#include <uhd/usrp/fe_connection.hpp>
◆ sampling_t
Sampling mode. Represents the sampling architecture for the front-end
| Enumerator |
| QUADRATURE  | Complex sampling (Complex input, Complex output).
| HETERODYNE  | Heterodyne sampling (Real input, Complex output). Only one of the I and Q inputs is used.
| REAL  | Real sampling (Real input, Real output). Only one of the I and Q inputs is used.
◆ fe_connection_t() [1/2]
          | uhd::usrp::fe_connection_t::fe_connection_t  |
          sampling_t  |
          sampling_mode,  |
          bool  |
          iq_swapped,  |
          bool  |
          i_inverted,  |
          bool  |
          q_inverted,  |
          double  |
          if_freq = 0.0  |
Create a frontend connection class from individual settings.
- Parameters
    | sampling_mode | can be { QUADRATURE, HETERODYNE, REAL }  |
    | iq_swapped | indicates if the IQ channels are swapped (after inverion and heterodyne correction)  |
    | i_inverted | indicates if the I channel is inverted (negated)  |
    | q_inverted | indicates if the Q channel is inverted (negated)  |
    | if_freq | the baseband sampling frequency.  |
◆ fe_connection_t() [2/2]
          const std::string &  |
          conn_str,  |
          double  |
          if_freq = 0.0  |
Create a frontend connection class from a connection string The connection string can be:
- in {I, Q}: Real mode sampling with no inversion.
- in {Ib, Qb}: Real mode sampling with inversion.
- in {IQ, QI}: Quadrature sampling with no inversion.
- in {IbQb, QbIb}: Quadrature sampling with inversion.
- in {II, QQ}: Heterodyne sampling with no inversion.
- in {IbIb, QbQb}: Heterodyne sampling with inversion.
- Parameters
    | conn_str | the connection string.  |
◆ get_if_freq()
          | double uhd::usrp::fe_connection_t::get_if_freq  |
           const |
inline   |
Accessor for IF frequency
◆ get_sampling_mode()
          | sampling_t uhd::usrp::fe_connection_t::get_sampling_mode  |
           const |
inline   |
Accessor for sampling mode
◆ is_i_inverted()
          | bool uhd::usrp::fe_connection_t::is_i_inverted  |
           const |
inline   |
Accessor for I inversion parameter
◆ is_iq_swapped()
          | bool uhd::usrp::fe_connection_t::is_iq_swapped  |
           const |
inline   |
Accessor for IQ swap parameter
◆ is_q_inverted()
          | bool uhd::usrp::fe_connection_t::is_q_inverted  |
           const |
inline   |
Accessor for Q inversion parameter
◆ set_if_freq()
          | void uhd::usrp::fe_connection_t::set_if_freq  |
          double  |
          freq | ) |
inline   |
