◆ ctrl_payload() [1/3]
          | uhd::rfnoc::chdr::ctrl_payload::ctrl_payload  |
default   |
◆ ctrl_payload() [2/3]
          const ctrl_payload &  |
          rhs | ) |
default   |
◆ ctrl_payload() [3/3]
          ctrl_payload &&  |
          rhs | ) |
default   |
◆ deserialize() [1/2]
          | void uhd::rfnoc::chdr::ctrl_payload::deserialize  |
          const uint64_t *  |
          buff,  |
          size_t  |
          num_elems  |
inline   |
Deserialize the payload from a uint64_t buffer (no conversion function)
◆ deserialize() [2/2]
          const uint64_t *  |
          buff,  |
          size_t  |
          num_elems,  |
          const std::function< uint64_t(uint64_t)> &  |
          conv_byte_order  |
Deserialize the payload from a uint64_t buffer.
◆ get_length()
          | size_t uhd::rfnoc::chdr::ctrl_payload::get_length  |
           const |
Get the serialized size of this payload in 64 bit words.
◆ has_timestamp()
          | bool uhd::rfnoc::chdr::ctrl_payload::has_timestamp  |
           const |
inline   |
◆ operator!=()
          | bool uhd::rfnoc::chdr::ctrl_payload::operator!=  |
          rhs | ) |
           const |
inline   |
◆ operator=()
◆ operator==()
          | bool uhd::rfnoc::chdr::ctrl_payload::operator==  |
          rhs | ) |
           const |
◆ populate_header()
          | void uhd::rfnoc::chdr::ctrl_payload::populate_header  |
          chdr_header &  |
          header | ) |
           const |
Populate the header for this type of packet.
◆ serialize() [1/2]
          | size_t uhd::rfnoc::chdr::ctrl_payload::serialize  |
          uint64_t *  |
          buff,  |
          size_t  |
          max_size_bytes  |
           |  const |
inline   |
Serialize the payload to a uint64_t buffer (no conversion function)
◆ serialize() [2/2]
          uint64_t *  |
          buff,  |
          size_t  |
          max_size_bytes,  |
          conv_byte_order  |
           |  const |
Serialize the payload to a uint64_t buffer.
◆ to_string()
          | const std::string uhd::rfnoc::chdr::ctrl_payload::to_string  |
           const |
Return a string representation of this object.
◆ address
          | uint32_t uhd::rfnoc::chdr::ctrl_payload::address = 0 |
Address for transaction (20 bits)
◆ byte_enable
          | uint8_t uhd::rfnoc::chdr::ctrl_payload::byte_enable = 0xF |
Byte-enable mask for transaction (4 bits)
◆ data_vtr
          | std::vector<uint32_t> uhd::rfnoc::chdr::ctrl_payload::data_vtr = {0} |
Data for transaction (vector of 32 bits)
◆ dst_port
          | uint16_t uhd::rfnoc::chdr::ctrl_payload::dst_port = 0 |
Destination port for transaction (10 bits)
◆ is_ack
          | bool uhd::rfnoc::chdr::ctrl_payload::is_ack = false |
Is Acknowledgment Flag (1 bit)
◆ op_code
◆ seq_num
          | uint8_t uhd::rfnoc::chdr::ctrl_payload::seq_num = 0 |
◆ src_epid
          | uint16_t uhd::rfnoc::chdr::ctrl_payload::src_epid = 0 |
Source endpoint ID of transaction (16 bits)
◆ src_port
          | uint16_t uhd::rfnoc::chdr::ctrl_payload::src_port = 0 |
Source port for transaction (10 bits)
◆ status
Transaction status (4 bits)
◆ timestamp
          | boost::optional<uint64_t> uhd::rfnoc::chdr::ctrl_payload::timestamp = boost::none |
Has Time Flag (1 bit) and timestamp (64 bits)
