uhd::rfnoc::make_args_t Struct Reference
#include <uhd/rfnoc/block_ctrl_base.hpp>
 make_args_t (const std::string &key="")
Public Attributes
std::map< size_t, boost::shared_ptr< ctrl_iface > > ctrl_ifaces
 A valid interface that allows us to read and write registers. More...
uint32_t base_address
 This block's base address (address of block port 0) More...
size_t device_index
 The device index (or motherboard index). More...
uhd::property_tree::sptr tree
 A property tree for this motherboard. Example: If the root a device's. More...
std::string block_name
 The name of the block as it will be addressed. More...
std::string block_key
 The key of the block, i.e. how it was registered. More...
◆ make_args_t()
uhd::rfnoc::make_args_t::make_args_t ( const std::string &  key = "")
◆ base_address
uint32_t uhd::rfnoc::make_args_t::base_address
◆ block_key
std::string uhd::rfnoc::make_args_t::block_key
◆ block_name
std::string uhd::rfnoc::make_args_t::block_name
◆ ctrl_ifaces
std::map<size_t, boost::shared_ptr<ctrl_iface> > uhd::rfnoc::make_args_t::ctrl_ifaces
◆ device_index
size_t uhd::rfnoc::make_args_t::device_index
◆ tree
uhd::property_tree::sptr uhd::rfnoc::make_args_t::tree
