Public Types | |
| enum | data_type_t { BOOLEAN = 'b', INTEGER = 'i', REALNUM = 'r', STRING = 's' } |
| Enumeration of possible data types in a sensor.  More... | |
| typedef std::map< std::string, std::string > | sensor_map_t |
| sensor_value_t (const std::string &name, bool value, const std::string &utrue, const std::string &ufalse) | |
| sensor_value_t (const std::string &name, signed value, const std::string &unit, const std::string &formatter="%d") | |
| sensor_value_t (const std::string &name, double value, const std::string &unit, const std::string &formatter="%f") | |
| sensor_value_t (const std::string &name, const std::string &value, const std::string &unit) | |
| sensor_value_t (const std::map< std::string, std::string > &sensor_dict) | |
| sensor_value_t (const sensor_value_t &source) | |
| bool | to_bool (void) const |
| convert the sensor value to a boolean  More... | |
| signed | to_int (void) const |
| convert the sensor value to an integer  More... | |
| double | to_real (void) const |
| convert the sensor value to real number  More... | |
| std::string | to_pp_string (void) const |
| Convert this sensor value into a printable string.  More... | |
| sensor_value_t & | operator= (const sensor_value_t &value) |
| Assignment operator for sensor value.  More... | |
Public Attributes | |
| std::string | name |
| The name of the sensor value.  More... | |
| std::string | value |
| std::string | unit |
| data_type_t | type |
| The data type of the value.  More... | |
A sensor value stores a sensor reading as a string with unit and data type. The sensor value class can be used in the following way:
sensor_value_t ref_lock_sensor("Reference", my_lock, "unlocked", "locked"); std::cout << ref_lock_sensor.to_pp_string() << std::endl; //prints Reference: locked
sensor_value_t temp_sensor("Temperature", my_temp, "C"); std::cout << temp_sensor.to_pp_string() << std::endl; //prints Temperature: 38.5 C
| typedef std::map<std::string, std::string> uhd::sensor_value_t::sensor_map_t |
| uhd::sensor_value_t::sensor_value_t | ( | const std::string & | name, |
| bool | value, | ||
| const std::string & | utrue, | ||
| const std::string & | ufalse | ||
Create a sensor value from a boolean.
| name | the name of the sensor |
| value | the value true or false |
| utrue | the unit string when value is true |
| ufalse | the unit string when value is false |
| signed | value, | ||
| const std::string & | unit, | ||
| const std::string & | formatter = "%d"  |
Create a sensor value from an integer.
| value | the signed integer value |
| unit | the associated unit type |
| formatter | the formatter string |
| double | value, | ||
| const std::string & | formatter = "%f"  |
Create a sensor value from a real number.
| value | the real number value |
| const std::string & | value, | ||
| const std::string & | unit | ||
Create a sensor value from a string.
| uhd::sensor_value_t::sensor_value_t | ( | const std::map< std::string, std::string > & | sensor_dict | ) |
Create a sensor value from a map.
The map must have the following keys: name, type, value, and unit.
type must one of the following strings: BOOLEAN, INTEGER, REALNUM, or STRING (see data_type_t).
| uhd::sensor_value_t::sensor_value_t | ( | const sensor_value_t & | source | ) |
Create a sensor value from another sensor value.
| source | the source sensor value to copy |
| sensor_value_t& uhd::sensor_value_t::operator= | ( | const sensor_value_t & | value | ) |
| bool uhd::sensor_value_t::to_bool | ( | void | ) | const |
| signed uhd::sensor_value_t::to_int | ( | void | ) | const |
| std::string uhd::sensor_value_t::to_pp_string | ( | void | ) | const |
| double uhd::sensor_value_t::to_real | ( | void | ) | const |
| std::string uhd::sensor_value_t::name |
| data_type_t uhd::sensor_value_t::type |
| std::string uhd::sensor_value_t::unit |
The sensor value's unit type. For boolean types, this will be the one of the two units depending upon the value of the boolean true or false.
| std::string uhd::sensor_value_t::value |
The sensor value as a string. For integer and real number types, this will be the output of the formatter. For boolean types, the value will be the string literal "true" or "false".
