf
62  ) = 0;
63
70  virtual byte_vector_t read_i2c(
71  uint16_t addr,
72  size_t num_bytes
73  ) = 0;
74
81  virtual void write_eeprom(
82  uint16_t addr,
83  uint16_t offset,
84  const byte_vector_t &buf
85  );
86
94  virtual byte_vector_t read_eeprom(
95  uint16_t addr,
96  uint16_t offset,
97  size_t num_bytes
98  );
99  };
100
110  enum edge_t{
111  EDGE_RISE = 'r',
112  EDGE_FALL = 'f'
113  };
114
117
120
123
125  size_t divider;
126
131  spi_config_t(edge_t edge = EDGE_RISE);
132  };
133
139  public:
140  typedef boost::shared_ptr<spi_iface> sptr;
141
142  virtual ~spi_iface(void);
143
153  virtual uint32_t transact_spi(
154  int which_slave,
155  const spi_config_t &config,
156  uint32_t data,
157  size_t num_bits,
158  bool readback
159  ) = 0;
160
169  virtual uint32_t read_spi(
170  int which_slave,
171  const spi_config_t &config,
172  uint32_t data,
173  size_t num_bits
174  );
175
183  virtual void write_spi(
184  int which_slave,
185  const spi_config_t &config,
186  uint32_t data,
187  size_t num_bits
188  );
189  };
190
195  public:
196  typedef boost::shared_ptr<uart_iface> sptr;
197
198  virtual ~uart_iface(void);
199
204  virtual void write_uart(const std::string &buf) = 0;
205
211  virtual std::string read_uart(double timeout) = 0;
212  };
213
214 } //namespace uhd
215
216 #endif /* INCLUDED_UHD_TYPES_SERIAL_HPP */
size_t divider
Optionally set the SPI clock divider for this transaction.
Definition: serial.hpp:125
Definition: serial.hpp:138
Definition: serial.hpp:45
bool use_custom_divider
Set the clock speed for this transaction.
Definition: serial.hpp:122
edge_t mosi_edge
on what edge is the mosi data valid?
Definition: serial.hpp:116
Definition: build_info.hpp:25
Definition: serial.hpp:105
boost::shared_ptr< spi_iface > sptr
Definition: serial.hpp:140
Definition: config.h:73
edge_t miso_edge
on what edge is the miso data valid?
Definition: serial.hpp:119
Definition: serial.hpp:194
Definition: serial.hpp:196
edge_t
Definition: serial.hpp:110
boost::shared_ptr< i2c_iface > sptr
Definition: serial.hpp:47
Definition: byte_vector.hpp:33
