uhd::rfnoc::blockdef::port_t Class Reference
Describes port options for a block definition. More...
#include <uhd/rfnoc/blockdef.hpp>
Inheritance diagram for uhd::rfnoc::blockdef::port_t:
 port_t ()
bool is_variable (const std::string &key) const
 Checks if the value at key is a variable (e.g. '$fftlen') More...
bool is_keyword (const std::string &key) const
 Checks if the value at key is a keyword (e.g. 'vlen') More...
bool is_valid () const
 Basic validity check of this port definition. Variables and. More...
std::string to_string () const
 Returns a string with the most important keys. More...
 dict (void)
std::size_t size (void) const
bool operator== (const dict< std::string, std::string > &other) const
bool operator!= (const dict< std::string, std::string > &other) const
void update (const dict< std::string, std::string > &new_dict, bool fail_on_conflict=true)
 operator std::map< std::string, std::string > () const
static const device_addr_t PORT_ARGS
 A list of args a port can have. More...
◆ port_t()
uhd::rfnoc::blockdef::port_t::port_t ( )
◆ is_keyword()
bool uhd::rfnoc::blockdef::port_t::is_keyword ( const std::string &  key) const
◆ is_valid()
bool uhd::rfnoc::blockdef::port_t::is_valid ( ) const
◆ is_variable()
bool uhd::rfnoc::blockdef::port_t::is_variable ( const std::string &  key) const
◆ to_string()
std::string uhd::rfnoc::blockdef::port_t::to_string ( ) const
◆ PORT_ARGS
const device_addr_t uhd::rfnoc::blockdef::port_t::PORT_ARGS
