| action_handler_t typedef | uhd::rfnoc::node_t | |
| add_property_resolver(prop_ptrs_t &&inputs, prop_ptrs_t &&outputs, resolver_fn_t &&resolver_fn) | uhd::rfnoc::node_t | protected |
| ALWAYS_DIRTY | uhd::rfnoc::node_t | protectedstatic |
| ANY_PORT | uhd::rfnoc::node_t | static |
| check_topology(const std::vector< size_t > &connected_inputs, const std::vector< size_t > &connected_outputs) | uhd::rfnoc::node_t | protectedvirtual |
| clear_command_time(const size_t instance) | uhd::rfnoc::node_t | virtual |
| deinit() | uhd::rfnoc::noc_block_base | protectedvirtual |
| forwarding_map_t typedef | uhd::rfnoc::node_t | |
| forwarding_policy_t enum name | uhd::rfnoc::node_t | |
| get_amplitude(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| get_block_args() const | uhd::rfnoc::noc_block_base | inline |
| get_block_id() const | uhd::rfnoc::noc_block_base | inline |
| get_command_time(const size_t instance) const | uhd::rfnoc::node_t | virtual |
| get_constant(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| get_enable(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| get_mb_controller() | uhd::rfnoc::noc_block_base | protected |
| get_mtu(const res_source_info &edge) | uhd::rfnoc::noc_block_base | |
| get_mtu_prop_ref(const res_source_info &edge) | uhd::rfnoc::noc_block_base | protected |
| get_noc_id() const | uhd::rfnoc::noc_block_base | inline |
| get_num_input_ports() const | uhd::rfnoc::noc_block_base | inlinevirtual |
| get_num_output_ports() const | uhd::rfnoc::noc_block_base | inlinevirtual |
| get_property(const std::string &id, const size_t instance=0) | uhd::rfnoc::node_t | |
| get_property(const std::string &id, const res_source_info &src_info) | uhd::rfnoc::node_t | protected |
| get_property_ids() const | uhd::rfnoc::node_t | |
| get_samples_per_packet(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| get_sine_phase_increment(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| get_tick_rate() const | uhd::rfnoc::noc_block_base | |
| get_tree() const | uhd::rfnoc::noc_block_base | inline |
| get_tree() | uhd::rfnoc::noc_block_base | inline |
| get_unique_id() const | uhd::rfnoc::noc_block_base | inlinevirtual |
| get_waveform(const size_t port) const =0 | uhd::rfnoc::siggen_block_control | pure virtual |
| make_args_ptr typedef | uhd::rfnoc::noc_block_base | |
| noc_block_base(make_args_ptr make_args) | uhd::rfnoc::noc_block_base | protected |
| node_t() | uhd::rfnoc::node_t | |
| post_action(const res_source_info &edge_info, action_info::sptr action) | uhd::rfnoc::node_t | protected |
| prop_ptrs_t typedef | uhd::rfnoc::node_t | protected |
| REG_BLOCK_SIZE | uhd::rfnoc::siggen_block_control | static |
| REG_CARTESIAN_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_CONSTANT_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_ENABLE_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_GAIN_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_PHASE_INC_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_SPP_OFFSET | uhd::rfnoc::siggen_block_control | static |
| REG_WAVEFORM_OFFSET | uhd::rfnoc::siggen_block_control | static |
| register_action_handler(const std::string &id, action_handler_t &&handler) | uhd::rfnoc::node_t | protected |
| register_iface_holder(register_iface::sptr reg) | uhd::rfnoc::register_iface_holder | inline |
| register_property(property_base_t *prop, resolve_callback_t &&clean_callback=nullptr) | uhd::rfnoc::node_t | protected |
| regs() | uhd::rfnoc::register_iface_holder | inline |
| resolve_callback_t typedef | uhd::rfnoc::node_t | |
| resolver_fn_t typedef | uhd::rfnoc::node_t | |
| RFNOC_DECLARE_BLOCK(siggen_block_control) | uhd::rfnoc::siggen_block_control | |
| set_action_forwarding_map(const forwarding_map_t &map) | uhd::rfnoc::node_t | protected |
| set_action_forwarding_policy(forwarding_policy_t policy, const std::string &action_key="") | uhd::rfnoc::node_t | protected |
| set_amplitude(const double amplitude, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| set_command_time(uhd::time_spec_t time, const size_t instance) | uhd::rfnoc::node_t | virtual |
| set_constant(const std::complex< double > constant, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| set_enable(const bool enable, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| set_mtu(const res_source_info &edge, const size_t new_mtu) | uhd::rfnoc::noc_block_base | protected |
| set_mtu_forwarding_policy(const forwarding_policy_t policy) | uhd::rfnoc::noc_block_base | protected |
| set_num_input_ports(const size_t num_ports) | uhd::rfnoc::noc_block_base | protected |
| set_num_output_ports(const size_t num_ports) | uhd::rfnoc::noc_block_base | protected |
| set_prop_forwarding_map(const forwarding_map_t &map) | uhd::rfnoc::node_t | protected |
| set_prop_forwarding_policy(forwarding_policy_t policy, const std::string &prop_id="") | uhd::rfnoc::node_t | protected |
| set_properties(const uhd::device_addr_t &props, const size_t instance=0) | uhd::rfnoc::node_t | |
| set_property(const std::string &id, const prop_data_t &val, const size_t instance=0) | uhd::rfnoc::node_t | |
| set_property(const std::string &id, const prop_data_t &val, const res_source_info &src_info) | uhd::rfnoc::node_t | protected |
| set_samples_per_packet(const size_t spp, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| set_sine_frequency(const double frequency, const double sample_rate, const size_t port) | uhd::rfnoc::siggen_block_control | inline |
| set_sine_phase_increment(const double phase_inc, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| set_tick_rate(const double tick_rate) | uhd::rfnoc::noc_block_base | protected |
| set_waveform(const siggen_waveform type, const size_t port)=0 | uhd::rfnoc::siggen_block_control | pure virtual |
| sptr typedef | uhd::rfnoc::noc_block_base | |
| update_reg_iface(register_iface::sptr new_iface=nullptr) | uhd::rfnoc::register_iface_holder | protected |
| ~noc_block_base() | uhd::rfnoc::noc_block_base | virtual |
| ~node_t() | uhd::rfnoc::node_t | inlinevirtual |
| ~register_iface_holder()=default | uhd::rfnoc::register_iface_holder | virtual |
