USRP E320
Comparative features list
The E320 is a 2-channel transmitter/receiver based on the AD9361 transceiver IC. It is a monolithic board with one AD9361 and provides two RF channels.
  • TX band: 47 MHz to 6.0 GHz
  • RX band: 70 MHz to 6.0 GHz
  • 56 MHz of instantaneous bandwidth
  • 2 RX DDC chains in FPGA
  • 2 TX DUC chain in FPGA
  • Hardware Capabilities:
    • Single SFP+ Transceivers (can be used with 1 GigE, 10 GigE, and Aurora)
    • External PPS input
    • External 10 MHz input
    • Internal GPSDO for timing, location, and 10 MHz reference clock + PPS
    • External USB Connection for built-in JTAG debugger and serial console
    • Xilinx Zynq SoC with dual-core ARM Cortex A9 (Speedgrade 3) and Kintex-7 FPGA (XC7Z045)
  • Software Capabilities:
  • FPGA Capabilities:
    • RFNoC capability
The Zynq CPU/FPGA and host operating system
The main CPU of the E320 is a Xilinx Zynq SoC XC7Z045. It is both a dual-core ARM Cortex A9 CPU and Kintex-7 FPGA on a single die. The CPU is clocked at 1GHz (speedgrade 3).
The STM32 microcontroller
The SD card
The E320 uses a micro SD card as its main storage. The entire root file system (Linux kernel, libraries) and any user data are stored on this SD card.
  1. Boot partition (contains the bootloader). This partition usually does not require any modifications.
  2. A data partition, mounted in /data. This is the only partition that is not erased during file system updates.
  1. Two identical system partitions (root file systems). These contain the operating system and the home directory (anything mounted under / that is not the data or boot partition). The reason there are two of these is to enable remote updates: An update running on one partition can update the other one without any effect to the currently running system. Note that the system partitions are erased during updates and are thus unsuitable for permanently storing information.
$ mkdir temp
$ mount /dev/mmcblk0p3 temp
Getting started
This will run you through the first steps relevant to getting your USRP E320 up and running. Note: This guide was creating on an Ubuntu machine, and other distributions or OS's may have different names/methods.
Assembling the E320
Unlike the X300 or N200 series, there is no assembly of required since it is a monolithic board.
Checklist:
  • Connect power and network
  • Read security settings
  • Connect clocking (if required)
Updating the file system
To obtain the default micro SD card image for a specific version of UHD, install that version of UHD (3.13.0.2 or later) on a host system with Internet access and run:
$ uhd_images_downloader -t e320 -t sdimg
The image will be downloaded to <UHD_INSTALL_DIR>/share/uhd/images/usrp_e320_fs.sdimg, where <UHD_INSTALL_DIR> is the UHD installation directory.
The <YOUR_IMAGE> is the path to the micro SD card image (i.e.<UHD_INSTALL_DIR>/share/uhd/images/usrp_e320_fs.sdimg).
Serial connection
$ ls /dev/serial/by-id
/dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if00-port0
/dev/serial/by-id/usb-FTDI_Dual_RS232-HS-if01-port0
/dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if00-port0
/dev/serial/by-id/usb-Silicon_Labs_CP2105_Dual_USB_to_UART_Bridge_Controller_007F6A6C-if01-port0
root@ni-e320-311FE00:~#
SSH connection
The USRP E320 devices have two network connections: One SFP port, and an RJ-45 connector. The latter is by default configured by DHCP; by plugging it into into 1 Gigabit switch on a DHCP-capable network, it will get assigned an IP address and thus be accessible via ssh.
$ ssh root@ni-e320-311FE00 # Replace with your actual device name!
$ ssh [email protected]
Note: The device's hostname is derived from its serial number by default (ni-e320-<SERIAL>). You can change the hostname by modifying the /etc/hostname file and rebooting.
Network Connectivity
The SFP+ (sfp0) port is configured with static address 192.168.10.2/24
The configuration for the sfp0 port is stored in /etc/systemd/networkd/sfp0.network.
eth0 (DHCP):
    [Match]
    Name=eth0
    [Network]
    DHCP=v4
    [DHCPv4]
    UseHostname=false
sfp0 (static):
    [Match]
    Name=sfp0
    [Network]
    Address=192.168.10.2/24
    [Link]
    MTUBytes=8000
Note: Care needs to be taken when editing these files on the device, since vi / vim sometimes generates undo files (e.g. /etc/systemd/networkd/sfp0.network~), that systemd-networkd might accidentally pick up.
