uhd::cal::power_container Class Referenceabstract
#include <uhd/cal/power_container.hpp>
Inheritance diagram for uhd::cal::power_container:
uhd::cal::cal_container< std::vector< double >, double > uhd::cal::base_container
typedef boost::shared_ptr< power_containersptr
- Public Types inherited from uhd::cal::cal_container< std::vector< double >, double >
typedef std::map< std::vector< double >, double > container_t
typedef boost::archive::text_iarchive iarchive_type
typedef boost::archive::text_oarchive oarchive_type
- Public Types inherited from uhd::cal::base_container
virtual double get (const std::vector< double > &args)=0
virtual void add (const double output, const std::vector< double > &args)=0
virtual void add_metadata (const metadata_t &data)=0
virtual const metadata_tget_metadata ()=0
static sptr make ()
- Protected Member Functions inherited from uhd::cal::cal_container< std::vector< double >, double >
virtual void serialize (iarchive_type &ar, const unsigned int)=0
virtual void serialize (oarchive_type &ar, const unsigned int)=0
◆ add()
virtual void uhd::cal::power_container::add ( const double  output,
const std::vector< double > &  args
Add a data point to the container. This function records a mapping R^n -> R between an input vector and output scalar. For example, a mapping might be (power level, frequency, temperature) -> gain.
outputthe output of the data point mapping
argsinput values
Implements uhd::cal::cal_container< std::vector< double >, double >.
◆ add_metadata()
virtual void uhd::cal::power_container::add_metadata ( const metadata_t data)
Associate some metadata with the container.
dataa map of metadata (string -> string).
virtual double uhd::cal::power_container::get ( const std::vector< double > &  args)
Get the mapping from an input to an output from the calibration container.
argsinput values
the output of the mapping (a scalar value)
Exceptions
uhd::assertion_errorif the number of input values are incorrect for the container type
◆ get_metadata()
virtual const metadata_t& uhd::cal::power_container::get_metadata ( )
Retrieve metadata from the container.
map of metadata.
◆ make()
static sptr uhd::cal::power_container::make ( )
Create a container for data related to power calibration.
shared pointer to the container
