#include <uhd/rfnoc/mb_controller.hpp>
Classes | |
| class | timekeeper |
Public Types | |
| using | sptr = std::shared_ptr< mb_controller > |
| virtual | ~mb_controller () |
| size_t | get_num_timekeepers () const |
| Returns the number of timekeepers, which equals the number of timebases. More... | |
| timekeeper::sptr | get_timekeeper (const size_t tk_idx) const |
Return a reference to the tk_idx-th timekeeper on this motherboard. More... | |
| virtual void | init () |
| virtual std::string | get_mboard_name () const =0 |
| virtual void | set_time_source (const std::string &source)=0 |
| virtual std::string | get_time_source () const =0 |
| virtual std::vector< std::string > | get_time_sources () const =0 |
| virtual void | set_clock_source (const std::string &source)=0 |
| virtual std::string | get_clock_source () const =0 |
| virtual std::vector< std::string > | get_clock_sources () const =0 |
| virtual void | set_sync_source (const std::string &clock_source, const std::string &time_source)=0 |
| virtual void | set_sync_source (const uhd::device_addr_t &sync_source)=0 |
| virtual uhd::device_addr_t | get_sync_source () const =0 |
| virtual std::vector< uhd::device_addr_t > | get_sync_sources ()=0 |
| virtual void | set_clock_source_out (const bool enb)=0 |
| virtual void | set_time_source_out (const bool enb)=0 |
| virtual uhd::sensor_value_t | get_sensor (const std::string &name)=0 |
| virtual std::vector< std::string > | get_sensor_names ()=0 |
| virtual uhd::usrp::mboard_eeprom_t | get_eeprom ()=0 |
| virtual bool | synchronize (std::vector< mb_controller::sptr > &mb_controllers, const uhd::time_spec_t &time_spec=uhd::time_spec_t(0.0), const bool quiet=false) |
| virtual std::vector< std::string > | get_gpio_banks () const |
| virtual std::vector< std::string > | get_gpio_srcs (const std::string &bank) const |
| virtual std::vector< std::string > | get_gpio_src (const std::string &bank) |
| virtual void | set_gpio_src (const std::string &bank, const std::vector< std::string > &src) |
Protected Member Functions | |
| void | register_timekeeper (const size_t idx, timekeeper::sptr tk) |
A default block controller for blocks that can't be found in the registry
| using uhd::rfnoc::mb_controller::sptr = std::shared_ptr<mb_controller> |
inlinevirtual |
Get the currently set clock source
Get a list of possible clock sources
Return the motherboard EEPROM data
virtual |
Return the list of GPIO banks that are controlled by this MB controller
Note that this list may be empty. Only if the MB controller has any control over GPIOs, do the get listed here.
virtual |
Return the current sources for a given GPIO bank
virtual |
Return a list of possible sources to drive GPIOs
Sources can be "PS", for when an embedded device can drive the pins from software, "Radio#0", if a radio block can drive them, and so on.
Get canonical name for this USRP motherboard
| size_t uhd::rfnoc::mb_controller::get_num_timekeepers | ( | ) | const |
Get a motherboard sensor value
| name | the name of the sensor |
Get a list of possible motherboard sensor names
Get the currently set sync source
Get a list of available sync sources
Get the currently set time source
Get a list of possible time sources.
| timekeeper::sptr uhd::rfnoc::mb_controller::get_timekeeper | ( | const size_t | tk_idx | ) | const |
inlinevirtual |
Run initializations of this motherboard that have to occur post-block init
protected |
Stash away a timekeeper. This needs to be called by the implementer of mb_controller.
Set the clock source for the USRP device
This sets the source of the frequency reference, typically a 10 MHz signal. In order to frequency-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same clock source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_clock_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the time source when the clock source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
This function does not force a re-initialization of the underlying hardware when the value does not change. Consider the following snippet:
See also:
| source | a string representing the time source |
| uhd::value_error | if source is an invalid option |
Send the clock source to an output connector
This call is only applicable on devices with reference outputs. By default, the reference output will be enabled for ease of use. This call may be used to enable or disable the output.
| enb | true to output the clock source. |
virtual |
Set the source for GPIO pins on a given bank.
| uhd::key_error | if the bank does not exist |
| uhd::value_error | if the source does not exist |
| uhd::not_implemented_error | if the current motherboard does not support this feature |
Set the reference/synchronization sources for the USRP device
This is a shorthand for calling set_sync_source(device_addr_t("clock_source=$CLOCK_SOURCE,time_source=$TIME_SOURCE"))
| clock_source | A string representing the clock source |
| time_source | A string representing the time source |
| uhd::value_error | if the sources don't actually exist |
Typically, this will set both clock and time source in a single call. For some USRPs, this may be significantly faster than calling set_time_source() and set_clock_source() individually.
Example:
This function does not force a re-initialization of the underlying hardware when the value does not change. See also set_time_source() and set_clock_source() for more details.
| sync_source | A dictionary representing the various source settings. |
| uhd::value_error | if the sources don't actually exist or if the combination of clock and time source is invalid. |
Set the time source for the USRP device
This sets the method of time synchronization, typically a pulse per second signal. In order to time-align multiple USRPs, it is necessary to connect all of them to a common reference and provide them with the same time source. Typical values for source are 'internal', 'external'. Refer to the specific device manual for a full list of options.
If the value for for source is not available for this device, it will throw an exception. Calling get_time_sources() will return a valid list of options for this method.
Side effects: Some devices only support certain combinations of time and clock source. It is possible that the underlying device implementation will change the clock source when the time source changes and vice versa. Reading back the current values of clock and time source using get_clock_source() and get_time_source() is the only certain way of knowing which clock and time source are currently selected.
See also:
Send the time source to an output connector
This call is only applicable on devices with PPS outputs. By default, the PPS output will be enabled for ease of use. This call may be used to enable or disable the output.
| enb | true to output the time source. |
virtual |
Synchronize a list of motherboards
| mb_controllers | A list of motherboard controllers to synchronize. Any motherboard controllers that could not be synchronized because they're incompatible with this motherboard controller are removed from the list. On return, the list should be (ideally) identical to its value at call time. |
| time_spec | Time specification to syncrhonize mb_controllers to |
| quiet | If true, don't print any errors or warnings if synchronization fails. |
mb_controllers could be synchronized.
