pip or easy_install to install Mako from PyPi.Required to check out the repository (not necessary if building from tarballs).
On Windows, install Cygwin with Git support to checkout the repository or install msysGit from http://code.google.com/p/msysgit/downloads/list.
sudo apt-get install libboost-all-dev libusb-1.0-0-dev python-mako doxygen python-docutils cmake build-essential
sudo yum -y install boost-devel libusb1-devel python-mako doxygen python-docutils cmake make gcc gcc-c++
or
sudo dnf -y install boost-devel libusb1-devel python-mako doxygen python-docutils cmake make gcc gcc-c++
The UHD source is stored in a Git repository. To download it, follow these instructions:
git clone git://github.com/EttusResearch/uhd.git
If you also want the FPGA code (which is not necessary for building UHD and applications which depend on it), run:
git clone --recursive git://github.com/EttusResearch/uhd.git
This will populate the fpga-src submodule inside the repository. You can also do this after cloning the repository by running these commands from the top level source directory:
git submodule init git submodule update
Our source code repository contains of two main branches:
$ pybombs install uhd
cd <uhd-repo-path>/host mkdir build cd build cmake ../
-DCMAKE_INSTALL_PREFIX=<install-path>cmake -DLIB_SUFFIX=64Example usage:
make make test sudo make install
sudo ldconfig
When compiling for ARM platforms, the assumption is made that NEON extensions are available if the arm_neon.h header is found. However, this might not be true, e.g., when cross-compiling for an arm7l target (e.g., the Odroid XU4) using a standard SDK. In this case, it's necessary to tell CMake to disable NEON extensions:
cmake -DNEON_SIMD_ENABLE=OFF [...]
<uhd-repo-path>/host.<uhd-repo-path>/host/build.Boost_INCLUDE_DIR should point to the PATH where the Boost .hpp files are, e.g. C:\local\boost_version\boostBoost_LIBRARY_DIR should point to the pre-built libraries, e.g. C:\local\boost_version\lib64-msvc-14.0)<uhd-repo-path>\\host\\build\\ALL_BUILD.vcxproj in visual studio, generate the project. Watch the output console for errors.CMAKE_INSTALL_PREFIX where your user has write privileges, you must close Visual Studio, run it again with Administrator Privileges, and open ALL_BUILD.vcxproj.On Windows, CMake does not have the advantage of pkg-config, so we must manually tell CMake how to locate the LibUSB header and lib.
LIBUSB_INCLUDE_DIRS to the directory with libusb.h.LIBUSB_LIBRARIES to the full path for libusb-1.0.lib.libusb-1.0.lib to simplify runtime dependencies.Note: On Windows, LibUSB v1.0.19 is required to use most USB3 controllers.
cd <uhd-repo-path>\host\build DevEnv uhd.sln /build Release /project ALL_BUILD DevEnv uhd.sln /build Release /project INSTALL
xcode-select --install
sudo port install uhd sudo port uninstall uhd
NOTE: Other package managers (e.g., Fink, HomeBrew) will require different commands than the above to install all dependencies and then remove the UHD install. Please consult the specific package manager in use for how to do these commands properly; they will not be covered here.
$ mkdir build $ cd build $ CC=/usr/bin/llvm-gcc CXX=/usr/bin/llvm-g++ cmake -DCMAKE_INSTALL_PREFIX=/opt/local -DPYTHON_EXECUTABLE=/opt/local/bin/python2.7 -DPYTHON_INCLUDE_DIR=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Headers -DPYTHON_LIBRARY=/opt/local/Library/Frameworks/Python.framework/Versions/2.7/Python ../host $ make
$ make test
To install the build, issue
$ sudo make install
uhd_images_downloader on the command line, or one of these executables (the actual path may differ based on your installation):If your application uses CMake as a build system, the following command will setup up your build environment to link against UHD:
