Public Types | |
| enum | error_code_t { ERROR_CODE_NONE = 0x0, ERROR_CODE_TIMEOUT = 0x1, ERROR_CODE_LATE_COMMAND = 0x2, ERROR_CODE_BROKEN_CHAIN = 0x4, ERROR_CODE_OVERFLOW = 0x8, ERROR_CODE_ALIGNMENT = 0xc, ERROR_CODE_BAD_PACKET = 0xf } |
| rx_metadata_t () | |
| Default constructor. More... | |
| void | reset () |
| Reset values. More... | |
| std::string | to_pp_string (bool compact=true) const |
| std::string | strerror (void) const |
Public Attributes | |
| bool | has_time_spec |
| Has time specification? More... | |
| time_spec_t | time_spec |
| Time of the first sample. More... | |
| bool | more_fragments |
| size_t | fragment_offset |
| bool | start_of_burst |
| Start of burst will be true for the first packet in the chain. More... | |
| bool | end_of_burst |
| End of burst will be true for the last packet in the chain. More... | |
| enum uhd::rx_metadata_t::error_code_t | error_code |
| bool | out_of_sequence |
inline |
inline |
Reset values.
| std::string uhd::rx_metadata_t::strerror | ( | void | ) | const |
Similar to C's strerror() function, creates a std::string describing the error code.
| std::string uhd::rx_metadata_t::to_pp_string | ( | bool | compact = true | ) | const |
Convert a rx_metadata_t into a pretty print string.
| compact | Set to false for a more verbose output. |
| bool uhd::rx_metadata_t::end_of_burst |
| enum uhd::rx_metadata_t::error_code_t uhd::rx_metadata_t::error_code |
| size_t uhd::rx_metadata_t::fragment_offset |
| bool uhd::rx_metadata_t::has_time_spec |
| bool uhd::rx_metadata_t::more_fragments |
| bool uhd::rx_metadata_t::out_of_sequence |
Out of sequence. The transport has either dropped a packet or received data out of order.
| bool uhd::rx_metadata_t::start_of_burst |
| time_spec_t uhd::rx_metadata_t::time_spec |
