#include <uhd/rfnoc/graph.hpp>
| virtual void | connect (const block_id_t &src_block, size_t src_block_port, const block_id_t &dst_block, size_t dst_block_port, const size_t pkt_size=0)=0 |
| virtual void | connect (const block_id_t &src_block, const block_id_t &dst_block)=0 |
| virtual void | connect_src (const block_id_t &src_block, const size_t src_block_port, const uhd::sid_t dst_sid, const size_t buf_size_dst_bytes, const size_t pkt_size_)=0 |
| virtual void | connect_sink (const block_id_t &sink_block, const size_t dst_block_port, const size_t bytes_per_ack)=0 |
| virtual std::string | get_name () const =0 |
◆ sptr
◆ connect() [1/2]
| virtual void uhd::rfnoc::graph::connect |
const block_id_t & |
src_block, |
size_t |
src_block_port, |
dst_block, |
size_t |
dst_block_port, |
const size_t |
pkt_size = 0 |
Connect a RFNOC block with block ID src_block to another with block ID dst_block.
This will:
- Check if this connection is valid (IO signatures, see if types match)
- Configure the flow control for the blocks
- Configure SID for the upstream block
- Register the upstream block in the downstream block
◆ connect() [2/2]
src_block, |
dst_block |
Shorthand for connect().
Using default ports for both source and destination.
◆ connect_sink()
| virtual void uhd::rfnoc::graph::connect_sink |
sink_block, |
const size_t |
dst_block_port, |
const size_t |
bytes_per_ack |
Anonymous connection
Danger, danger. You use this, you know what you're doing.
- Parameters
| sink_block | Sink block ID |
| dst_block_port | Destination (sink) block port |
| bytes_per_ack | Flow control frequency in bytes |
◆ connect_src()
| virtual void uhd::rfnoc::graph::connect_src |
src_block, |
const size_t |
src_block_port, |
const uhd::sid_t |
dst_sid, |
const size_t |
buf_size_dst_bytes, |
const size_t |
pkt_size_ |
Anonymous connection.
- Parameters
| src_block | Source block ID |
| src_block_port | Source block port |
| dst_sid | SID to route traffic to |
| buf_size_dst_bytes | Destination window buffer in bytes |
◆ get_name()
| virtual std::string uhd::rfnoc::graph::get_name |
const |
