 Classes | |
| struct | register_info_t |
Public Types | |
| typedef boost::shared_ptr< multi_usrp > | sptr |
| virtual | ~multi_usrp (void)=0 |
| virtual device::sptr | get_device (void)=0 |
| virtual rx_streamer::sptr | get_rx_stream (const stream_args_t &args)=0 |
| Convenience method to get a RX streamer. See also uhd::device::get_rx_stream().  More... | |
| virtual tx_streamer::sptr | get_tx_stream (const stream_args_t &args)=0 |
| Convenience method to get a TX streamer. See also uhd::device::get_rx_stream().  More... | |
| virtual dict< std::string, std::string > | get_usrp_rx_info (size_t chan=0)=0 |
| virtual dict< std::string, std::string > | get_usrp_tx_info (size_t chan=0)=0 |
| virtual void | set_master_clock_rate (double rate, size_t mboard=ALL_MBOARDS)=0 |
| virtual double | get_master_clock_rate (size_t mboard=0)=0 |
| virtual std::string | get_pp_string (void)=0 |
| virtual std::string | get_mboard_name (size_t mboard=0)=0 |
| virtual time_spec_t | get_time_now (size_t mboard=0)=0 |
| virtual time_spec_t | get_time_last_pps (size_t mboard=0)=0 |
| virtual void | set_time_now (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_next_pps (const time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_unknown_pps (const time_spec_t &time_spec)=0 |
| virtual bool | get_time_synchronized (void)=0 |
| virtual void | set_command_time (const uhd::time_spec_t &time_spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | clear_command_time (size_t mboard=ALL_MBOARDS)=0 |
| virtual void | issue_stream_cmd (const stream_cmd_t &stream_cmd, size_t chan=ALL_CHANS)=0 |
| virtual void | set_clock_config (const clock_config_t &clock_config, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0 |
| virtual std::string | get_time_source (const size_t mboard)=0 |
| virtual std::vector< std::string > | get_time_sources (const size_t mboard)=0 |
| virtual void | set_clock_source (const std::string &source, const size_t mboard=ALL_MBOARDS)=0 |
| virtual std::string | get_clock_source (const size_t mboard)=0 |
| virtual std::vector< std::string > | get_clock_sources (const size_t mboard)=0 |
| virtual void | set_clock_source_out (const bool enb, const size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_time_source_out (const bool enb, const size_t mboard=ALL_MBOARDS)=0 |
| virtual size_t | get_num_mboards (void)=0 |
| virtual sensor_value_t | get_mboard_sensor (const std::string &name, size_t mboard=0)=0 |
| virtual std::vector< std::string > | get_mboard_sensor_names (size_t mboard=0)=0 |
| virtual void | set_user_register (const uint8_t addr, const uint32_t data, size_t mboard=ALL_MBOARDS)=0 |
| virtual void | set_rx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual uhd::usrp::subdev_spec_t | get_rx_subdev_spec (size_t mboard=0)=0 |
| virtual size_t | get_rx_num_channels (void)=0 |
| virtual std::string | get_rx_subdev_name (size_t chan=0)=0 |
| virtual void | set_rx_rate (double rate, size_t chan=ALL_CHANS)=0 |
| virtual double | get_rx_rate (size_t chan=0)=0 |
| virtual meta_range_t | get_rx_rates (size_t chan=0)=0 |
| virtual tune_result_t | set_rx_freq (const tune_request_t &tune_request, size_t chan=0)=0 |
| virtual double | get_rx_freq (size_t chan=0)=0 |
| virtual freq_range_t | get_rx_freq_range (size_t chan=0)=0 |
| virtual freq_range_t | get_fe_rx_freq_range (size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_lo_names (size_t chan=0)=0 |
| virtual void | set_rx_lo_source (const std::string &src, const std::string &name=ALL_LOS, size_t chan=0)=0 |
| virtual const std::string | get_rx_lo_source (const std::string &name=ALL_LOS, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_lo_sources (const std::string &name=ALL_LOS, size_t chan=0)=0 |
