ranges.h File Reference
#include <uhd/config.h>
#include <uhd/error.h>
#include <stdbool.h>
#include <stdlib.h>
Classes
struct  uhd_range_t
 Range of floating-point values. More...
Typedefs
typedef struct uhd_meta_range_t * uhd_meta_range_handle
 C-level interface for dealing with a list of ranges. More...
Functions
UHD_API uhd_error uhd_range_to_pp_string (const uhd_range_t *range, char *pp_string_out, size_t strbuffer_len)
 Get a string representation of the given range. More...
UHD_API uhd_error uhd_meta_range_make (uhd_meta_range_handle *h)
 Create a meta range handle. More...
UHD_API uhd_error uhd_meta_range_free (uhd_meta_range_handle *h)
 Destroy a meta range handle. More...
UHD_API uhd_error uhd_meta_range_start (uhd_meta_range_handle h, double *start_out)
 Get the overall start value for the given meta range. More...
UHD_API uhd_error uhd_meta_range_stop (uhd_meta_range_handle h, double *stop_out)
 Get the overall stop value for the given meta range. More...
UHD_API uhd_error uhd_meta_range_step (uhd_meta_range_handle h, double *step_out)
 Get the overall step value for the given meta range. More...
UHD_API uhd_error uhd_meta_range_clip (uhd_meta_range_handle h, double value, bool clip_step, double *result_out)
 Clip the given value to a possible value in the given range. More...
UHD_API uhd_error uhd_meta_range_size (uhd_meta_range_handle h, size_t *size_out)
 Get the number of ranges in the given meta range. More...
UHD_API uhd_error uhd_meta_range_push_back (uhd_meta_range_handle h, const uhd_range_t *range)
 Add a range to the given meta range. More...
UHD_API uhd_error uhd_meta_range_at (uhd_meta_range_handle h, size_t num, uhd_range_t *range_out)
 Get the range at the given index. More...
UHD_API uhd_error uhd_meta_range_to_pp_string (uhd_meta_range_handle h, char *pp_string_out, size_t strbuffer_len)
 Get a string representation of the given meta range. More...
UHD_API uhd_error uhd_meta_range_last_error (uhd_meta_range_handle h, char *error_out, size_t strbuffer_len)
 Get the last error recorded by the underlying meta range. More...
Typedef Documentation
◆ uhd_meta_range_handle
typedef struct uhd_meta_range_t* uhd_meta_range_handle
See uhd::meta_range_t for more details.
Function Documentation
◆ uhd_meta_range_at()
UHD_API uhd_error uhd_meta_range_at ( uhd_meta_range_handle  h,
size_t  num,
uhd_range_t *  range_out
◆ uhd_meta_range_clip()
UHD_API uhd_error uhd_meta_range_clip ( uhd_meta_range_handle  h,
double  value,
bool  clip_step,
double *  result_out
◆ uhd_meta_range_free()
UHD_API uhd_error uhd_meta_range_free ( uhd_meta_range_handle *  h)
NOTE: Using a uhd_meta_range_handle after passing it into this function will result in a segmentation fault.
◆ uhd_meta_range_last_error()
UHD_API uhd_error uhd_meta_range_last_error ( uhd_meta_range_handle  h,
char *  error_out,
◆ uhd_meta_range_make()
UHD_API uhd_error uhd_meta_range_make ( uhd_meta_range_handle *  h)
NOTE: Using a uhd_meta_range_handle before passing it into this function will result in undefined behavior.
◆ uhd_meta_range_push_back()
UHD_API uhd_error uhd_meta_range_push_back ( uhd_meta_range_handle  h,
const uhd_range_t *  range
◆ uhd_meta_range_size()
UHD_API uhd_error uhd_meta_range_size ( uhd_meta_range_handle  h,
size_t *  size_out
◆ uhd_meta_range_start()
UHD_API uhd_error uhd_meta_range_start ( uhd_meta_range_handle  h,
double *  start_out
◆ uhd_meta_range_step()
UHD_API uhd_error uhd_meta_range_step ( uhd_meta_range_handle  h,
double *  step_out
◆ uhd_meta_range_stop()
UHD_API uhd_error uhd_meta_range_stop ( uhd_meta_range_handle  h,
double *  stop_out
◆ uhd_meta_range_to_pp_string()
UHD_API uhd_error uhd_meta_range_to_pp_string ( uhd_meta_range_handle  h,
char *  pp_string_out,
◆ uhd_range_to_pp_string()
UHD_API uhd_error uhd_range_to_pp_string ( const uhd_range_t *  range,
