8 #ifndef INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP     9 #define INCLUDED_UHD_UTILS_SOFT_REGISTER_HPP    12 #include <boost/noncopyable.hpp>    16 #include <boost/thread/mutex.hpp>    17 #include <boost/thread/locks.hpp>    18 #include <boost/unordered_map.hpp>    19 #include <boost/tokenizer.hpp>    20 #include <boost/foreach.hpp>    41 #define UHD_DEFINE_SOFT_REG_FIELD(name, width, shift) \    42     static const uhd::soft_reg_field_t name = (((shift & 0xFF) << 8) | (width & 0xFF))    52     return __builtin_expect(expr,
true);
    62     return __builtin_expect(expr,
false);
    77 namespace soft_reg_field {
    79         return (field & 0xFF);
    83         return ((field >> 8) & 0xFF);
    86     template<
typename data_t>
    88         static const data_t ONE =
static_cast<data_t
>(1);
    93             return ((ONE<<
width(field))-ONE)<<
shift(field);
    95             return (0-ONE)<<
shift(field);
   103     virtual void initialize(
wb_iface& iface,
bool sync =
false) = 0;
   104     virtual void flush() = 0;
   105     virtual void refresh() = 0;
   106     virtual size_t get_bitwidth() = 0;
   107     virtual bool is_readable() = 0;
   108     virtual bool is_writable() = 0;
   113     template <
typename soft_reg_t>
   115         soft_reg_t* ptr =
dynamic_cast<soft_reg_t*
   131 template<
typename reg_data_t,
bool readable,
bool writable>
   134     typedef boost::shared_ptr< soft_register_t<reg_data_t, readable, writable> >
sptr;
   146         _iface(NULL), _wr_addr(wr_addr), _rd_addr(rd_addr), _soft_copy(0), _flush_mode(mode)
   156         _iface(NULL), _wr_addr(addr), _rd_addr(addr), _soft_copy(0), _flush_mode(mode)
   169         if (sync && writable) flush();
   170         if (sync && readable) refresh();
   178     UHD_INLINE void set(
const soft_reg_field_t field,
const reg_data_t value)
   180         _soft_copy = (_soft_copy & ~soft_reg_field::mask<reg_data_t>(field)) |
   181                      ((value << soft_reg_field::shift(field)) & soft_reg_field::mask<reg_data_t>(field));
   198         if (writable && _iface) {
   202             if (_flush_mode == ALWAYS_FLUSH || _soft_copy.is_dirty()) {
   203                 if (get_bitwidth() <= 16) {
   204                     _iface->poke16(_wr_addr, static_cast<uint16_t>(_soft_copy));
   205                 }
else if (get_bitwidth() <= 32) {
   206                     _iface->poke32(_wr_addr, static_cast<uint32_t>(_soft_copy));
   207                 }
else if (get_bitwidth() <= 64) {
   208                     _iface->poke64(_wr_addr, static_cast<uint64_t>(_soft_copy));
   212                 _soft_copy.mark_clean();
   224         if (readable && _iface) {
   225             if (get_bitwidth() <= 16) {
   226                 _soft_copy =
static_cast<reg_data_t
>(_iface->peek16(_rd_addr));
   227             }
   228                 _soft_copy =
>(_iface->peek32(_rd_addr));
   229             }
   230                 _soft_copy =
>(_iface->peek64(_rd_addr));
   234             _soft_copy.mark_clean();
   263         static const size_t BITS_IN_BYTE = 8;
   264         return sizeof(reg_data_t) * BITS_IN_BYTE;
   295 template<
bool readable,
bool writable>
   298     typedef boost::shared_ptr< soft_register_sync_t<reg_data_t, readable, writable> >
sptr;
   304         soft_register_t<reg_data_t, readable, writable>(wr_addr, rd_addr, mode), _mutex()
   315         boost::lock_guard<boost::mutex> lock(_mutex);
   319     UHD_INLINE void set(
   321         boost::lock_guard<boost::mutex> lock(_mutex);
   327         boost::lock_guard<boost::mutex> lock(_mutex);
   333         boost::lock_guard<boost::mutex> lock(_mutex);
   339         boost::lock_guard<boost::mutex> lock(_mutex);
   345         boost::lock_guard<boost::mutex> lock(_mutex);
   351         boost::lock_guard<boost::mutex> lock(_mutex);
   435     typedef boost::shared_ptr<soft_regmap_accessor_t>
sptr;
   439     virtual std::vector<std::string> enumerate()
const = 0;
   440     virtual const std::string& get_name()
const = 0;
   470         boost::lock_guard<boost::mutex> lock(_mutex);
   482         boost::lock_guard<boost::mutex> lock(_mutex);
   494         boost::lock_guard<boost::mutex> lock(_mutex);