| virtual void | set_rx_lo_export_enabled (bool enabled, const std::string &name=ALL_LOS, size_t chan=0)=0 |
| virtual bool | get_rx_lo_export_enabled (const std::string &name=ALL_LOS, size_t chan=0)=0 |
| virtual double | set_rx_lo_freq (double freq, const std::string &name, size_t chan=0)=0 |
| virtual double | get_rx_lo_freq (const std::string &name, size_t chan=0)=0 |
| virtual freq_range_t | get_rx_lo_freq_range (const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_lo_names (size_t chan=0)=0 |
| virtual void | set_tx_lo_source (const std::string &src, const std::string &name=ALL_LOS, const size_t chan=0)=0 |
| virtual const std::string | get_tx_lo_source (const std::string &name=ALL_LOS, const size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_lo_sources (const std::string &name=ALL_LOS, const size_t chan=0)=0 |
| virtual void | set_tx_lo_export_enabled (const bool enabled, const std::string &name=ALL_LOS, const size_t chan=0)=0 |
| virtual bool | get_tx_lo_export_enabled (const std::string &name=ALL_LOS, const size_t chan=0)=0 |
| virtual double | set_tx_lo_freq (const double freq, const std::string &name, const size_t chan=0)=0 |
| virtual double | get_tx_lo_freq (const std::string &name, const size_t chan=0)=0 |
| virtual freq_range_t | get_tx_lo_freq_range (const std::string &name, const size_t chan=0)=0 |
| virtual void | set_rx_gain (double gain, const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_gain_profile_names (const size_t chan=0)=0 |
| virtual void | set_rx_gain_profile (const std::string &profile, const size_t chan=0)=0 |
| virtual std::string | get_rx_gain_profile (const size_t chan=0)=0 |
| void | set_rx_gain (double gain, size_t chan=0) |
| A convenience wrapper for setting overall RX gain.  More... | |
| virtual void | set_normalized_rx_gain (double gain, size_t chan=0)=0 |
| virtual void | set_rx_agc (bool enable, size_t chan=0)=0 |
| virtual double | get_rx_gain (const std::string &name, size_t chan=0)=0 |
| double | get_rx_gain (size_t chan=0) |
| A convenience wrapper for getting overall RX gain.  More... | |
| virtual double | get_normalized_rx_gain (size_t chan=0)=0 |
| virtual gain_range_t | get_rx_gain_range (const std::string &name, size_t chan=0)=0 |
| gain_range_t | get_rx_gain_range (size_t chan=0) |
| A convenience wrapper for getting overall RX gain range.  More... | |
| virtual std::vector< std::string > | get_rx_gain_names (size_t chan=0)=0 |
| virtual void | set_rx_antenna (const std::string &ant, size_t chan=0)=0 |
| virtual std::string | get_rx_antenna (size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_antennas (size_t chan=0)=0 |
| virtual void | set_rx_bandwidth (double bandwidth, size_t chan=0)=0 |
| virtual double | get_rx_bandwidth (size_t chan=0)=0 |
| virtual meta_range_t | get_rx_bandwidth_range (size_t chan=0)=0 |
| virtual dboard_iface::sptr | get_rx_dboard_iface (size_t chan=0)=0 |
| virtual sensor_value_t | get_rx_sensor (const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_rx_sensor_names (size_t chan=0)=0 |
| virtual void | set_rx_dc_offset (const bool enb, size_t chan=ALL_CHANS)=0 |
| virtual void | set_rx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0 |
| virtual void | set_rx_iq_balance (const bool enb, size_t chan)=0 |
| virtual void | set_rx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0 |
| virtual void | set_tx_subdev_spec (const uhd::usrp::subdev_spec_t &spec, size_t mboard=ALL_MBOARDS)=0 |
| virtual uhd::usrp::subdev_spec_t | get_tx_subdev_spec (size_t mboard=0)=0 |
| virtual size_t | get_tx_num_channels (void)=0 |
| virtual std::string | get_tx_subdev_name (size_t chan=0)=0 |
| virtual void | set_tx_rate (double rate, size_t chan=ALL_CHANS)=0 |
