uhd::transport::tcp_zero_copy Struct Reference
#include <uhd/transport/tcp_zero_copy.hpp>
Inheritance diagram for uhd::transport::tcp_zero_copy:
uhd::transport::zero_copy_if
virtual ~tcp_zero_copy (void)
- Public Member Functions inherited from uhd::transport::zero_copy_if
virtual ~zero_copy_if ()
static zero_copy_if::sptr make (const std::string &addr, const std::string &port, const device_addr_t &hints=device_addr_t())
- Public Types inherited from uhd::transport::zero_copy_if
typedef boost::shared_ptr< zero_copy_if > sptr
The zero copy TCP transport. This transport provides the uhd zero copy interface on top of a standard tcp socket from boost asio.
◆ ~tcp_zero_copy()
virtual uhd::transport::tcp_zero_copy::~tcp_zero_copy ( void  )
virtual
◆ make()
static zero_copy_if::sptr uhd::transport::tcp_zero_copy::make ( const std::string &  addr,
const std::string &  port,
const device_addr_t &  hints = device_addr_t()
Make a new zero copy TCP transport: This transport is for sending and receiving between this host and a single endpoint. The primary usage for this transport will be data transactions.
hintsoptional parameters to pass to the underlying transport
