Namespaces | |
| chdr | |
| CHDR related function.  | |
Classes | |
| struct | if_packet_info_t |
Functions | |
| UHD_API void | if_hdr_pack_be (uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_unpack_be (const uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_pack_le (uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_unpack_le (const uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void uhd::transport::vrt::if_hdr_pack_be | ( | uint32_t * | packet_buff, |
| if_packet_info_t & | if_packet_info | ||
Pack a vrt header from metadata (big endian format).
if_packet_info has the following members set to correct values:has_* members all set accordinglyhas_* member, the corresponding variable holds a valid value (e.g. if has_sid is true, sid contains a valid SID)num_payload_bytes and num_payload_words32 are both set to the correct valuespacket_buff now points to a valid header that can be sent over the transport without further modificationif_packet_info are set:num_header_words32num_packet_words32| packet_buff | memory to write the packed vrt header |
| if_packet_info | the if packet info (read/write) |
| UHD_API void uhd::transport::vrt::if_hdr_pack_le | ( | uint32_t * | packet_buff, |
Pack a vrt header from metadata (little endian format).
See Packing contract.
| UHD_API void uhd::transport::vrt::if_hdr_unpack_be | ( | const uint32_t * | packet_buff, |
Unpack a vrt header to metadata (big endian format).
packet_buff points to a readable address space with a CHDR packet, starting at the header. packet_buff[0] must always point to a valid first word of the header. This implies that num_packet_words32 must be at least 1.if_packet_info has the following members set to correct values:num_packet_words32. This means all values packet_buff[0] through packet_buff[if_packet_info.num_packet_words32-1] are readable words from this packet.link_typeif_packet_info now has the following values set to correct values:packet_typenum_payload_bytesnum_payload_words32num_header_words32has_*sob, eob, error, cid, sid (if applicable)tsf, tsi (if applicable)| packet_buff | memory to read the packed vrt header |
| UHD_API void uhd::transport::vrt::if_hdr_unpack_le | ( | const uint32_t * | packet_buff, |
Unpack a vrt header to metadata (little endian format).
See Unpacking contract.
