pimpl.hpp File Reference
#include <uhd/config.hpp>
Macros
#define UHD_PIMPL_DECL(_name)   struct _name; boost::shared_ptr<_name>
#define UHD_PIMPL_MAKE(_name, _args)   boost::shared_ptr<_name>(new _name _args)
"Pimpl idiom" (pointer to implementation idiom). The UHD_PIMPL_* macros simplify code overhead for declaring and making pimpls.
Each pimpl is implemented as a shared pointer to the implementation:
  • The container class will not have to deallocate the pimpl.
  • The container class will use the pimpl as a regular pointer.
  • Usage: _impl->method(arg0, arg1)
  • Usage: _impl->member = value;
See also
http://en.wikipedia.org/wiki/Opaque_pointer
◆ UHD_PIMPL_DECL
#define UHD_PIMPL_DECL (   _name)    struct _name; boost::shared_ptr<_name>
Make a declaration for a pimpl in a header file.
◆ UHD_PIMPL_MAKE
#define UHD_PIMPL_MAKE (   _name,
  _args
Make an instance of a pimpl in a source file.
