CHDR related function. More...
Functions | |
| UHD_API void | if_hdr_pack_be (uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_unpack_be (const uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_pack_le (uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
| UHD_API void | if_hdr_unpack_le (const uint32_t *packet_buff, if_packet_info_t &if_packet_info) |
See CHDR for details on the CHDR protocol.
All packers take the host format into account. Choose the _le functions if the transport uses little endian format (e.g. PCIe) and the _be functions if the transport uses big endian format (e.g. Ethernet).
Note 1: All packers assume there to be enough space at the address provided by packet_buff. See also Packing contract.
Note 2: All these packers assume the following options without checking them:
if_packet_info.link_type == LINK_TYPE_CHDRif_packet_info.has_cid == falseif_packet_info.has_sid == trueif_packet_info.has_tsi == falseif_packet_info.has_tlr == false This relaxes some of Packing contract, but adds the additional constraint that the input data must be CHDR.In the unpacker, these values will be set accordingly.
| UHD_API void uhd::transport::vrt::chdr::if_hdr_pack_be | ( | uint32_t * | packet_buff, |
| if_packet_info_t & | if_packet_info | ||
Pack a CHDR header from metadata (big endian format).
See Packing contract, but link_type is assumed to be LINK_TYPE_CHDR.
| packet_buff | memory to write the packed vrt header |
| if_packet_info | the if packet info (read/write) |
| UHD_API void uhd::transport::vrt::chdr::if_hdr_pack_le | ( | uint32_t * | packet_buff, |
Pack a CHDR header from metadata (little endian format).
| UHD_API void uhd::transport::vrt::chdr::if_hdr_unpack_be | ( | const uint32_t * | packet_buff, |
Unpack a CHDR header to metadata (big endian format).
See Unpacking contract, but link_type is assumed to be LINK_TYPE_CHDR.
| packet_buff | memory to read the packed vrt header |
| UHD_API void uhd::transport::vrt::chdr::if_hdr_unpack_le | ( | const uint32_t * | packet_buff, |
Unpack a CHDR header to metadata (little endian format).
