uhd::spi_iface Class Referenceabstract
typedef boost::shared_ptr< spi_ifacesptr
virtual ~spi_iface (void)
virtual uint32_t transact_spi (int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits, bool readback)=0
virtual uint32_t read_spi (int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
virtual void write_spi (int which_slave, const spi_config_t &config, uint32_t data, size_t num_bits)
typedef boost::shared_ptr<spi_iface> uhd::spi_iface::sptr
◆ ~spi_iface()
virtual uhd::spi_iface::~spi_iface ( void  )
virtual
◆ read_spi()
virtual uint32_t uhd::spi_iface::read_spi ( int  which_slave,
const spi_config_t config,
uint32_t  data,
size_t  num_bits
virtual
Read from the SPI bus.
which_slavethe slave device number
configspi config args
datathe bits to write out (be sure to set write bit)
num_bitshow many bits in data
spi data
◆ transact_spi()
virtual uint32_t uhd::spi_iface::transact_spi ( int  which_slave,
uint32_t  data,
size_t  num_bits,
bool  readback
Perform a spi transaction.
readbacktrue to readback a value
spi data if readback set
◆ write_spi()
virtual void uhd::spi_iface::write_spi ( int  which_slave,
uint32_t  data,
size_t  num_bits
virtual
Write to the SPI bus.