| virtual double | get_tx_rate (size_t chan=0)=0 |
| virtual meta_range_t | get_tx_rates (size_t chan=0)=0 |
| virtual tune_result_t | set_tx_freq (const tune_request_t &tune_request, size_t chan=0)=0 |
| virtual double | get_tx_freq (size_t chan=0)=0 |
| virtual freq_range_t | get_tx_freq_range (size_t chan=0)=0 |
| virtual freq_range_t | get_fe_tx_freq_range (size_t chan=0)=0 |
| virtual void | set_tx_gain (double gain, const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_gain_profile_names (const size_t chan=0)=0 |
| virtual void | set_tx_gain_profile (const std::string &profile, const size_t chan=0)=0 |
| virtual std::string | get_tx_gain_profile (const size_t chan=0)=0 |
| void | set_tx_gain (double gain, size_t chan=0) |
| A convenience wrapper for setting overall TX gain.  More... | |
| virtual void | set_normalized_tx_gain (double gain, size_t chan=0)=0 |
| virtual double | get_tx_gain (const std::string &name, size_t chan=0)=0 |
| double | get_tx_gain (size_t chan=0) |
| A convenience wrapper for getting overall TX gain.  More... | |
| virtual double | get_normalized_tx_gain (size_t chan=0)=0 |
| virtual gain_range_t | get_tx_gain_range (const std::string &name, size_t chan=0)=0 |
| gain_range_t | get_tx_gain_range (size_t chan=0) |
| A convenience wrapper for getting overall TX gain range.  More... | |
| virtual std::vector< std::string > | get_tx_gain_names (size_t chan=0)=0 |
| virtual void | set_tx_antenna (const std::string &ant, size_t chan=0)=0 |
| virtual std::string | get_tx_antenna (size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_antennas (size_t chan=0)=0 |
| virtual void | set_tx_bandwidth (double bandwidth, size_t chan=0)=0 |
| virtual double | get_tx_bandwidth (size_t chan=0)=0 |
| virtual meta_range_t | get_tx_bandwidth_range (size_t chan=0)=0 |
| virtual dboard_iface::sptr | get_tx_dboard_iface (size_t chan=0)=0 |
| virtual sensor_value_t | get_tx_sensor (const std::string &name, size_t chan=0)=0 |
| virtual std::vector< std::string > | get_tx_sensor_names (size_t chan=0)=0 |
| virtual void | set_tx_dc_offset (const std::complex< double > &offset, size_t chan=ALL_CHANS)=0 |
| virtual void | set_tx_iq_balance (const std::complex< double > &correction, size_t chan=ALL_CHANS)=0 |
| virtual std::vector< std::string > | get_gpio_banks (const size_t mboard)=0 |
| virtual void | set_gpio_attr (const std::string &bank, const std::string &attr, const uint32_t value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0 |
| virtual void | set_gpio_attr (const std::string &bank, const std::string &attr, const std::string &value, const uint32_t mask=0xffffffff, const size_t mboard=0)=0 |
| virtual uint32_t | get_gpio_attr (const std::string &bank, const std::string &attr, const size_t mboard=0)=0 |
| virtual std::vector< std::string > | get_gpio_string_attr (const std::string &bank, const std::string &attr, const size_t mboard=0)=0 |
| virtual std::vector< std::string > | enumerate_registers (const size_t mboard=0)=0 |
| virtual register_info_t | get_register_info (const std::string &path, const size_t mboard=0)=0 |
| virtual void | write_register (const std::string &path, const uint32_t field, const uint64_t value, const size_t mboard=0)=0 |
| virtual uint64_t | read_register (const std::string &path, const uint32_t field, const size_t mboard=0)=0 |
| virtual std::vector< std::string > | get_filter_names (const std::string &search_mask="")=0 |
| virtual filter_info_base::sptr | get_filter (const std::string &path)=0 |
| virtual void | set_filter (const std::string &path, filter_info_base::sptr filter)=0 |
| static sptr | make (const device_addr_t &dev_addr) |
| static const size_t | ALL_MBOARDS = size_t(~0) |
