uhd::transport::usb_control Class Referenceabstract
#include <uhd/transport/usb_control.hpp>
Inheritance diagram for uhd::transport::usb_control:
typedef boost::shared_ptr< usb_control > sptr
virtual ~usb_control (void)
virtual int submit (uint8_t request_type, uint8_t request, uint16_t value, uint16_t index, unsigned char *buff, uint16_t length, uint32_t timeout=0)=0
static sptr make (usb_device_handle::sptr handle, const int interface)
typedef boost::shared_ptr<usb_control> uhd::transport::usb_control::sptr
◆ ~usb_control()
virtual uhd::transport::usb_control::~usb_control ( void  )
virtual
◆ make()
static sptr uhd::transport::usb_control::make ( usb_device_handle::sptr  handle,
const int  interface
Create a new USB control transport: This transport is for sending and receiving control information from the host to device using the Default Control Pipe.
handlea device handle that uniquely identifies a USB device
interfacethe USB interface number for the control transport
◆ submit()
virtual int uhd::transport::usb_control::submit ( uint8_t  request_type,
uint8_t  request,
uint16_t  value,
uint16_t  index,
unsigned char *  buff,
uint16_t  length,
uint32_t  timeout = 0
Submit a USB device request: Blocks until the request returns
For format and corresponding USB request fields see USB Specification Revision 2.0 - 9.3 USB Device Requests
Usage is device specific
request_type1-byte bitmask (bmRequestType)
request1-byte (bRequest)
value2-byte (wValue)
index2-byte (wIndex)
buffbuffer to hold send or receive data
length2-byte (wLength)
timeout4-byte (timeout, default is infinite wait)
number of bytes submitted or error code
