uhd::task Class Reference
#include <uhd/utils/tasks.hpp>
typedef boost::shared_ptr< task > sptr
static sptr make (const task_fcn_type &task_fcn, const std::string &name="")
◆ task_fcn_type
◆ make()
static sptr uhd::task::make ( const task_fcn_type &  task_fcn,
const std::string &  name = ""
Create a new task object with function callback. The task function callback will be run in a loop. until the thread is interrupted by the destructor.
A task should return in a reasonable amount of time. It may not block, or the destructor will also block.
nameTask name. Will be used as a thread name.
a new task object
