| device_addr_t (const std::string &args="") | |
| device_addr_t (const std::map< std::string, std::string > &info) | |
| std::string | to_pp_string (void) const |
| std::string | to_string (void) const |
| template<typename T > | |
| T | cast (const std::string &key, const T &def) const |
Public Member Functions inherited from uhd::dict< std::string, std::string > | |
| dict (void) | |
| dict (InputIterator first, InputIterator last) | |
| std::size_t | size (void) const |
| std::vector< std::string > | keys (void) const |
| std::vector< std::string > | vals (void) const |
| bool | has_key (const std::string &key) const |
| const std::string & | get (const std::string &key, const std::string &other) const |
| const std::string & | get (const std::string &key) const |
| void | set (const std::string &key, const std::string &val) |
| const std::string & | operator[] (const std::string &key) const |
| std::string & | operator[] (const std::string &key) |
| bool | operator== (const dict< std::string, std::string > &other) const |
| bool | operator!= (const dict< std::string, std::string > &other) const |
| std::string | pop (const std::string &key) |
| void | update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true) |
| uhd::device_addr_t::device_addr_t | ( | const std::string & | args = "" | ) |
| args | the arguments string |
| uhd::device_addr_t::device_addr_t | ( | const std::map< std::string, std::string > & | info | ) |
Create a device address from a std::map
| info | the device info map |
inline |
| key | the key as one of the address parameters |
| def | the value to use when key is not present |
| error | when the parameter cannot be casted |
| std::string uhd::device_addr_t::to_pp_string | ( | void | ) | const |
| std::string uhd::device_addr_t::to_string | ( | void | ) | const |
