| _args | uhd::rfnoc::node_ctrl_base | protected |
| _block_def | uhd::rfnoc::block_ctrl_base | protected |
| _clear(const size_t port=0) | uhd::rfnoc::block_ctrl_base | protectedvirtual |
| _downstream_nodes | uhd::rfnoc::node_ctrl_base | protected |
| _num_input_ports | uhd::rfnoc::node_ctrl_base | protected |
| _num_output_ports | uhd::rfnoc::node_ctrl_base | protected |
| _register_downstream_node(node_ctrl_base::sptr downstream_node, size_t port) | uhd::rfnoc::node_ctrl_base | protectedvirtual |
| _register_upstream_node(node_ctrl_base::sptr upstream_node, size_t port) | uhd::rfnoc::node_ctrl_base | protectedvirtual |
| _resolve_port_def(const blockdef::port_t &port_def) const | uhd::rfnoc::block_ctrl_base | protected |
| _root_path | uhd::rfnoc::block_ctrl_base | protected |
| _rx_streamer_active | uhd::rfnoc::node_ctrl_base | protected |
| _set_command_time(const time_spec_t &time_spec, const size_t port=ANY_PORT) | uhd::rfnoc::block_ctrl_base | protectedvirtual |
| _tree | uhd::rfnoc::block_ctrl_base | protected |
| _tx_streamer_active | uhd::rfnoc::node_ctrl_base | protected |
| _upstream_nodes | uhd::rfnoc::node_ctrl_base | protected |
| block_ctrl_base(void) | uhd::rfnoc::block_ctrl_base | inlineprotected |
| block_ctrl_base(const make_args_t &make_args) | uhd::rfnoc::block_ctrl_base | protected |
| clear() | uhd::rfnoc::block_ctrl_base | virtual |
| clear_command_time(const size_t port) | uhd::rfnoc::block_ctrl_base | |
| disconnect() | uhd::rfnoc::node_ctrl_base | |
| disconnect_input_port(const size_t input_port) | uhd::rfnoc::node_ctrl_base | |
| disconnect_output_port(const size_t output_port) | uhd::rfnoc::node_ctrl_base | |
| find_downstream_node(bool active_only=false) | uhd::rfnoc::node_ctrl_base | inline |
| find_downstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) | uhd::rfnoc::node_ctrl_base | inline |
| find_upstream_node(bool active_only=false) | uhd::rfnoc::node_ctrl_base | inline |
| find_upstream_unique_property(boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) | uhd::rfnoc::node_ctrl_base | inline |
| get_address(size_t block_port=0) | uhd::rfnoc::block_ctrl_base | |
| get_arg(const std::string &key, const size_t port=0) const | uhd::rfnoc::block_ctrl_base | |
| get_arg(const std::string &key, const size_t port=0) const | uhd::rfnoc::block_ctrl_base | inline |
| get_arg_path(const std::string &key, size_t port=0) const | uhd::rfnoc::block_ctrl_base | inlineprotected |
| get_arg_type(const std::string &key, const size_t port=0) const | uhd::rfnoc::block_ctrl_base | |
| get_args(const size_t port=0) const | uhd::rfnoc::block_ctrl_base | |
| get_block_id() const | uhd::rfnoc::block_ctrl_base | inline |
| get_command_time(const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| get_ctrl_iface(const size_t block_port) | uhd::rfnoc::block_ctrl_base | protected |
| get_ctrl_ports() const | uhd::rfnoc::block_ctrl_base | |
| get_downstream_port(const size_t this_port) | uhd::rfnoc::node_ctrl_base | |
| get_upstream_port(const size_t this_port) | uhd::rfnoc::node_ctrl_base | |
| list_downstream_nodes() | uhd::rfnoc::node_ctrl_base | inline |
| list_upstream_nodes() | uhd::rfnoc::node_ctrl_base | inline |
| make(const make_args_t &make_args, uint64_t noc_id=~0) | uhd::rfnoc::block_ctrl_base | static |
| make_t typedef | uhd::rfnoc::block_ctrl_base | |
| node_ctrl_base(void) | uhd::rfnoc::node_ctrl_base | inlineprotected |
| node_map_pair_t typedef | uhd::rfnoc::node_ctrl_base | |
| node_map_t typedef | uhd::rfnoc::node_ctrl_base | |
| register_block(const make_t &make, const std::string &name) | uhd::rfnoc::block_ctrl_base | static |
| set_arg(const std::string &key, const std::string &val, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| set_arg(const std::string &key, const T &val, const size_t port=0) | uhd::rfnoc::block_ctrl_base | inline |
| set_args(const uhd::device_addr_t &args, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| set_command_tick_rate(const double tick_rate, const size_t port=ANY_PORT) | uhd::rfnoc::block_ctrl_base | |
| set_command_time(const time_spec_t &time_spec, const size_t port=ANY_PORT) | uhd::rfnoc::block_ctrl_base | |
| set_downstream_port(const size_t this_port, const size_t remote_port) | uhd::rfnoc::node_ctrl_base | |
| set_upstream_port(const size_t this_port, const size_t remote_port) | uhd::rfnoc::node_ctrl_base | |
| sptr typedef | uhd::rfnoc::block_ctrl_base | |
| sr_read32(const settingsbus_reg_t reg, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| sr_read64(const settingsbus_reg_t reg, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| sr_write(const uint32_t reg, const uint32_t data, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| sr_write(const std::string ®, const uint32_t data, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| unique_id() const | uhd::rfnoc::block_ctrl_base | inlinevirtual |
| user_reg_read32(const uint32_t addr, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| user_reg_read32(const std::string ®, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| user_reg_read64(const uint32_t addr, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| user_reg_read64(const std::string ®, const size_t port=0) | uhd::rfnoc::block_ctrl_base | |
| wptr typedef | uhd::rfnoc::node_ctrl_base | |
| ~block_ctrl_base() | uhd::rfnoc::block_ctrl_base | protectedvirtual |
| ~node_ctrl_base() | uhd::rfnoc::node_ctrl_base | inlineprotectedvirtual |
