#include <uhd/rfnoc/block_ctrl_base.hpp>
Public Types | |
| typedef boost::shared_ptr< block_ctrl_base > | sptr |
| typedef boost::function< sptr(const make_args_t &)> | make_t |
Public Types inherited from uhd::rfnoc::node_ctrl_base | |
| typedef boost::shared_ptr< node_ctrl_base > | sptr |
| typedef boost::weak_ptr< node_ctrl_base > | wptr |
| typedef std::map< size_t, wptr > | node_map_t |
| typedef std::pair< size_t, wptr > | node_map_pair_t |
| uint32_t | get_address (size_t block_port=0) |
| block_id_t | get_block_id () const |
| std::string | unique_id () const |
| std::vector< size_t > | get_ctrl_ports () const |
| void | sr_write (const uint32_t reg, const uint32_t data, const size_t port=0) |
| void | sr_write (const std::string ®, const uint32_t data, const size_t port=0) |
| uint64_t | sr_read64 (const settingsbus_reg_t reg, const size_t port=0) |
| uint32_t | sr_read32 (const settingsbus_reg_t reg, const size_t port=0) |
| uint64_t | user_reg_read64 (const uint32_t addr, const size_t port=0) |
| uint64_t | user_reg_read64 (const std::string ®, const size_t port=0) |
| uint32_t | user_reg_read32 (const uint32_t addr, const size_t port=0) |
| uint32_t | user_reg_read32 (const std::string ®, const size_t port=0) |
| void | set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| time_spec_t | get_command_time (const size_t port=0) |
| void | set_command_tick_rate (const double tick_rate, const size_t port=ANY_PORT) |
| void | clear_command_time (const size_t port) |
| void | clear () |
| void | set_args (const uhd::device_addr_t &args, const size_t port=0) |
| void | set_arg (const std::string &key, const std::string &val, const size_t port=0) |
Set a specific block argument. val is converted to the corresponding. More... | |
| template<typename T > | |
| void | set_arg (const std::string &key, const T &val, const size_t port=0) |
| Direct access to set a block argument. More... | |
| uhd::device_addr_t | get_args (const size_t port=0) const |
| Return all block arguments as a device_addr_t. More... | |
| std::string | get_arg (const std::string &key, const size_t port=0) const |
| Return a single block argument in string format. More... | |
| T | get_arg (const std::string &key, const size_t port=0) const |
| Direct access to get a block argument. More... | |
| std::string | get_arg_type (const std::string &key, const size_t port=0) const |
Public Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_map_t | list_downstream_nodes () |
| node_map_t | list_upstream_nodes () |
| void | disconnect () |
| void | disconnect_output_port (const size_t output_port) |
| void | disconnect_input_port (const size_t input_port) |
| void | set_downstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_downstream_port (const size_t this_port) |
| void | set_upstream_port (const size_t this_port, const size_t remote_port) |
| size_t | get_upstream_port (const size_t this_port) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_downstream_node (bool active_only=false) |
| UHD_INLINE std::vector< boost::shared_ptr< T > > | find_upstream_node (bool active_only=false) |
| template<typename T , typename value_type > | |
| UHD_INLINE value_type | find_downstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| UHD_INLINE value_type | find_upstream_unique_property (boost::function< value_type(boost::shared_ptr< T > node, size_t port)> get_property, value_type null_value, const std::set< boost::shared_ptr< T > > &exclude_nodes=std::set< boost::shared_ptr< T > >()) |
| static void | register_block (const make_t &make, const std::string &name) |
| static sptr | make (const make_args_t &make_args, uint64_t noc_id=~0) |
| Create a block controller class given a NoC-ID or a block name. More... | |
Protected Member Functions | |
| block_ctrl_base (void) | |
| virtual | ~block_ctrl_base () |
| block_ctrl_base (const make_args_t &make_args) | |
| stream_sig_t | _resolve_port_def (const blockdef::port_t &port_def) const |
