#include <uhd/transport/udp_simple.hpp>
| virtual | ~udp_simple (void)=0 |
| virtual size_t | send (const boost::asio::const_buffer &buff)=0 |
| virtual size_t | recv (const boost::asio::mutable_buffer &buff, double timeout=0.1)=0 |
| virtual std::string | get_recv_addr (void)=0 |
| virtual std::string | get_send_addr (void)=0 |
| static const size_t | mtu = 1500 - 20 - 8 |
|  | The maximum number of bytes per udp packet.  More...
◆ ~udp_simple()
          | virtual uhd::transport::udp_simple::~udp_simple | ( | void |  | ) |  |  | pure virtual |
◆ get_recv_addr()
          | virtual std::string uhd::transport::udp_simple::get_recv_addr | ( | void |  | ) |  |  | pure virtual |
◆ get_send_addr()
          | virtual std::string uhd::transport::udp_simple::get_send_addr | ( | void |  | ) |  |  | pure virtual |
Get the IP address for the destination
◆ make_broadcast()
          | static sptr uhd::transport::udp_simple::make_broadcast | ( | const std::string & | addr, |
          |  |  | const std::string & | port |
          |  | ) |  |  |  | static |
- Parameters
    | addr | a string representing the destination address |  | port | a string representing the destination port |
◆ make_connected()
          | static sptr uhd::transport::udp_simple::make_connected | ( | const std::string & | addr, |
          |  | ) |  |  |  | static |
- Parameters
◆ make_uart()
- Parameters
    | udp | the UDP transport object |
- Returns
- a new UART interface
◆ recv()
          | virtual size_t uhd::transport::udp_simple::recv | ( | const boost::asio::mutable_buffer & | buff, |
          |  |  | double | timeout = 0.1 |
          |  | ) |  |  |  | pure virtual |
- Parameters
    | buff | a mutable buffer to receive into |  | timeout | the timeout in seconds |
- Returns
- the number of bytes received or zero on timeout
◆ send()
          | virtual size_t uhd::transport::udp_simple::send | ( | const boost::asio::const_buffer & | buff | ) |  |  | pure virtual |
- Parameters
- Returns
- the number of bytes sent
◆ mtu
          | const size_t uhd::transport::udp_simple::mtu = 1500 - 20 - 8 |  | static |