Security-related settings
The E320 ships without a root password set. It is possible to ssh into the device by simply connecting as root, and thus gaining access to all subsystems. To set a password, run the command
$ passwd
on the device.
Updating the FPGA
$ uhd_image_loader --args type=e3xx,addr=ni-e320-311fe00
to update the FPGA using the default settings. Replace ni-e320-311fe00 in the addr with the correct device address. If a custom FPGA image is targeted for uploading, use the --fpga-path command line argument. Run
$ uhd_image_loader --help
to see a full list of command line options. Note that updating the FPGA image will force a reload of the FPGA, which will temporarily take down the SFP network interfaces (and temporary settings, such as applied via ifconfig on the command line, will be lost).
Using an E320 USRP from UHD
Like any other USRP, all E320 USRPs are controlled by the UHD software. To integrate a USRP E320 into your C++ application, you would generate a UHD device in the same way you would for any other USRP:
auto usrp = uhd::usrp::multi_usrp::make("type=e3xx");
Device arguments
Key Description Example Value
addr IPv4 address of primary SFP+ port to connect to. addr=192.168.30.2
find_all When using broadcast, find all devices, even if unreachable via CHDR. find_all=1
master_clock_rate Master Clock Rate in Hz. Default is 16 MHz. master_clock_rate=30.72e6
serialize_init Force serial initialization of daughterboards. serialize_init=1
skip_dram Ignore DRAM FIFO block. Connect TX streamers straight into DUC or radio. skip_dram=1
skip_ddc Ignore DDC block. Connect Rx streamers straight into radio. skip_ddc=1
skip_duc Ignore DUC block. Connect Tx streamers or DRAM straight into radio. skip_duc=1
skip_init Skip the initialization process for the device. skip_init=1
ref_clk_freq Specify the external reference clock frequency, default is internal (20 MHz). ref_clk_freq=10e6
init_cals Specify the bitmask for initial calibrations of the RFIC. init_cals=BASIC
init_cals_timeout Timeout for initial calibrations in milliseconds. init_cals_timeout=45000
discovery_port Override default value for MPM discovery port. discovery_port=49700
rpc_port Override default value for MPM RPC port. rpc_port=49701
tracking_cals Specify the bitmask for tracking calibrations of the RFIC. tracking_cals=ALL
The sensor API
Like other USRPs, the E320 series has RF and motherboard sensors. When using uhd::usrp::multi_usrp, the following API calls are relevant to interact with the sensor API:
  • temp_internal: temperature (in C) of Temperature Sensor on board
  • temp_fpga: temperature (in C) of the FPGA die
  • temp_rf_channelA: temperature (in C) near power amplifier RF A
  • temp_rf_channelB: temperature (in C) near power amplifier RF B
  • temp_main_power: temperature (in C) near power supply
  • gps_locked: GPS lock
  • gps_time: GPS time in seconds sin ce the epch
  • gps_tpv: A TPV report from GPSd serialized as JSON
  • gps_sky: A SKY report from GPSd serialized as JSON
  • ref_locked: This will check that all the daughterboards have locked to the external/internal reference clock.
  • fan: get fan speed (in rpm)
Remote Management
Mender: Remote update capability
$ mender -rootfs /path/to/latest.mender
$ mender -rootfs http://server.name/path/to/latest.mender
$ reboot
$ mender -commit
If you are running a hosted server, the updates can be initiated from a web dashboard. From there, you can start the updates without having to log into the device, and can update groups of USRPs with a few clicks in a web GUI. The dashboard can also be used to inspect the state of USRPs. This is simple way to update groups of rack-mounted USRPs with custom file systems.
Salt: Remote configuration management and execution
Salt (also known as SaltStack, see Salt Website) is a Python-based tool for maintaining fleets of remote devices. It can be used to manage USRP E320 remotely for all types of settings that are not controlled by UHD. For example, if an operator would like to reset the root password on multiple devices, or install custom software, this tool might be a suitable choice.
Salt is a third-party project with its own documentation, which should be consulted for configuring it. However, the Salt minion is installed by default on every E320 device. To start it, simply log on to the device and run:
$ systemctl start salt-minion
  1. Install the salt-master package on the server (e.g. by running apt install salt-master if the server is an Ubuntu system), and make sure the Salt master is running.
  2. Add the network address / hostname of that server to the /etc/salt/minion file on the device by editing the master: line.