| uhd::fs_path | get_arg_path (const std::string &key, size_t port=0) const |
Return the property tree path to a block argument key on port. More... | |
| timed_wb_iface::sptr | get_ctrl_iface (const size_t block_port) |
Get a control interface object for block port block_port. More... | |
| virtual void | _clear (const size_t port=0) |
| Override this function if your block does something else. More... | |
| virtual void | _set_command_time (const time_spec_t &time_spec, const size_t port=ANY_PORT) |
| Override this function if your block needs to specially handle. More... | |
Protected Member Functions inherited from uhd::rfnoc::node_ctrl_base | |
| node_ctrl_base (void) | |
| virtual | ~node_ctrl_base () |
| virtual void | _register_downstream_node (node_ctrl_base::sptr downstream_node, size_t port) |
| virtual void | _register_upstream_node (node_ctrl_base::sptr upstream_node, size_t port) |
Protected Attributes | |
| uhd::property_tree::sptr | _tree |
| Property sub-tree. More... | |
| uhd::fs_path | _root_path |
| Root node of this block's properties. More... | |
| blockdef::sptr | _block_def |
| Block definition (stores info about the block such as ports) More... | |
Protected Attributes inherited from uhd::rfnoc::node_ctrl_base | |
| uhd::device_addr_t | _args |
| Stores default arguments. More... | |
| node_map_t | _upstream_nodes |
| List of upstream nodes. More... | |
| node_map_t | _downstream_nodes |
| List of downstream nodes. More... | |
| size_t | _num_input_ports |
| size_t | _num_output_ports |
| std::map< size_t, bool > | _rx_streamer_active |
| std::map< size_t, bool > | _tx_streamer_active |
| typedef boost::function<sptr(const make_args_t&)> uhd::rfnoc::block_ctrl_base::make_t |
| typedef boost::shared_ptr<block_ctrl_base> uhd::rfnoc::block_ctrl_base::sptr |
inlineprotected |
protectedvirtual |
protected |
Constructor. This is only called from the internal block factory!
| make_args | All arguments to this constructor are passed in this object. Its details are subject to change. Use the UHD_RFNOC_BLOCK_CONSTRUCTOR() macro to set up your block's constructor in a portable fashion. |
protectedvirtual |
protected |
protectedvirtual |
virtual |
Reset block after streaming operation.
This does the following:
Internally, rfnoc::node_ctrl_base::clear() and _clear() are called (in that order).
Between runs, it can be necessary to call this method, or blocks might be left hanging in a streaming state, and can get confused when a new application starts.
For custom behaviour, overwrite _clear(). If you do so, you must take take care of resetting flow control yourself.
TODO: Find better name (it disconnects, clears FC...)
Reimplemented from uhd::rfnoc::node_ctrl_base.
| void uhd::rfnoc::block_ctrl_base::clear_command_time | ( | const size_t | port | ) |
Resets the command time. Any command packet after this call will no longer have a time associated with it.
| uhd::assertion_error | if the underlying interface does not actually support timing. |
| uint32_t uhd::rfnoc::block_ctrl_base::get_address | ( | size_t | block_port = 0 | ) |
Returns the 16-Bit address for this block.
| std::string uhd::rfnoc::block_ctrl_base::get_arg | ( | const std::string & | key, |
| const size_t | port = 0 |
| ) | const |
inline |
inlineprotected |
| std::string uhd::rfnoc::block_ctrl_base::get_arg_type | ( | const std::string & | key, |
| ) | const |
| uhd::device_addr_t uhd::rfnoc::block_ctrl_base::get_args | ( | const size_t | port = 0 | ) | const |
inline |
Returns the unique block ID for this block (e.g. "0/FFT_1").
| time_spec_t uhd::rfnoc::block_ctrl_base::get_command_time | ( | const size_t | port = 0 | ) |
Returns the current command time for all future command packets.
protected |
| std::vector<size_t> uhd::rfnoc::block_ctrl_base::get_ctrl_ports | ( | ) | const |
Returns a list of valid ports that can be used for sr_write(), sr_read() etc.
