#include <uhd/cal/power_container.hpp>
 Public Types | |
| typedef boost::shared_ptr< power_container > | sptr |
  Public Types inherited from uhd::cal::cal_container< std::vector< double >, double > | |
| typedef std::map< std::vector< double >, double > | container_t |
| typedef boost::archive::text_iarchive | iarchive_type |
| typedef boost::archive::text_oarchive | oarchive_type |
  Public Types inherited from uhd::cal::base_container | |
| typedef std::map< std::string, std::string > | metadata_t |
| typedef boost::shared_ptr< base_container > | sptr |
| virtual double | get (const std::vector< double > &args)=0 |
| virtual void | add (const double output, const std::vector< double > &args)=0 |
| virtual void | add_metadata (const metadata_t &data)=0 |
| virtual const metadata_t & | get_metadata ()=0 |
| static sptr | make () |
  Protected Member Functions inherited from uhd::cal::cal_container< std::vector< double >, double > | |
| virtual void | serialize (iarchive_type &ar, const unsigned int)=0 |
| virtual void | serialize (oarchive_type &ar, const unsigned int)=0 |
| typedef boost::shared_ptr<power_container> uhd::cal::power_container::sptr |
Add a data point to the container. This function records a mapping R^n -> R between an input vector and output scalar. For example, a mapping might be (power level, frequency, temperature) -> gain.
| output | the output of the data point mapping |
| args | input values |
Implements uhd::cal::cal_container< std::vector< double >, double >.
Associate some metadata with the container.
| data | a map of metadata (string -> string). |
Get the mapping from an input to an output from the calibration container.
| uhd::assertion_error | if the number of input values are incorrect for the container type |
Retrieve metadata from the container.
Create a container for data related to power calibration.
