uhd::device3 Class Referenceabstract
Extends uhd::device for third-generation USRP devices. More...
#include <uhd/device3.hpp>
Inheritance diagram for uhd::device3:
uhd::device
typedef boost::shared_ptr< device3sptr
- Public Types inherited from uhd::device
enum  device_filter_t { ANY, USRP, CLOCK }
 Device type, used as a filter in make. More...
typedef boost::shared_ptr< devicesptr
typedef boost::function< device_addrs_t(const device_addr_t &)> find_t
typedef boost::function< sptr(const device_addr_t &)> make_t
virtual rfnoc::graph::sptr create_graph (const std::string &name="")=0
void clear ()
bool has_block (const rfnoc::block_id_t &block_id) const
 Checks if an RFNoC block exists on the device. More...
template<typename T >
rfnoc::block_ctrl_base::sptr get_block_ctrl (const rfnoc::block_id_t &block_id) const
 Returns a block controller class for an RFNoC block. More...
boost::shared_ptr< T > get_block_ctrl (const rfnoc::block_id_t &block_id) const
std::vector< rfnoc::block_id_t > find_blocks (const std::string &block_id_hint) const
- Public Member Functions inherited from uhd::device
virtual ~device (void)=0
 Make a new receive streamer from the streamer arguments. More...
 Make a new transmit streamer from the streamer arguments. More...
uhd::property_tree::sptr get_tree (void) const
 Get access to the underlying property structure. More...
device_filter_t get_device_type () const
 Get device type. More...
static sptr make (const device_addr_t &hint, const size_t which=0)
 Same as uhd::device::make(), but will fail if not actually a device3. More...
- Static Public Member Functions inherited from uhd::device
static void register_device (const find_t &find, const make_t &make, const device_filter_t filter)
static device_addrs_t find (const device_addr_t &hint, device_filter_t filter=ANY)
 Find devices attached to the host. More...
static sptr make (const device_addr_t &hint, device_filter_t filter=ANY, size_t which=0)
 Create a new device from the device address hint. More...
Protected Attributes
std::vector< rfnoc::block_ctrl_base::sptr > _rfnoc_block_ctrl
 List of all RFNoC blocks available on this device. More...
boost::mutex _block_ctrl_mutex
 Mutex to protect access to members. More...
- Protected Attributes inherited from uhd::device
uhd::property_tree::sptr _tree
device_filter_t _type
Generation-3 devices are characterized by the following traits:
  • They support RFNoC (RF Network-on-Chip).
  • Data transport uses the compressed VITA (CVITA/CHDR) data format.
typedef boost::shared_ptr<device3> uhd::device3::sptr
◆ clear()
void uhd::device3::clear ( )
Reset blocks after a stream.
TODO write docs
◆ create_graph()
virtual rfnoc::graph::sptr uhd::device3::create_graph ( const std::string &  name = "")
◆ find_blocks() [1/2]
std::vector<rfnoc::block_id_t> uhd::device3::find_blocks ( const std::string &  block_id_hint) const
Returns the block ids of all blocks that match the specified hint Uses block_ctrl_base::match() internally. If no matching block is found, it returns an empty vector.
To access specialized block controller classes (i.e. derived from block_ctrl_base), use the templated version of this function, e.g.
// Assume DEV is a device3::sptr
null_block_ctrl::sptr null_block =
DEV->find_blocks<null_block_ctrl>("NullSrcSink");
Note
this access is not thread safe if peformed during block enumeration
◆ find_blocks() [2/2]
Type-cast version of find_blocks().
◆ get_block_ctrl() [1/2]
rfnoc::block_ctrl_base::sptr uhd::device3::get_block_ctrl ( const rfnoc::block_id_t &  block_id) const
If the given block ID is not valid (i.e. such a block does not exist on this device), it will throw a uhd::lookup_error.
block_idCanonical block name (e.g. "0/FFT_1").
Note
◆ get_block_ctrl() [2/2]
boost::shared_ptr<T> uhd::device3::get_block_ctrl ( const rfnoc::block_id_t &  block_id) const
Same as get_block_ctrl(), but with a type cast.
If you have a block controller class that is derived from block_ctrl_base, use this function to access its specific methods. If the given block ID is not valid (i.e. such a block does not exist on this device) or if the type does not match, it will throw a uhd::lookup_error.
uhd::rfnoc::my_block_ctrl::sptr block_controller =
get_block_ctrl<my_block_ctrl>("0/MyBlock_0");
block_controller->my_own_block_method();
Note
◆ has_block() [1/2]
bool uhd::device3::has_block ( const rfnoc::block_id_t &  block_id) const
true if a block with the specified id exists
Note
◆ has_block() [2/2]
Same as has_block(), but with a type check.
true if a block of type T with the specified id exists
Note
◆ make()
static sptr uhd::device3::make ( const device_addr_t hint,
const size_t  which = 0
◆ _block_ctrl_mutex
boost::mutex uhd::device3::_block_ctrl_mutex
◆ _rfnoc_block_ctrl
std::vector<rfnoc::block_ctrl_base::sptr> uhd::device3::_rfnoc_block_ctrl
