#include <uhd/transport/vrt_if_packet.hpp>
Public Types | |
enum | link_type_t { LINK_TYPE_NONE = 0x0, LINK_TYPE_CHDR = 0x1, LINK_TYPE_VRLP = 0x2 } |
enum | packet_type_t { PACKET_TYPE_DATA = 0x0, PACKET_TYPE_IF_EXT = 0x1, PACKET_TYPE_CONTEXT = 0x2, PACKET_TYPE_FC = 0x1, PACKET_TYPE_ACK = 0x1, PACKET_TYPE_CMD = 0x2, PACKET_TYPE_RESP = 0x3, PACKET_TYPE_ERROR } |
if_packet_info_t (void) | |
Public Attributes | |
enum uhd::transport::vrt::if_packet_info_t::link_type_t | link_type |
enum uhd::transport::vrt::if_packet_info_t::packet_type_t | packet_type |
size_t | num_payload_words32 |
size_t | num_payload_bytes |
size_t | num_header_words32 |
size_t | num_packet_words32 |
size_t | packet_count |
bool | sob |
Asserted for start- or end-of-burst. More... | |
bool | eob |
bool | error |
This is asserted for command responses that are errors (CHDR only) More... | |
bool | fc_ack |
This is asserted for flow control packets are ACKS (CHDR only) More... | |
bool | has_sid |
Stream ID (SID). See uhd::sid_t. More... | |
uint32_t | sid |
bool | has_cid |
Class ID. More... | |
uint64_t | cid |
bool | has_tsi |
Integer timestamp. More... | |
uint32_t | tsi |
bool | has_tsf |
Fractional timestamp. More... | |
uint64_t | tsf |
bool | has_tlr |
Trailer. More... | |
uint32_t | tlr |
Definition for fields that can be packed into a vrt if header. The size fields are used for input and output depending upon the operation used (ie the pack or unpack function call).
UHD_INLINE uhd::transport::vrt::if_packet_info_t::if_packet_info_t | ( | void | ) |
uint64_t uhd::transport::vrt::if_packet_info_t::cid |
bool uhd::transport::vrt::if_packet_info_t::eob |
bool uhd::transport::vrt::if_packet_info_t::error |
bool uhd::transport::vrt::if_packet_info_t::fc_ack |
bool uhd::transport::vrt::if_packet_info_t::has_cid |
Class ID.
bool uhd::transport::vrt::if_packet_info_t::has_sid |
bool uhd::transport::vrt::if_packet_info_t::has_tlr |
Trailer.
bool uhd::transport::vrt::if_packet_info_t::has_tsf |
bool uhd::transport::vrt::if_packet_info_t::has_tsi |
Integer timestamp.
enum uhd::transport::vrt::if_packet_info_t::link_type_t uhd::transport::vrt::if_packet_info_t::link_type |
size_t uhd::transport::vrt::if_packet_info_t::num_header_words32 |
size_t uhd::transport::vrt::if_packet_info_t::num_packet_words32 |
size_t uhd::transport::vrt::if_packet_info_t::num_payload_bytes |
size_t uhd::transport::vrt::if_packet_info_t::num_payload_words32 |
size_t uhd::transport::vrt::if_packet_info_t::packet_count |
enum uhd::transport::vrt::if_packet_info_t::packet_type_t uhd::transport::vrt::if_packet_info_t::packet_type |
uint32_t uhd::transport::vrt::if_packet_info_t::sid |
bool uhd::transport::vrt::if_packet_info_t::sob |
uint32_t uhd::transport::vrt::if_packet_info_t::tlr |
uint64_t uhd::transport::vrt::if_packet_info_t::tsf |
uint32_t uhd::transport::vrt::if_packet_info_t::tsi |