| A wildcard motherboard index.  More... | |
| static const size_t | ALL_CHANS = size_t(~0) |
| A wildcard channel index.  More... | |
| static const std::string | ALL_GAINS |
| A wildcard gain element name.  More... | |
| static const std::string | ALL_LOS |
| A wildcard LO stage name.  More... | |
The Multi-USRP device class:
This class facilitates ease-of-use for most use-case scenarios. The wrapper provides convenience functions to tune the devices, set the dboard gains, antennas, filters, and other properties. This class can be used to interface with a single USRP with one or more channels, or multiple USRPs in a homogeneous setup. All members take an optional parameter for board number or channel number. In the single device, single channel case, these parameters can be unspecified.
When using a single device with multiple channels:
When using multiple devices in a configuration:
Example to setup channel mapping for multiple devices:
//create a multi_usrp with two boards in the configuration device_addr_t dev_addr; dev_addr["addr0"] = "192.168.10.2" dev_addr["addr1"] = "192.168.10.3"; multi_usrp::sptr dev = multi_usrp::make(dev_addr);
//set the board on 10.2 to use the A RX frontend (RX channel 0)
dev->set_rx_subdev_spec("A:A", 0);//set the board on 10.3 to use the B RX frontend (RX channel 1)
dev->set_rx_subdev_spec("A:B", 1);//set both boards to use the AB TX frontend (TX channels 0 and 1)
dev->set_tx_subdev_spec("A:AB", multi_usrp::ALL_MBOARDS);//now that all the channels are mapped, continue with configuration...
| typedef boost::shared_ptr<multi_usrp> uhd::usrp::multi_usrp::sptr |
Clear the command time so future commands are sent ASAP.
| mboard | which motherboard to set the config |
Enumerate the full paths of all low-level USRP registers accessible to read/write
| mboard | the motherboard index 0 to M-1 |
Get the currently set clock source.
| mboard | which motherboard to get the config |
Get a list of possible clock sources.
| mboard | which motherboard to get the list |
Get the underlying device object. This is needed to get access to the streaming API and properties.
Get the center frequency range of the RF frontend.
| chan | the channel index 0 to N-1 |
Get the center frequency range of the TX frontend.
Return the filter object for the given name.
| path | the name of the filter as returned from get_filter_names(). |
Enumerate the available filters in the signal path.
| search_mask | Select only certain filter names by specifying this search mask. E.g. if search mask is set to "rx_frontends/A" only filter names including that string will be returned.  |
Get a GPIO attribute on a particular GPIO bank. Possible attribute names:
| bank | the name of a GPIO bank |
| attr | the name of a GPIO attribute |
Enumerate gpio banks on the specified device.
Get the master clock rate.
Get canonical name for this USRP motherboard.
| mboard | which motherboard to query |
Get a motherboard sensor value.
| name | the name of the sensor |
Get a list of possible motherboard sensor names.
Return the normalized RX gain value.
See set_normalized_rx_gain() for a discussion of normalized gains.
| A | uhd::runtime_error if the gain value is outside [0, 1]. |
Return the normalized TX gain value.
Get the number of USRP motherboards in this configuration.
Get more information about a low-level device register
| path | the full path to the register |
Get the selected RX antenna on the frontend.
Get a list of possible RX antennas on the frontend.
Get the RX bandwidth on the frontend.
Get the range of the possible RX bandwidth settings.
Get the dboard interface object for the RX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
Get the RX center frequency.
