#include <uhd/rfnoc/property.hpp>
Public Types | |
| enum | access_t { NONE , RO = 0x1 , RW = 0x3 , RWLOCKED = 0x5 } |
| property_base_t (const std::string &id, const res_source_info &source_info) | |
| virtual | ~property_base_t () |
| const std::string & | get_id () const |
| Gets the ID (name) of this property.  More... | |
| const res_source_info & | get_src_info () const |
| Return the source info for this property.  More... | |
| virtual bool | is_dirty () const =0 |
| Query this property's dirty flag.  More... | |
| virtual bool | is_valid () const =0 |
| Query this property's valid flag.  More... | |
| bool | read_access_granted () const |
| Returns true if this property can be read.  More... | |
| bool | write_access_granted () const |
| Returns true if this property can be written to.  More... | |
| access_t | get_access_mode () const |
| Return the current access mode.  More... | |
| virtual bool | equal (property_base_t *rhs) const =0 |
| Return true if rhs has the same type and value.  More... | |
| virtual std::unique_ptr< property_base_t > | clone (res_source_info) |
| Create a copy of this property.  More... | |
| virtual void | force_dirty ()=0 |
| virtual void | set_from_str (const std::string &new_val_str)=0 |
Friends | |
| class | prop_accessor_t |
Base class for properties
  inline |
  inlinevirtual |
  inlinevirtual |
Reimplemented in uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, and uhd::rfnoc::property_t< size_t >.
Implemented in uhd::rfnoc::dirtifier_t, uhd::rfnoc::property_t< data_t >, uhd::rfnoc::property_t< double >, and uhd::rfnoc::property_t< size_t >.
  inline |
  inline |
  inline |
  inline |
Set this property's value using a string
This requires the underlying property type to be convertible from a string.
| uhd::runtime_error | if the underlying type has no conversion from a string |
  inline |
  friend |
