uhd::msg_task Class Referenceabstract
#include <uhd/utils/msg_task.hpp>
Inheritance diagram for uhd::msg_task:
typedef boost::shared_ptr< msg_tasksptr
typedef std::vector< uint8_t > msg_payload_t
typedef std::pair< uint32_t, msg_payload_tmsg_type_t
typedef boost::function< boost::optional< msg_type_t >void)> task_fcn_type
virtual msg_payload_t get_msg_from_dump_queue (uint32_t sid)=0
virtual ~msg_task (void)=0
static UHD_INLINE std::vector< uint8_t > buff_to_vector (uint8_t *p, size_t n)
◆ msg_payload_t
typedef std::vector<uint8_t> uhd::msg_task::msg_payload_t
◆ msg_type_t
typedef std::pair<uint32_t, msg_payload_t> uhd::msg_task::msg_type_t
typedef boost::shared_ptr<msg_task> uhd::msg_task::sptr
◆ task_fcn_type
typedef boost::function<boost::optional<msg_type_t>void)> uhd::msg_task::task_fcn_type
◆ ~msg_task()
virtual uhd::msg_task::~msg_task ( void  )
◆ buff_to_vector()
static UHD_INLINE std::vector<uint8_t> uhd::msg_task::buff_to_vector ( uint8_t *  p,
size_t  n
inlinestatic
◆ get_msg_from_dump_queue()
virtual msg_payload_t uhd::msg_task::get_msg_from_dump_queue ( uint32_t  sid)
◆ make()
static sptr uhd::msg_task::make ( const task_fcn_type task_fcn)
a new task object