  3. Launch the Salt minion on the USRP by running the command systemctl start salt-minion.
  4. The minion will try to connect to the master. You need to authorize the minion by running salt-key -a $hostname where $hostname is the name of the minion.
  5. Once the device is authorized, you can try various commands to see if the communication was established:
    $ [sudo] salt '*' test.ping ni-n3xx-$serial: True $ [sudo] salt '*' network.interfaces
    ni-n3xx-$serial:
    eth0:
    hwaddr: 02:00:03:11:fe:00 inet:
    |_
    address: xx.xx.xx.xx broadcast: xx.xx.xx.xx label: eth0 netmask: 255.255.254.0 up: True
Theory of Operation
E320 is on the MPM architecture (see also: The Module Peripheral Manager (MPM) Architecture). Inside the Linux operating system running on the ARM cores, there is hardware daemon which needs to be active in order for the device to function as a USRP (it is enabled to run by default).
Modifying and compiling UHD and MPM for the E320
Compiling MPM natively
$ mkdir uhd # Create a new, empty directory called uhd
$ sshfs user@yourcomputer:src/uhd uhd # This will mount ~/src/uhd from the remote machine to ~/uhd on the device
$ mkdir build_mpm
$ cd build_mpm # You are now in /home/root/build_mpm
$ cmake ../uhd/mpm
$ make -j2 install # This will take several minutes
Obtaining an SDK
The recommended way to develop software for the E320 is to cross-compile. By running the compiles on a desktop or laptop computer, you will be able to speed up compile times considerably (compiling UHD natively for the E320 would take many hours).
$ ./oecore-x86_64-cortexa9hf-neon-toolchain-nodistro.0.sh
This will prompt you for an installation path. Please ensure you have sufficient disk space, as each of the SDKs may require several gigabytes of disk space (depends on the image flavor selected).
SDK Usage
This will modify the PATH, CC, CXX etc, environment variables and allow you to compile software for your USRP E320 device. To verify all went well you can try:
$ $CC -dumpmachine
Building UHD
  2. Set up your environment as described in SDK Usage
     $ cmake -DCMAKE_TOOLCHAIN_FILE=../host/cmake/Toolchains/oe-sdk_cross.cmake -DCMAKE_INSTALL_PREFIX=/usr .. # Add any CMake options you desire
     $ make # You can run make -j12 to compile on 12 processes at once
Note: The UHD you are cross-compiling will not run on your host computer (the one where you're doing the development). Compiling UHD regularly on your host computer (with MPMD enabled) will allow you to talk to your E320.
Building GNU Radio
  1. Obtain the GNU Radio source code via git or tarball
$ mkdir build-arm
$ cd build-arm
-DENABLE_GR_DTV=OFF -DENABLE_DOXYGEN=OFF ../ # Append any CMake options you desire
E320-specific Features
Front and Rear Panel
FPGA Register Map
AXI Slave Address Range UIO Label Description
Slave 0 4000_0000 - 4000_3fff - Ethernet DMA SFP
Slave 1 4000_4000 - 4000_4fff misc-enet-regs Ethernet registers SFP
Slave 2 4001_0000 - 4001_3fff mboard-regs Motherboard control
Slave 3 4001_4000 - 4001_41ff dboard-regs Daughterboard control
E320 Register Map
AXI Slave Module Address Name Read/Write Description
Slave 0 axi_eth_dma 4000_0000 - 4000_4fff Ethernet DMA RW See Linux Driver
Slave 1 e320_mgt_io_core 4000_4000 PORT_INFO RO SFP port information
[31:24] COMPAT_NUM RO -
[23:18] 6'h0 RO -
