build_info.hpp File Reference
#include <uhd/config.hpp>
#include <string>
Namespaces
namespace  uhd
namespace  uhd::build_info
Functions
UHD_API const std::string uhd::build_info::boost_version ()
 Return the version of Boost this build was built with. More...
UHD_API const std::string uhd::build_info::build_date ()
 Return the date and time (GMT) this UHD build was built. More...
UHD_API const std::string uhd::build_info::c_compiler ()
 Return the C compiler used for this build. More...
UHD_API const std::string uhd::build_info::cxx_compiler ()
 Return the C++ compiler used for this build. More...
UHD_API const std::string uhd::build_info::c_flags ()
 Return the C flags passed into this build. More...
UHD_API const std::string uhd::build_info::cxx_flags ()
 Return the C++ flags passed into this build. More...
UHD_API const std::string uhd::build_info::enabled_components ()
 Return the UHD components enabled for this build, comma-delimited. More...
UHD_API const std::string uhd::build_info::install_prefix ()
 Return the default CMake install prefix for this build. More...
UHD_API const std::string uhd::build_info::libusb_version ()
 Return the version of libusb this build was built with. More...
