uhd::rfnoc::graph Class Referenceabstract
#include <uhd/rfnoc/graph.hpp>
Inheritance diagram for uhd::rfnoc::graph:
typedef boost::shared_ptr< uhd::rfnoc::graph > sptr
virtual void connect (const block_id_t &src_block, size_t src_block_port, const block_id_t &dst_block, size_t dst_block_port, const size_t pkt_size=0)=0
virtual void connect (const block_id_t &src_block, const block_id_t &dst_block)=0
virtual void connect_src (const block_id_t &src_block, const size_t src_block_port, const uhd::sid_t dst_sid, const size_t buf_size_dst_bytes, const size_t pkt_size)=0
virtual void connect_sink (const block_id_t &sink_block, const size_t dst_block_port, const size_t bytes_per_ack)=0
virtual std::string get_name () const =0
typedef boost::shared_ptr<uhd::rfnoc::graph> uhd::rfnoc::graph::sptr
◆ connect() [1/2]
virtual void uhd::rfnoc::graph::connect ( const block_id_t &  src_block,
const block_id_t &  dst_block,
const size_t  pkt_size = 0
Connect a RFNOC block with block ID src_block to another with block ID dst_block.
This will:
  • Check if this connection is valid (IO signatures, see if types match)
  • Configure the flow control for the blocks
  • Configure SID for the upstream block
  • Register the upstream block in the downstream block
◆ connect() [2/2]
Shorthand for connect().
Using default ports for both source and destination.
◆ connect_sink()
virtual void uhd::rfnoc::graph::connect_sink ( const block_id_t &  sink_block,
Anonymous connection
Danger, danger. You use this, you know what you're doing.
sink_blockSink block ID
dst_block_portDestination (sink) block port
bytes_per_ackFlow control frequency in bytes
◆ connect_src()
virtual void uhd::rfnoc::graph::connect_src ( const block_id_t &  src_block,
Anonymous connection.
src_blockSource block ID
src_block_portSource block port
dst_sidSID to route traffic to
buf_size_dst_bytesDestination window buffer in bytes
pkt_sizeHint what the packet size over this link will be
◆ get_name()
virtual std::string uhd::rfnoc::graph::get_name ( ) const
