#include <uhd/transport/udp_simple.hpp>
virtual ~udp_simple (void)=0
virtual std::string get_send_addr (void)=0
◆ ~udp_simple()
virtual uhd::transport::udp_simple::~udp_simple ( void  )
◆ get_recv_addr()
◆ get_send_addr()
virtual std::string uhd::transport::udp_simple::get_send_addr ( void  )
Get the IP address for the destination
◆ make_broadcast()
const std::string &  port
◆ make_connected()
◆ make_uart()
udpthe UDP transport object
a new UART interface
◆ recv()
double  timeout = 0.1
timeoutthe timeout in seconds
◆ send()
buffsingle asio buffer
the number of bytes sent
◆ mtu
