blockdef.hpp
2 // Copyright 2014-2015 Ettus Research LLC
4 //
6 //
7
8 #ifndef INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP
9 #define INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP
10
11 #include <uhd/config.hpp>
13 #include <stdint.h>
14 #include <boost/enable_shared_from_this.hpp>
15 #include <set>
16 #include <vector>
18 namespace uhd { namespace rfnoc {
19
22 class UHD_RFNOC_API blockdef : public boost::enable_shared_from_this<blockdef>
23 {
24 public:
25  typedef boost::shared_ptr<blockdef> sptr;
26
28  //
29  // This is not the same as a uhd::rfnoc::stream_sig_t. This is used
30  // to describe which ports are defined in a block definition, and
31  // to describe what kind of connection is allowed for this port.
32  //
33  // All the keys listed in PORT_ARGS will be available in this class.
34  class port_t : public uhd::dict<std::string, std::string>
35  {
36  public:
38  static const device_addr_t PORT_ARGS;
39
40  port_t();
41
43  bool is_variable(const std::string& key) const;
45  bool is_keyword(const std::string& key) const;
47  // keywords are not resolved.
48  bool is_valid() const;
50  std::string to_string() const;
51  };
52  typedef std::vector<port_t> ports_t;
53
55  class arg_t : public uhd::dict<std::string, std::string>
56  {
57  public:
59  static const device_addr_t ARG_ARGS;
60  static const std::set<std::string> VALID_TYPES;
61
62  arg_t();
63
65  bool is_valid() const;
67  std::string to_string() const;
68  };
69  typedef std::vector<arg_t> args_t;
70
72
79  static sptr make_from_noc_id(uint64_t noc_id);
80
82  virtual bool is_block() const = 0;
83
85  virtual bool is_component() const = 0;
86
88  virtual std::string get_key() const = 0;
89
91  virtual std::string get_name() const = 0;
92
94  virtual uint64_t noc_id() const = 0;
95
96  virtual ports_t get_input_ports() = 0;
97  virtual ports_t get_output_ports() = 0;
98
100  virtual std::vector<size_t> get_all_port_numbers() = 0;
101
103  //
104  // \throws uhd::runtime_error if args are invalid.
105  virtual args_t get_args() = 0;
106
108  virtual registers_t get_settings_registers() = 0;
109
111  virtual registers_t get_readback_registers() = 0;
112 };
113
114 }} /* namespace uhd::rfnoc */
115
116 #endif /* INCLUDED_LIBUHD_RFNOC_BLOCKDEF_HPP */
Definition: blockdef.hpp:22
uhd::dict< std::string, size_t > registers_t
Definition: blockdef.hpp:71
Definition: dict.hpp:21
static const std::set< std::string > VALID_TYPES
Definition: blockdef.hpp:60
std::vector< arg_t > args_t
Definition: blockdef.hpp:69
Definition: build_info.hpp:13
#define UHD_RFNOC_API
Definition: config.hpp:117
boost::shared_ptr< blockdef > sptr
Definition: blockdef.hpp:25
Describes port options for a block definition.
Definition: blockdef.hpp:34
A list of args a port can have.
Definition: blockdef.hpp:38
A list of args an argument can have.
Definition: blockdef.hpp:59
Describes arguments in a block definition.
Definition: blockdef.hpp:55
std::vector< port_t > ports_t
Definition: blockdef.hpp:52
