#include <uhd/usrp/dboard_manager.hpp>
| static void  | register_dboard (const dboard_id_t &dboard_id, dboard_ctor_t db_subdev_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0"), dboard_ctor_t db_container_ctor=NULL) |
| static void  | register_dboard (const dboard_id_t &rx_dboard_id, const dboard_id_t &tx_dboard_id, dboard_ctor_t db_subdev_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0"), dboard_ctor_t db_container_ctor=NULL) |
| static void  | register_dboard_restricted (const dboard_id_t &dboard_id, dboard_ctor_t db_subdev_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0"), dboard_ctor_t db_container_ctor=NULL) |
| static void  | register_dboard_restricted (const dboard_id_t &rx_dboard_id, const dboard_id_t &tx_dboard_id, dboard_ctor_t db_subdev_ctor, const std::string &name, const std::vector< std::string > &subdev_names=std::vector< std::string >(1, "0"), dboard_ctor_t db_container_ctor=NULL) |
| static sptr  | make (dboard_id_t rx_dboard_id, dboard_id_t tx_dboard_id, dboard_id_t gdboard_id, dboard_iface::sptr iface, property_tree::sptr subtree, bool defer_db_init=false) |
| static sptr  | make (dboard_eeprom_t rx_eeprom, dboard_eeprom_t tx_eeprom, dboard_eeprom_t gdb_eeprom, dboard_iface::sptr iface, property_tree::sptr subtree, bool defer_db_init=false) |
A daughter board subdev dboard_manager class. Create subdev instances for each subdev on a dboard. Provide wax::obj access to the subdevs inside.
◆ dboard_ctor_t
◆ ~dboard_manager()
          | virtual uhd::usrp::dboard_manager::~dboard_manager  |
inlinevirtual   |
◆ get_rx_frontends()
          | virtual const std::vector<std::string>& uhd::usrp::dboard_manager::get_rx_frontends  |
           const |
pure virtual   |
Returns a vector of RX frontend (subdev) names
- Returns
 - a vector of names
◆ get_tx_frontends()
          | virtual const std::vector<std::string>& uhd::usrp::dboard_manager::get_tx_frontends  |
           const |
pure virtual   |
Returns a vector of TX frontend (subdev) names
- Returns
 - a vector of names
◆ initialize_dboards()
          | virtual void uhd::usrp::dboard_manager::initialize_dboards  |
pure virtual   |
Run dboard post constructor initializations if defered during make
◆ make() [1/2]
Make a new dboard manager.
- Parameters
    | rx_dboard_id | the id of the rx dboard  |
    | tx_dboard_id | the id of the tx dboard  |
    | gdboard_id | the id of the grand-dboard  |
    | iface | the custom dboard interface  |
    | subtree | the subtree to load with props  |
    | defer_db_init | initialising the daughterboards (DEPRECATED)  |
- Returns
 - an sptr to the new dboard manager
◆ make() [2/2]
- Parameters
    | rx_eeprom | the RX EEPROM data  |
    | tx_eeprom | the TX EEPROM data  |
    | gdb_eeprom | the grand-dboard EEPROM data  |
- Returns
◆ register_dboard() [1/2]
          | static void uhd::usrp::dboard_manager::register_dboard  |
          const dboard_id_t &  |
          dboard_id,  |
          dboard_ctor_t  |
          db_subdev_ctor,  |
          const std::string &  |
          name,  |
          const std::vector< std::string > &  |
          subdev_names = std::vector< std::string >(1, "0"),  |
          dboard_ctor_t  |
          db_container_ctor = NULL  |
static   |
Register a rx or tx dboard into the system. For single subdevice boards, omit subdev_names.
- Parameters
    | dboard_id | the dboard id (rx or tx)  |
    | db_subdev_ctor | the dboard sub-device constructor function pointer (one instance per subdev name)  |
    | name | the canonical name for the dboard represented  |
    | subdev_names | the names of the subdevs on this dboard  |
    | db_container_ctor | the dboard container constructor function pointer (one instance per dboard)  |
◆ register_dboard() [2/2]
          rx_dboard_id,  |
          tx_dboard_id,  |
          dboard_ctor_t  |
          db_subdev_ctor,  |
          name,  |
          dboard_ctor_t  |
static   |
Register an xcvr dboard into the system. For single subdevice boards, omit subdev_names.
- Parameters
    | rx_dboard_id | the rx unit dboard id  |
    | tx_dboard_id | the tx unit dboard id  |
◆ register_dboard_restricted() [1/2]
          | static void uhd::usrp::dboard_manager::register_dboard_restricted  |
          dboard_id,  |
          dboard_ctor_t  |
          db_subdev_ctor,  |
          name,  |
          dboard_ctor_t  |
static   |
Register a restricted rx or tx dboard into the system. A restricted dboard does not add its dboard_iface object into the property tree. For single subdevice boards, omit subdev_names. The iface for a restricted board is not registered into the property tree.
- Parameters
◆ register_dboard_restricted() [2/2]
          rx_dboard_id,  |
          tx_dboard_id,  |
          dboard_ctor_t  |
          db_subdev_ctor,  |
          name,  |
          dboard_ctor_t  |
static   |
Register a restricted xcvr dboard into the system. A restricted dboard does not add its dboard_iface object into the property tree. For single subdevice boards, omit subdev_names. The iface for a restricted board is not registered into the property tree.
- Parameters
