uhd::gps_ctrl Class Referenceabstract
#include <uhd/usrp/gps_ctrl.hpp>
Inheritance diagram for uhd::gps_ctrl:
typedef std::shared_ptr< gps_ctrlsptr
virtual ~gps_ctrl (void)=0
virtual std::vector< std::string > get_sensors (void)=0
virtual uhd::sensor_value_t get_sensor (std::string key)=0
virtual bool gps_detected (void)=0
static sptr make (uart_iface::sptr uart)
typedef std::shared_ptr<gps_ctrl> uhd::gps_ctrl::sptr
◆ ~gps_ctrl()
virtual uhd::gps_ctrl::~gps_ctrl ( void  )
◆ get_sensor()
virtual uhd::sensor_value_t uhd::gps_ctrl::get_sensor ( std::string  key)
Retrieve the named sensor
◆ get_sensors()
virtual std::vector< std::string > uhd::gps_ctrl::get_sensors ( void  )
Retrieve the list of sensors this GPS object provides
◆ gps_detected()
virtual bool uhd::gps_ctrl::gps_detected ( void  )
Tell you if there's a supported GPS connected or not
true if a supported GPS is connected
◆ make()
static sptr uhd::gps_ctrl::make ( uart_iface::sptr  uart)
Make a GPS config for internal GPSDOs or generic NMEA GPS devices