   505         regmap_t::const_iterator iter = _regmap.find(name);
   506         if (iter != _regmap.end()) {
   507             return *(iter->second);
   518         std::vector<std::string> temp;
   519         BOOST_FOREACH(
const regmap_t::value_type& reg, _regmap) {
   520             temp.push_back(_name +
"/" + reg.first);
   535         boost::lock_guard<boost::mutex> lock(_mutex);
   536         if (visible == PUBLIC) {
   538             if (not _regmap.insert(regmap_t::value_type(name, ®)).second) {
   542         _reglist.push_back(®);
   546     typedef boost::unordered_map<std::string, soft_register_base*> regmap_t;
   547     typedef std::list<soft_register_base*>                         reglist_t;
   549     const std::string   _name;
   564     typedef boost::shared_ptr<soft_regmap_db_t>
sptr;
   579     const std::string&
get_name()
 const {
return _name; }
   585         boost::lock_guard<boost::mutex> lock(_mutex);
   586         _regmaps.push_back(®map);
   593         boost::lock_guard<boost::mutex> lock(_mutex);
   597             _regmap_dbs.push_back(&db);
   614         std::list<std::string> tokens;
   616             const std::string& node,
   617             boost::tokenizer< boost::char_separator<char> >(path, boost::char_separator<char>(
   619             tokens.push_back(node);
   621         if ((tokens.size() > 2 && tokens.front() == _name) ||
   622             (tokens.size() > 1 && _name ==
   623             if (_name !=
"") tokens.pop_front();
   624             if (tokens.size() == 2) {
   626                     if (regmap->
get_name() == tokens.front()) {
   627                         return regmap->
lookup(tokens.back());
   631             }
else if (not _regmap_dbs.empty()) {
   634                 BOOST_FOREACH(
const std::string& node, tokens) {
   635                     newpath += (
"/" + node);
   640                         return db->
lookup(newpath.substr(1));
   641                     }
catch (std::exception&) {
   654         std::vector<std::string> paths;
   656             const std::vector<std::string>& regs = regmap->
enumerate();
   657             paths.insert(paths.end(), regs.begin(), regs.end());
   660             const std::vector<std::string>& regs = db->
enumerate();
   661             paths.insert(paths.end(), regs.begin(), regs.end());
   667     typedef std::list<soft_regmap_accessor_t*> db_t;
   669     const std::string   _name;
 void refresh()
Definition: soft_register.hpp:493
soft_register_sync_t< uint16_t, false, true > soft_reg16_wo_sync_t
Definition: soft_register.hpp:375
uint32_t soft_reg_field_t
Definition: soft_register.hpp:75
UHD_INLINE void flush()
Definition: soft_register.hpp:196
Definition: soft_register.hpp:124
soft_reg_flush_mode_t
boost::shared_ptr< soft_register_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:134
Definition: soft_register.hpp:296
Definition: exception.hpp:106
soft_regmap_t(const std::string &name)
Definition: soft_register.hpp:455
UHD_INLINE bool unlikely(bool expr)
hint for the branch prediction
Definition: soft_register.hpp:59
UHD_INLINE void refresh()
Definition: soft_register.hpp:222
soft_register_t< uint64_t, false, true > soft_reg64_wo_t
Definition: soft_register.hpp:386
virtual std::vector< std::string > enumerate() const
Definition: soft_register.hpp:517
soft_register_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:153
Definition: soft_register.hpp:41
soft_register_t< uint32_t, true, false > soft_reg32_ro_t
Definition: soft_register.hpp:380
UHD_INLINE size_t get_bitwidth()
Definition: soft_register.hpp:261
virtual soft_register_base & lookup(const std::string &name) const
Definition: soft_register.hpp:504
soft_register_sync_t(wb_iface::wb_addr_type addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:307
UHD_INLINE bool is_writable()
Definition: soft_register.hpp:278
soft_register_sync_t< uint64_t, true, true > soft_reg64_rw_sync_t
Definition: soft_register.hpp:391
Definition: exception.hpp:91
Definition: soft_register.hpp:562
Definition: soft_register.hpp:653
soft_register_sync_t< uint32_t, false, true > soft_reg32_wo_sync_t
Definition: soft_register.hpp:382
soft_register_t< uint32_t, false, true > soft_reg32_wo_t
