8 #ifndef INCLUDED_UHD_USRP_MULTI_USRP_HPP     9 #define INCLUDED_UHD_USRP_MULTI_USRP_HPP    12 #define UHD_USRP_MULTI_USRP_REF_SOURCES_API    13 #define UHD_USRP_MULTI_USRP_GET_RATES_API    14 #define UHD_USRP_MULTI_USRP_FRONTEND_CAL_API    15 #define UHD_USRP_MULTI_USRP_FRONTEND_IQ_AUTO_API    16 #define UHD_USRP_MULTI_USRP_COMMAND_TIME_API    17 #define UHD_USRP_MULTI_USRP_BW_RANGE_API    18 #define UHD_USRP_MULTI_USRP_USER_REGS_API    19 #define UHD_USRP_MULTI_USRP_GET_USRP_INFO_API    20 #define UHD_USRP_MULTI_USRP_NORMALIZED_GAIN    21 #define UHD_USRP_MULTI_USRP_GPIO_API    22 #define UHD_USRP_MULTI_USRP_REGISTER_API    23 #define UHD_USRP_MULTI_USRP_FILTER_API    24 #define UHD_USRP_MULTI_USRP_LO_CONFIG_API    37 #include <boost/shared_ptr.hpp>    38 #include <boost/utility.hpp>    43 namespace uhd{
namespace usrp{
    93     typedef boost::shared_ptr<multi_usrp>
sptr;
    98     static const size_t ALL_MBOARDS = size_t(~0);
   101     static const size_t ALL_CHANS = size_t(~0);
   175     virtual void set_master_clock_rate(
double rate,
size_t mboard = ALL_MBOARDS) = 0;
   182     virtual double get_master_clock_rate(
size_t mboard = 0) = 0;
   188     virtual std::string get_pp_string(
void) = 0;
   195     virtual std::string get_mboard_name(
   202     virtual time_spec_t get_time_now(
   209     virtual time_spec_t get_time_last_pps(
   222     virtual void set_time_now(
const time_spec_t &time_spec,
   236     virtual void set_time_next_pps(
   253     virtual void set_time_unknown_pps(
const time_spec_t &time_spec) = 0;
   261     virtual bool get_time_synchronized(
void) = 0;
   273     virtual void set_command_time(
const uhd::time_spec_t &time_spec,
   280     virtual void clear_command_time(
   294     virtual void issue_stream_cmd(
const stream_cmd_t &stream_cmd,
size_t chan = ALL_CHANS) = 0;
   304     virtual void set_clock_config(
const clock_config_t &clock_config,
   314     virtual void set_time_source(
const std::string &source,
const size_t mboard = ALL_MBOARDS) = 0;
   321     virtual std::string get_time_source(
const size_t mboard) = 0;
   328     virtual std::vector<std::string> get_time_sources(
   337     virtual void set_clock_source(
   344     virtual std::string get_clock_source(
   351     virtual std::vector<std::string> get_clock_sources(
   361     virtual void set_clock_source_out(
const bool enb,
   371     virtual void set_time_source_out(
const bool enb,
   376     virtual size_t get_num_mboards(
void) = 0;
   384     virtual sensor_value_t get_mboard_sensor(
const std::string &name,
   391     virtual std::vector<std::string> get_mboard_sensor_names(
   400     virtual void set_user_register(
const uint8_t addr,
const uint32_t data,
   427     virtual size_t get_rx_num_channels(
void) = 0;
   434     virtual std::string get_rx_subdev_name(
size_t chan = 0) = 0;
   441     virtual void set_rx_rate(
double rate,
   448     virtual double get_rx_rate(
   472     virtual double get_rx_freq(
   483     virtual freq_range_t get_rx_freq_range(
   490     virtual freq_range_t get_fe_rx_freq_range(
   508     virtual std::vector<std::string> get_rx_lo_names(
   521     virtual void set_rx_lo_source(
   522             const std::string &src,
   523             const std::string &name = ALL_LOS,
   535     virtual const std::string get_rx_lo_source(
   536             const std::string &name = ALL_LOS,
   551     virtual std::vector<std::string> get_rx_lo_sources(
   552             const std::string &name = ALL_LOS,
   566     virtual void set_rx_lo_export_enabled(
   568             const std::string &name = ALL_LOS,
   577     virtual bool get_rx_lo_export_enabled(
   578             const std::string &name = ALL_LOS,
   605     virtual double set_rx_lo_freq(
   607             const std::string &name,
   621     virtual double get_rx_lo_freq(
   622             const std::string &name,
   636             const std::string &name,
   652     virtual std::vector<std::string> get_tx_lo_names(
   665     virtual void set_tx_lo_source(
   666             const std::string &src,
   667             const std::string &name = ALL_LOS,
   668             const size_t chan = 0
   679     virtual const std::string get_tx_lo_source(
   680             const std::string &name = ALL_LOS,
   681             const size_t chan = 0
   694     virtual std::vector<std::string> get_tx_lo_sources(
   695             const std::string &name = ALL_LOS,
   696             const size_t chan = 0
   709     virtual void set_tx_lo_export_enabled(
   711             const std::string &name = ALL_LOS,
   712             const size_t chan = 0
   720     virtual bool get_tx_lo_export_enabled(
   721             const std::string &name = ALL_LOS,
   722             const size_t chan = 0
   748     virtual double set_tx_lo_freq(
   750             const std::string &name,
   764     virtual double get_tx_lo_freq(
   765             const std::string &name,
   779             const std::string &name,
   793     virtual void set_rx_gain(