Get the RX center frequency range. This range includes the overall tunable range of the RX chain, including frontend chain and digital down conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
Get the RX gain value for the specified gain element. For an empty name, sum across all gain elements.
| name | the name of the gain element |
  inline |
Get the names of the gain elements in the RX chain. Gain elements are ordered from antenna to FPGA.
Get the RX gain profile.
Get a list of possible RX gain profile options
Example: On the TwinRX, this will return "low-noise", "low-distortion" or "default". These names can be used in gain-profile related API called. An empty return value doesn't mean there are no profile options, it means that this radio does not have any gain profiles implemented, and typically means there is only one default profile of set gain
Get the RX gain range for the specified gain element. For an empty name, calculate the overall gain range.
  inline |
Returns true if the currently selected LO is being exported.
| name | the name of the LO stage to query |
Get the current RX LO frequency (Advanced).
If the channel does not have independently configurable LOs the current rf frequency will be returned. See also set_rx_lo_freq() for more information.
Get the LO frequency range of the RX LO.
If the channel does not have independently configurable LOs the rf frequency range will be returned.
Get a list of possible LO stage names
Example: On the TwinRX, this will return "LO1", "LO2". These names can are used in other LO-related API calls, so this function can be used for automatically enumerating LO stages. An empty return value doesn't mean there are no LOs, it means that this radio does not have an LO API implemented, and typically means the LOs have no direct way of being controlled other than setting the frequency.
Get the currently selected LO source.
Channels without controllable LO sources will always return "internal".
Get a list of possible LO sources.
Channels which do not have controllable LO sources will return "internal". Typical values are "internal" and "external", although the TwinRX has more options, such as "companion". These options are device- specific.
Get the number of RX channels in this configuration. This is the number of USRPs times the number of RX channels per board, where the number of RX channels per board is homogeneous among all USRPs.
Gets the RX sample rate.
Get a range of possible RX rates.
Get an RX frontend sensor value.
Get a list of possible RX frontend sensor names.
Get the name of the RX frontend.
Get the RX frontend specification.
Get the time when the last pps pulse occurred.
Get the current time in the usrp time registers.
Get the currently set time source.
Get a list of possible time sources.
Are the times across all motherboards in this configuration synchronized? Checks that all time registers are approximately close but not exact, given that the RTT may varying for a control packet transaction.
Get the selected TX antenna on the frontend.
Get a list of possible TX antennas on the frontend.
Get the TX bandwidth on the frontend.
Get the range of the possible TX bandwidth settings.
Get the dboard interface object for the TX frontend. The dboard interface gives access to GPIOs, SPI, I2C, low-speed ADC and DAC. Use at your own risk!
Get the TX center frequency.
Get the TX center frequency range. This range includes the overall tunable range of the TX chain, including frontend chain and digital up conversion chain. This tunable limit does not include the baseband bandwidth; users should assume that the actual range is +/- samp_rate/2.
Get the TX gain value for the specified gain element. For an empty name, sum across all gain elements.
  inline |
Get the names of the gain elements in the TX chain. Gain elements are ordered from antenna to FPGA.
Get the TX gain profile.
Get a list of possible TX gain profile options
Example: On the N310, this will return "manual" or "default". These names can be used in gain related API called. An empty return value doesn't mean there are no profile options, it means that this radio does not have any gain profiles implemented, and typically means there is only one default profile of set gain
Get the TX gain range for the specified gain element. For an empty name, calculate the overall gain range.
  inline |
Get the current TX LO frequency (Advanced).
If the channel does not have independently configurable LOs the current rf frequency will be returned. See also set_tx_lo_freq() for more information.
Get the LO frequency range of the TX LO.
Get a list of possible TX LO stage names
See also get_rx_lo_names().
Get the currently selected TX LO source.
Channels which do not have controllable LO sources will return "internal". Typical values are "internal" and "external". These options are device-specific.
