#include <uhd/utils/gain_group.hpp>
◆ sptr
◆ ~gain_group()
| virtual uhd::gain_group::~gain_group |
void |
◆ get_names()
| virtual const std::vector<std::string> uhd::gain_group::get_names |
void |
Get a list of names of registered gain elements. The names are in the order that they were registered.
- Returns
- a vector of gain name strings
◆ get_range()
| virtual gain_range_t uhd::gain_group::get_range |
const std::string & |
name = "" | ) |
Get the gain range for the gain element specified by name. For an empty name, get the overall gain range for this group. Overall step is defined as the minimum step size.
- Parameters
| name | name of the gain element (optional) |
- Returns
- a gain range with overall min, max, step
◆ get_value()
| virtual double uhd::gain_group::get_value |
name = "" | ) |
Get the gain value for the gain element specified by name. For an empty name, get the overall gain value for this group.
- Parameters
- Returns
- a gain value of the element or all elements
◆ make()
| static sptr uhd::gain_group::make |
void |
Make a new empty gain group.
- Returns
- a gain group object.
◆ register_fcns()
| virtual void uhd::gain_group::register_fcns |
name, |
const gain_fcns_t & |
gain_fcns, |
size_t |
priority = 0 |
Register a set of gain functions into this group:
The name should be a unique and non-empty name. Otherwise, the implementation will rename it.
Priority determines how power will be distributed with higher priorities getting the power first, and lower priorities getting the remainder power.
- Parameters
| name | the name of the gain element |
| gain_fcns | the set of gain functions |
| priority | the priority of the gain element |
◆ set_value()
| virtual void uhd::gain_group::set_value |
double |
gain, |
name = "" |
Set the gain value for the gain element specified by name. For an empty name, set the overall gain value for this group. The power will be distributed across individual gain elements. The semantics of how to do this are determined by the priority.
- Parameters
| gain | the gain to set for the element or across the group |
