uhd::rfnoc::chdr::strc_payload Class Reference
 strc_payload ()=default
 strc_payload (const strc_payload &rhs)=default
 strc_payload (strc_payload &&rhs)=default
strc_payloadoperator= (const strc_payload &rhs)=default
void populate_header (chdr_header &header) const
 Populate the header for this type of packet. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes, const std::function< uint64_t(uint64_t)> &conv_byte_order) const
 Serialize the payload to a uint64_t buffer. More...
size_t serialize (uint64_t *buff, size_t max_size_bytes) const
 Serialize the payload to a uint64_t buffer (no conversion function) More...
void deserialize (const uint64_t *buff, size_t num_elems, const std::function< uint64_t(uint64_t)> &conv_byte_order)
 Deserialize the payload from a uint64_t buffer. More...
void deserialize (const uint64_t *buff, size_t num_elems)
 Deserialize the payload from a uint64_t buffer (no conversion function) More...
size_t get_length () const
 Get the serialized size of this payload in 64 bit words. More...
bool operator== (const strc_payload &rhs) const
 Comparison operator (==) More...
bool operator!= (const strc_payload &rhs) const
 Comparison operator (!=) More...
const std::string to_string () const
 Return a string representation of this object. More...
Public Attributes
uint16_t src_epid = 0
 The source EPID for the stream (16 bits) More...
strc_op_code_t op_code = STRC_INIT
 Operation code for the command (4 bits) More...
uint8_t op_data = 0
 Data associated with the operation (4 bits) More...
uint64_t num_pkts = 0
 Number of packets to use for operation (40 bits) More...
uint64_t num_bytes = 0
 Number of bytes to use for operation (64 bits) More...
static constexpr size_t MAX_PACKET_SIZE = 128
 Worst-case size of a strc packet (including header) More...
◆ strc_payload() [1/3]
uhd::rfnoc::chdr::strc_payload::strc_payload ( )
default
◆ strc_payload() [2/3]
uhd::rfnoc::chdr::strc_payload::strc_payload ( const strc_payload rhs)
default
◆ strc_payload() [3/3]
uhd::rfnoc::chdr::strc_payload::strc_payload ( strc_payload &&  rhs)
default
◆ deserialize() [1/2]
void uhd::rfnoc::chdr::strc_payload::deserialize ( const uint64_t *  buff,
size_t  num_elems
◆ deserialize() [2/2]
size_t  num_elems,
const std::function< uint64_t(uint64_t)> &  conv_byte_order
◆ get_length()
size_t uhd::rfnoc::chdr::strc_payload::get_length ( ) const
◆ operator!=()
bool uhd::rfnoc::chdr::strc_payload::operator!= ( const strc_payload rhs) const
◆ operator=()
strc_payload & uhd::rfnoc::chdr::strc_payload::operator= ( const strc_payload rhs)
default
◆ operator==()
bool uhd::rfnoc::chdr::strc_payload::operator== ( const strc_payload rhs) const
◆ populate_header()
void uhd::rfnoc::chdr::strc_payload::populate_header ( chdr_header header) const
◆ serialize() [1/2]
size_t uhd::rfnoc::chdr::strc_payload::serialize ( uint64_t *  buff,
) const
◆ serialize() [2/2]
) const
◆ to_string()
const std::string uhd::rfnoc::chdr::strc_payload::to_string ( ) const
◆ MAX_PACKET_SIZE
constexpr size_t uhd::rfnoc::chdr::strc_payload::MAX_PACKET_SIZE = 128
staticconstexpr
◆ num_bytes
uint64_t uhd::rfnoc::chdr::strc_payload::num_bytes = 0
◆ num_pkts
uint64_t uhd::rfnoc::chdr::strc_payload::num_pkts = 0
◆ op_code
strc_op_code_t uhd::rfnoc::chdr::strc_payload::op_code = STRC_INIT
◆ op_data
uint8_t uhd::rfnoc::chdr::strc_payload::op_data = 0
◆ src_epid
uint16_t uhd::rfnoc::chdr::strc_payload::src_epid = 0