Definition: soft_register.hpp:379
UHD_INLINE size_t width(const soft_reg_field_t field)
Definition: soft_register.hpp:78
Definition: soft_register.hpp:527
UHD_INLINE void set(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:178
soft_regmap_db_t(const std::string &name)
Definition: soft_register.hpp:574
virtual ~soft_regmap_accessor_t()
Definition: soft_register.hpp:437
Definition: soft_register.hpp:132
UHD_INLINE reg_data_t get(const soft_reg_field_t field)
Definition: soft_register.hpp:188
Definition: build_info.hpp:14
soft_regmap_db_t()
Definition: soft_register.hpp:569
UHD_INLINE void write(const soft_reg_field_t field, const reg_data_t value)
Definition: soft_register.hpp:343
virtual std::vector< std::string > enumerate() const =0
virtual soft_register_base & lookup(const std::string &path) const =0
virtual ~soft_register_base()
Definition: soft_register.hpp:101
void flush()
Definition: soft_register.hpp:481
visibility_t
Definition: soft_register.hpp:526
UHD_INLINE void initialize(wb_iface &iface, bool sync=false)
Definition: soft_register.hpp:164
boost::shared_ptr< soft_register_sync_t< reg_data_t, readable, writable > > sptr
Definition: soft_register.hpp:298
Definition: soft_register.hpp:469
virtual const std::string & get_name() const =0
soft_register_sync_t< uint64_t, true, false > soft_reg64_ro_sync_t
Definition: soft_register.hpp:390
virtual ~soft_regmap_t()
Definition: soft_register.hpp:456
soft_register_sync_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:300
boost::shared_ptr< soft_regmap_accessor_t > sptr
Definition: soft_register.hpp:435
Definition: soft_register.hpp:433
UHD_INLINE bool is_readable()
Definition: soft_register.hpp:270
#define UHD_INLINE
Definition: config.h:53
Definition: soft_register.hpp:331
UHD_INLINE reg_data_t read(const soft_reg_field_t field)
Definition: soft_register.hpp:252
soft_register_t(wb_iface::wb_addr_type wr_addr, wb_iface::wb_addr_type rd_addr, soft_reg_flush_mode_t mode=ALWAYS_FLUSH)
Definition: soft_register.hpp:142
soft_register_t< uint64_t, true, false > soft_reg64_ro_t
Definition: soft_register.hpp:387
boost::shared_ptr< soft_regmap_db_t > sptr
Definition: soft_register.hpp:564
Definition: soft_register.hpp:453
Definition: soft_register.hpp:99
soft_register_sync_t< uint32_t, true, false > soft_reg32_ro_sync_t
Definition: soft_register.hpp:383
Definition: exception.hpp:42
Definition: config.h:63
Definition: soft_register.hpp:87
void add(soft_regmap_t ®map)
Definition: soft_register.hpp:584
Definition: soft_register.hpp:349
Definition: soft_register.hpp:579
Definition: soft_register.hpp:337
soft_register_t< uint64_t, true, true > soft_reg64_rw_t
Definition: soft_register.hpp:388
Definition: soft_register.hpp:243
soft_register_t< uint16_t, true, true > soft_reg16_rw_t
Definition: soft_register.hpp:374
Definition: exception.hpp:70
void add(soft_regmap_db_t &db)
Definition: soft_register.hpp:592
virtual void initialize(wb_iface &iface, bool sync=false)=0
Definition: soft_register.hpp:611
soft_register_sync_t< uint16_t, true, true > soft_reg16_rw_sync_t
Definition: soft_register.hpp:377
soft_register_sync_t< uint64_t, false, true > soft_reg64_wo_sync_t
Definition: soft_register.hpp:389
Definition: soft_register.hpp:313
soft_register_t< uint16_t, false, true > soft_reg16_wo_t
Definition: soft_register.hpp:372
UHD_INLINE bool likely(bool expr)
soft_register_sync_t< uint32_t, true, true > soft_reg32_rw_sync_t
Definition: soft_register.hpp:384
virtual UHD_INLINE const std::string & get_name() const
Definition: soft_register.hpp:461
UHD_INLINE void add_to_map(soft_register_base ®, const std::string &name, const visibility_t visible=PRIVATE)
Definition: soft_register.hpp:534
UHD_INLINE size_t shift(const soft_reg_field_t field)
Definition: soft_register.hpp:82
uint32_t wb_addr_type
Definition: wb_iface.hpp:23
static UHD_INLINE soft_reg_t & cast(soft_register_base ®)
Definition: soft_register.hpp:114
Definition: wb_iface.hpp:19
soft_register_t< uint16_t, true, false > soft_reg16_ro_t
Definition: soft_register.hpp:373
soft_register_sync_t< uint16_t, true, false > soft_reg16_ro_sync_t
Definition: soft_register.hpp:376
soft_register_t< uint32_t, true, true > soft_reg32_rw_t
Definition: soft_register.hpp:381
