thread_priority.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
Functions
UHD_API uhd_error uhd_set_thread_priority (float priority, bool realtime)
Function Documentation
◆ uhd_set_thread_priority()
UHD_API uhd_error uhd_set_thread_priority ( float  priority,
bool  realtime
Set the scheduling priority on the current thread.
A new thread or calling process should make this call with the defaults this to enable realtime scheduling.
A priority of zero corresponds to normal priority. Positive priority values are higher than normal. Negative priority values are lower than normal.
prioritya value between -1 and 1
realtimetrue to use realtime mode
UHD error code