Get the number of TX channels in this configuration. This is the number of USRPs times the number of TX channels per board, where the number of TX channels per board is homogeneous among all USRPs.
Gets the TX sample rate.
Get a range of possible TX rates.
Get an TX frontend sensor value.
Get a list of possible TX frontend sensor names.
Get the name of the TX frontend.
Get the TX frontend specification.
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard RX ID, subdev name and spec, serial, and antenna.
| chan | channel index 0 to N-1 |
Returns identifying information about this USRP's configuration. Returns motherboard ID, name, and serial. Returns daughterboard TX ID, subdev name and spec, serial, and antenna.
| stream_cmd | the stream command to issue |
| dev_addr | the device address |
| uhd::key_error | no device found |
| uhd::index_error | fewer devices found than expected |
Read a low-level register field from a register in the USRP hardware
| field | the identifier of bitfield to be read |
Set the clock configuration for the usrp device. DEPRECATED in favor of set time and clock source calls. This tells the usrp how to get a 10MHz reference and PPS clock. See the documentation for clock_config_t for more info.
| clock_config | the clock configuration to set |
Set the clock source for the usrp device. This sets the source for a 10 MHz reference clock. Typical options for source: internal, external, MIMO.
| source | a string representing the clock source |
Send the clock source to an output connector. This call is only applicable on devices with reference outputs. By default, the reference output will be enabled for ease of use. This call may be used to enable or disable the output.
| enb | true to output the clock source. |
| mboard | which motherboard to set |
Set the time at which the control commands will take effect.
A timed command will back-pressure all subsequent timed commands, assuming that the subsequent commands occur within the time-window. If the time spec is late, the command will be activated upon arrival.
| time_spec | the time at which the next command will activate |
Write back a filter obtained by get_filter() to the signal path. This filter can be a modified version of the originally returned one. The information about Rx or Tx is contained in the path parameter.
| filter | the filter_info_base::sptr of the filter object to be written |
Set a GPIO attribute on a particular GPIO bank. Possible attribute names:
| value | the new value for this GPIO bank |
| mask | the bit mask to effect which pins are changed |
Set the master clock rate.
What exactly this changes is device-dependent, but it will always affect the rate at which the ADC/DAC is running.
Like tuning receive or transmit frequencies, this call will do a best effort to change the master clock rate. The device will coerce to the closest clock rate available, and on many devices won't actually change anything at all. Call get_master_clock_rate() to see which rate was actually applied.
Note that changing this value during streaming is not recommended and can have random side effects.
If the device has an 'auto clock rate' setting (e.g. B200, see also Automatic Clock Rate Setting), calling this function will disable the automatic clock rate selection, and the clock rate will be fixed to rate.
| rate | the new master clock rate in Hz |
Set the normalized RX gain value.
The normalized gain is a value in [0, 1], where 0 is the smallest gain value available, and 1 is the largest, independent of the device. In between, gains are linearly interpolated.
Check the individual device manual for notes on the gain range.
Note that it is not possible to specify a gain name for this function, it will always set the overall gain.
| gain | the normalized gain value |
Set the normalized TX gain value.
See set_normalized_rx_gain() for a discussion on normalized gains.
Enable or disable the RX AGC module. Once this module is enabled manual gain settings will be ignored. The AGC will start in a default configuration which should be good for most use cases. Device specific configuration parameters can be found in the property tree.
| enable | Enable or Disable the AGC |
Select the RX antenna on the frontend.
| ant | the antenna name |
Set the RX bandwidth on the frontend.
| bandwidth | the bandwidth in Hz |
Enable/disable the automatic RX DC offset correction. The automatic correction subtracts out the long-run average.