If a block name is given in make_args, it will directly try to generate a block of this type. If no block name is given, it will look up a name using the NoC-ID and use that. If it can't find a suitable block controller class, it will generate a uhd::rfnoc::block_ctrl. However, if a block name is specified, it will throw a uhd::runtime_error if this block type is not registered.
| make_args | Valid make args. |
| noc_id | The 64-Bit NoC-ID. |
Register a block controller class into the discovery and factory system.
Note: It is not recommended to call this function directly. Rather, use the UHD_RFNOC_BLOCK_REGISTER() macro, which will set up the discovery and factory system correctly.
| make | A factory function that makes a block controller object |
| name | A unique block name, e.g. 'FFT'. If a block has this block name, it will use make to generate the block controller class. |
| void uhd::rfnoc::block_ctrl_base::set_arg | ( | const std::string & | key, |
| const std::string & | val, | ||
inline |
| void uhd::rfnoc::block_ctrl_base::set_args | ( | const uhd::device_addr_t & | args, |
Set multiple block args. Calls set_arg() for all individual items.
Note that this function will silently ignore any keys in args that aren't already registered as block arguments.
| void uhd::rfnoc::block_ctrl_base::set_command_tick_rate | ( | const double | tick_rate, |
| const size_t | port = ANY_PORT |
Sets a tick rate for the command timebase.
| tick_rate | The tick rate in Hz |
| port | Port |
| void uhd::rfnoc::block_ctrl_base::set_command_time | ( | const time_spec_t & | time_spec, |
Sets a command time for all future command packets.
| uint32_t uhd::rfnoc::block_ctrl_base::sr_read32 | ( | const settingsbus_reg_t | reg, |
Allows reading one register on the settings bus (32-Bit version).
| reg | The settings register to be read. |
| port | Port on which to read |
Returns the readback value.
| uint64_t uhd::rfnoc::block_ctrl_base::sr_read64 | ( | const settingsbus_reg_t | reg, |
Allows reading one register on the settings bus (64-Bit version).
| void uhd::rfnoc::block_ctrl_base::sr_write | ( | const uint32_t | reg, |
| const uint32_t | data, | ||
Allows setting one register on the settings bus.
Note: There is no address translation ("memory mapping") necessary. Register 0 is 0, 1 is 1 etc.
| reg | The settings register to write to. |
| data | New value of this register. |
| port | Port on which to write |
| void uhd::rfnoc::block_ctrl_base::sr_write | ( | const std::string & | reg, |
Like sr_write(), but takes a register name as argument.
| uhd::key_error | if reg is not a valid register name |
inlinevirtual |
Shorthand for get_block_id().to_string()
| uint32_t uhd::rfnoc::block_ctrl_base::user_reg_read32 | ( | const uint32_t | addr, |
Allows reading one user-defined register (32-Bit version).
This is a shorthand for setting the requested address through sr_write() and then reading SR_READBACK_REG_USER with sr_read32().
| addr | The user register address. |
| uint32_t uhd::rfnoc::block_ctrl_base::user_reg_read32 | ( | const std::string & | reg, |
Identical to user_reg_read32(), but takes a register name instead of a numeric address. The register name must be defined in the block definition file.
| reg | The user register name. |
| port | Destination port. |
| port | Port from which to read |
| uint64_t uhd::rfnoc::block_ctrl_base::user_reg_read64 | ( | const uint32_t | addr, |
Allows reading one user-defined register (64-Bit version).
This is a shorthand for setting the requested address through sr_write() and then reading SR_READBACK_REG_USER with sr_read64().
| uint64_t uhd::rfnoc::block_ctrl_base::user_reg_read64 | ( | const std::string & | reg, |
Identical to user_reg_read64(), but takes a register name instead of a numeric address. The register name must be defined in the block definition file.
| reg | The user register address. |
protected |
protected |
protected |
Property sub-tree.