double gain,
   807     virtual std::vector<std::string> get_rx_gain_profile_names(
const size_t chan = 0) = 0;
   814     virtual void set_rx_gain_profile(
const std::string& profile,
   821     virtual std::string get_rx_gain_profile(
   825         return this->set_rx_gain(gain, ALL_GAINS, chan);
   844     virtual void set_normalized_rx_gain(
double gain,
   854     virtual void set_rx_agc(
bool enable,
   863     virtual double get_rx_gain(
   867         return this->get_rx_gain(ALL_GAINS, chan);
   880     virtual double get_normalized_rx_gain(
   889     virtual gain_range_t get_rx_gain_range(
   893         return this->get_rx_gain_range(ALL_GAINS, chan);
   902     virtual std::vector<std::string> get_rx_gain_names(
   909     virtual void set_rx_antenna(
const std::string &ant,
   916     virtual std::string get_rx_antenna(
   923     virtual std::vector<std::string> get_rx_antennas(
   930     virtual void set_rx_bandwidth(
double bandwidth,
   937     virtual double get_rx_bandwidth(
   944     virtual meta_range_t get_rx_bandwidth_range(
   961     virtual sensor_value_t get_rx_sensor(
   968     virtual std::vector<std::string> get_rx_sensor_names(
   982     virtual void set_rx_dc_offset(
const bool enb,
   991     virtual void set_rx_dc_offset(
const std::complex<double> &offset,
   999     virtual void set_rx_iq_balance(
const bool enb,
size_t chan) = 0;
  1008     virtual void set_rx_iq_balance(
const std::complex<double> &correction,
  1035     virtual size_t get_tx_num_channels(
void) = 0;
  1042     virtual std::string get_tx_subdev_name(
  1049     virtual void set_tx_rate(
double rate,
  1056     virtual double get_tx_rate(
  1063     virtual meta_range_t get_tx_rates(
  1080     virtual double get_tx_freq(
  1091     virtual freq_range_t get_tx_freq_range(
  1098     virtual freq_range_t get_fe_tx_freq_range(
  1107     virtual void set_tx_gain(
double gain,
  1121     virtual std::vector<std::string> get_tx_gain_profile_names(
  1128     virtual void set_tx_gain_profile(
  1135     virtual std::string get_tx_gain_profile(
  1139         return this->set_tx_gain(gain, ALL_GAINS, chan);
  1152     virtual void set_normalized_tx_gain(
double gain,
  1161     virtual double get_tx_gain(
  1165         return this->get_tx_gain(ALL_GAINS, chan);
  1178     virtual double get_normalized_tx_gain(
  1187     virtual gain_range_t get_tx_gain_range(
  1191         return this->get_tx_gain_range(ALL_GAINS, chan);
  1200     virtual std::vector<std::string> get_tx_gain_names(
  1207     virtual void set_tx_antenna(
  1214     virtual std::string get_tx_antenna(
  1221     virtual std::vector<std::string> get_tx_antennas(
  1228     virtual void set_tx_bandwidth(
double bandwidth,
  1235     virtual double get_tx_bandwidth(
  1242     virtual meta_range_t get_tx_bandwidth_range(
  1259     virtual sensor_value_t get_tx_sensor(
  1266     virtual std::vector<std::string> get_tx_sensor_names(
  1274     virtual void set_tx_dc_offset(
  1283     virtual void set_tx_iq_balance(
  1294     virtual std::vector<std::string> get_gpio_banks(
  1312     virtual void set_gpio_attr(
const std::string &bank,
const std::string &attr,
const uint32_t value,
const uint32_t
mask = 0xffffffff,
const size_t mboard = 0) = 0;
  1339     virtual void set_gpio_attr(
const std::string &value,
const uint32_t
mask = 0xffffffff,
  1357     virtual uint32_t get_gpio_attr(
  1384     virtual std::vector<std::string> get_gpio_string_attr(
  1400     virtual std::vector<std::string> enumerate_registers(
  1408     virtual register_info_t get_register_info(
const std::string &path,
  1417     virtual void write_register(
const uint32_t field,
const uint64_t value,
  1426     virtual uint64_t read_register(
  1442     virtual std::vector<std::string> get_filter_names(
const std::string &search_mask =
"") = 0;
Definition: multi_usrp.hpp:892
Definition: stream_cmd.hpp:36
Definition: tune_result.hpp:19
Definition: multi_usrp.hpp:1164
Definition: multi_usrp.hpp:1138
Definition: time_spec.hpp:29
bool readable
Definition: multi_usrp.hpp:1391
Definition: device.hpp:31
boost::shared_ptr< multi_usrp > sptr
Definition: multi_usrp.hpp:93
Definition: multi_usrp.hpp:1389
Definition: multi_usrp.hpp:866
Definition: tune_request.hpp:23
Definition: stream.hpp:161
static const std::string ALL_GAINS
A wildcard gain element name.
Definition: multi_usrp.hpp:104
Definition: build_info.hpp:14
Definition: sensors.hpp:29
boost::shared_ptr< filter_info_base > sptr
Definition: filters.hpp:28
Definition: clock_config.hpp:26
Definition: multi_usrp.hpp:91
Definition: stream.hpp:47
Definition: config.h:63
Definition: soft_register.hpp:87
Definition: dboard_iface.hpp:54
Definition: multi_usrp.hpp:824
static const std::string ALL_LOS
A wildcard LO stage name.
Definition: multi_usrp.hpp:107
Definition: subdev_spec.hpp:62
bool writable
Definition: multi_usrp.hpp:1392
size_t bitwidth
Definition: multi_usrp.hpp:1390
Definition: stream.hpp:237
Definition: multi_usrp.hpp:1190
Definition: device_addr.hpp:37