[17] activity RO -
[16] link_up RO -
[15:8] mgt_protocol RO 0 - None, 1 - 1G, 2 - XG, 3 - Aurora
[7:0] PORTNUM RO -
e320_mgt_io_core 4000_4004 MAC_CTRL_STATUS RW Control 10gE and Aurora mac
[0] ctrl_tx_enable (PROTOCOL = "10GbE")RW-
[0] bist_checker_en (PROTOCOL = "Aurora")RW-
[1] bist_gen_en RW -
[2] bist_loopback_enRW -
[8:3] bist_gen_rate RW -
[9] phy_areset RW -
[10] mac_clear RW -
e320_mgt_io_core 4000_4008 PHY_CTRL_STATUS RW Phy reset control
e320_mgt_io_core 4000_400C MAC_LED_CTL RW Used by ethtool to indicate port
[1] identify_enable RW -
[0] identify_value RW -
mdio_master 4000_4010 MDIO_DATA RW -
4000_4014 MDIO_ADDR RW -
4000_4018 MDIO_OP RW -
4000_401C MDIO_CTRL_STATUSRW -
e320_mgt_io_core 4000_4020 AURORA_OVERUNS RO -
4000_4024 AURORA_CHECKSUM_ERRORSRO -
4000_4028 AURORA_BIST_CHECKER_SAMPSRO -
4000_402C AURORA_BIST_CHECKER_ERRORSRO-
eth_switch 4000_5000 MAC_LSB RW Device MAC LSB
4000_5004 MAC_MSB RW Device MAC MSB
4000_6000 IP RW Device IP
4000_6004 PORT1, PORT0 RW Device UDP port
eth_dispatch 4000_6008 [1] ndest, [0] bcastRW Enable Crossover
4000_600c [1] my_icmp_type, [0] my_icmp_code-
eth_switch 4000_6010 BRIDGE_MAC_LSB Bridge SFP ports in ARM
4000_6014 BRIDGE_MAC_MSB -
4000_6018 BRIDGE_IP -
4000_601c BRIDGE_PORT1, BRIDGE_PORT0-
4000_6020 BRIDGE_EN -
chdr_eth_framer 4000_6108 onwards LOCAL_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 256 SIDs
4000_6208 onwards LOCAL_DST_UDP_MAC_MSBW Destination MAC for outgoing packets (MSB)
4000_6308 onwards LOCAL_DST_MAC_LSBW Destination MAC for outgoing packets (LSB)
4000_7000 onwards REMOTE_DST_IP W Destination IP, MAC, UDP for Outgoing Packet for 16 local addrs
4000_7400 onwards REMOTE_DST_UDP_MAC_HIW Destination MAC (MSB)
4000_7800 onwards REMOTE_DST_MAC_LOW
Destination MAC (LSB)
Slave 2 e320_core 4001_0000 COMPAT_NUM R FPGA Compat Number
[31:16] Major RO -
[15:0] Minor RO -
4001_0004 DATESTAMP RO -
4001_0008 GIT_HASH RO -
4001_000C SCRATCH RO -
4001_0010 NUM_CE RO Number of Computation Engines (RFNoC Blocks)
4001_0014 NUM_IO_CE RO Number of fixed IO CEs - Radios + DMA Fifo
4001_0018 CLOCK_CTRL -
[0] pps select (internal 10 MHz)RWOne-hot encoded pps_select to use the internal PPS from GPSDO
[1] pps select (external 10 MHz)RWOne-hot encoded pps_select to use the external PPS.
[2] refclk_select (internal/external 10 MHz)RWrefclk_select=0 for internal (GPSDO) 10 MHz, refclk_sel=1 for external 10 MHz.
4001_001C XADC_READBACK RO -
[11:0] FPGA temperatureRO -
4001_0020 BUS_CLK_RATE RO -
4001_0024 BUS_CLK_COUNT RO -
4001_0028 SFP_PORT_INFO RO Same as port_info register 0x4000_4000
4001_002C FP_GPIO_CTRL RW -
4001_0030 FP_GPIO_MASTER RW -
4001_0034 FP_GPIO_RADIO_SRC RW -
4001_0038 GPS_CTRL RW -
[0] GPS_PWR_EN RW Power on GPSDO
[1] GPS_RST_N RW -
[2] GPS_INITSURV_N RW -
4001_003C GPS_STATUS RO GPSDO Status
[0] GPS_LOCK RO Returns 1 if GPSDO is locked
[1] GPS_ALARM RO -
[2] GPS_PHASELOCK RO -
[3] GPS_SURVEY RO -
[4] GPS_WARMUP RO -
4001_0040 DBOARD_CTRL RO -
4001_0044 DBOARD_STATUS RO
axi_crossbar 4001_1010 XBAR_VERSION RO See crossbar kernel driver
4001_1014 XBAR_NUM_PORTS RO See crossbar kernel driver
4001_1018 LOCAL_ADDR RW See crossbar kernel driver
4001_1020 remote_offset WO XBAR settings reg
4001_1420 local_offset WO
XBAR settings reg
Slave 4 4001_40004001_41FFDaughterboard Registers- Don't exist now. TBD