When disabled, the averaging option operation is halted. Once halted, the average value will be held constant until the user re-enables the automatic correction or overrides the value by manually setting the offset.
| enb | true to enable automatic DC offset correction |
Set a constant RX DC offset value. The value is complex to control both I and Q. Only set this when automatic correction is disabled.
| offset | the dc offset (1.0 is full-scale) |
Set the RX center frequency.
| tune_request | tune request instructions |
Set the RX gain value for the specified gain element. For an empty name, distribute across all gain elements.
| gain | the gain in dB |
  inline |
Set the RX gain profile.
| profile | the profile string option |
Enable/disable the automatic IQ imbalance correction.
| enb | true to enable automatic IQ balance correction |
Set the RX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
| correction | the complex correction (1.0 is full-scale) |
Set whether the LO used by the device is exported
For USRPs that support exportable LOs, this function configures if the LO used by chan is exported or not.
| enabled | if true then export the LO |
| name | the name of the LO stage to update |
| chan | the channel index 0 to N-1 for the source channel |
| uhd::runtime_error | if LO exporting is not enabled |
Set the RX LO frequency (Advanced).
The actual behaviour is device-specific. However, as a rule of thumb, this will coerce the underlying driver into some state. Typical situations include:
| freq | the frequency to set the LO to |
Set the LO source for the USRP device.
For USRPs that support selectable LO sources, this function allows switching between them. Typical options for source: internal, external.
| src | a string representing the LO source |
| name | the name of the LO stage to update. If the wildcard value ALL_LOS is used, the setting will be applied to all LOs on this channel. |
Set the RX sample rate.
| rate | the rate in Sps |
Set the RX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
| spec | the new frontend specification |
Set the time registers on the usrp at the next pps tick. The values will not be latched in until the pulse occurs. It is recommended that the user sleep(1) after calling to ensure that the time registers will be in a known state prior to use.
Note: Because this call sets the time on the "next" pps, the seconds in the time spec should be current seconds + 1.
| time_spec | the time to latch into the usrp device |
Sets the time registers on the usrp immediately.
If only one MIMO master is present in your configuration, set_time_now is safe to use because the slave's time automatically follows the master's time. Otherwise, this call cannot set the time synchronously across multiple devices. Please use the set_time_next_pps or set_time_unknown_pps calls with a PPS signal.
Set the time source for the usrp device. This sets the method of time synchronization, typically a pulse per second or an encoded time. Typical options for source: external, MIMO.
| source | a string representing the time source |
Send the time source to an output connector. This call is only applicable on devices with PPS outputs. By default, the PPS output will be enabled for ease of use. This call may be used to enable or disable the output.
| enb | true to output the time source. |
Synchronize the times across all motherboards in this configuration. Use this method to sync the times when the edge of the PPS is unknown.
Ex: Host machine is not attached to serial port of GPSDO and can therefore not query the GPSDO for the PPS edge.
This is a 2-step process, and will take at most 2 seconds to complete. Upon completion, the times will be synchronized to the time provided.
| time_spec | the time to latch at the next pps after catching the edge |
Select the TX antenna on the frontend.
Set the TX bandwidth on the frontend.
Set a constant TX DC offset value. The value is complex to control both I and Q.
Set the TX center frequency.
Set the TX gain value for the specified gain element. For an empty name, distribute across all gain elements.
  inline |
Set the TX gain profile.
Set the TX frontend IQ imbalance correction. Use this to adjust the magnitude and phase of I and Q.
Set whether the TX LO used by the device is exported
Set the TX LO frequency (Advanced).
Set the TX LO source for the USRP device.
Set the TX sample rate.
Set the TX frontend specification: The subdev spec maps a physical part of a daughter-board to a channel number. Set the subdev spec before calling into any methods with a channel number. The subdev spec must be the same size across all motherboards.
Perform write on the user configuration register bus. These only exist if the user has implemented custom setting registers in the device FPGA.
| addr | 8-bit register address |
| data | 32-bit register value |
| mboard | which motherboard to set the user register |
Write a low-level register field for a register in the USRP hardware
| field | the identifier of bitfield to be written (all other bits remain unchanged) |
| value | the value to write to the register field |
